Hi,
I’m having trouble getting an old external USB drive to work in Manjaro. It works just fine in Windows 10 and Linux Mint, so I suspect some kernel / driver problem maybe?
edit: Tested with Manjaro 6.1, 5.x and 4.19 -kernels. Works fine in 4.19 but not in the others!
When connecting the disk, dmesg
shows:
[ 232.906701] usb 3-5: new high-speed USB device number 3 using xhci_hcd
[ 233.049541] usb 3-5: New USB device found, idVendor=14cd, idProduct=6116, bcdDevice= 1.50
[ 233.049547] usb 3-5: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[ 233.049550] usb 3-5: Product: Mobile HDD
[ 233.049551] usb 3-5: Manufacturer: Super Top
[ 233.049553] usb 3-5: SerialNumber: M6116018VE15
[ 233.587841] usb-storage 3-5:1.0: USB Mass Storage device detected
[ 233.587911] scsi host10: usb-storage 3-5:1.0
[ 233.587965] usbcore: registered new interface driver usb-storage
[ 233.590151] usbcore: registered new interface driver uas
[ 234.590650] scsi 10:0:0:0: Direct-Access Mobile HDD PQ: 0 ANSI: 0
[ 234.591349] sd 10:0:0:0: [sdf] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 234.591462] sd 10:0:0:0: [sdf] Write Protect is off
[ 234.591464] sd 10:0:0:0: [sdf] Mode Sense: 03 00 00 00
[ 234.591578] sd 10:0:0:0: [sdf] No Caching mode page found
[ 234.591579] sd 10:0:0:0: [sdf] Assuming drive cache: write through
[ 234.614606] sdf: sdf1
[ 234.614685] sd 10:0:0:0: [sdf] Attached SCSI disk
[ 247.181598] sd 10:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=11s
[ 247.181604] sd 10:0:0:0: [sdf] tag#0 Sense Key : Illegal Request [current]
[ 247.181607] sd 10:0:0:0: [sdf] tag#0 Add. Sense: Invalid command operation code
[ 247.181609] sd 10:0:0:0: [sdf] tag#0 CDB: Read(6) 08 00 00 3f 08 00
[ 247.181611] critical target error, dev sdf, sector 63 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 247.182059] sd 10:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[ 247.182061] sd 10:0:0:0: [sdf] tag#0 Sense Key : Illegal Request [current]
[ 247.182063] sd 10:0:0:0: [sdf] tag#0 Add. Sense: Invalid command operation code
[ 247.182064] sd 10:0:0:0: [sdf] tag#0 CDB: Read(6) 08 00 00 3f 08 00
[ 247.182065] critical target error, dev sdf, sector 63 op 0x0:(READ) flags 0x0 phys_seg 4 prio class 2
[ 247.182068] Buffer I/O error on dev sdf1, logical block 0, async page read
[ 247.182071] Buffer I/O error on dev sdf1, logical block 1, async page read
[ 247.182072] Buffer I/O error on dev sdf1, logical block 2, async page read
[ 247.182074] Buffer I/O error on dev sdf1, logical block 3, async page read
smartctl -a /dev/sdf
also fails without an explicit device type:
Read Device Identity failed: scsi error medium or hardware error (serious)
But works when -d usbcypress
is specified:
$ sudo smartctl -a /dev/sdf -d usbcypress
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.55-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Scorpio Blue Serial ATA
Device Model: WDC WD1600BEVT-00A23T0
Serial Number: WD-WX21A30W4141
LU WWN Device Id: 5 0014ee 2aeef9e4c
Firmware Version: 01.01A01
User Capacity: 160 041 885 696 bytes [160 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
Device is: In smartctl database 7.3/5528
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Sun Oct 22 12:20:04 2023 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 5580) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 68) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7037) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 153 152 021 Pre-fail Always - 1316
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 178
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 62
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 106
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 60
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 396
194 Temperature_Celsius 0x0022 115 093 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for mor
edit: also tried adding amd_iommu=on iommu=pt
to kernel cmdline, no effect…
Any ideas please?
