I used my external drives last week without any problem. No update/upgrade and yesterday/today I get:
Jul 21 13:20:50 el-tadpole kernel: usb 2-2: USB disconnect, device number 12
Jul 21 13:20:50 el-tadpole kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jul 21 13:20:51 el-tadpole kernel: sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Jul 21 13:20:57 el-tadpole kernel: usb 2-2: new SuperSpeed Gen 1 USB device number 13 using xhci_hcd
Jul 21 13:20:57 el-tadpole kernel: usb 2-2: New USB device found, idVendor=2109, idProduct=0711, bcdDevice= 1.14
Jul 21 13:20:57 el-tadpole kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 21 13:20:57 el-tadpole kernel: usb 2-2: Product: USB3.0 SATA Bridge
Jul 21 13:20:57 el-tadpole kernel: usb 2-2: Manufacturer: VIA Labs,Inc.
Jul 21 13:20:57 el-tadpole kernel: usb 2-2: SerialNumber: 000000000026
Jul 21 13:20:57 el-tadpole kernel: scsi host0: uas
Jul 21 13:20:57 el-tadpole mtp-probe[15504]: checking bus 2, device 13: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb2/2-2"
Jul 21 13:20:57 el-tadpole mtp-probe[15504]: bus: 2, device: 13 was not an MTP device
Jul 21 13:20:57 el-tadpole mtp-probe[15531]: checking bus 2, device 13: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb2/2-2"
Jul 21 13:20:57 el-tadpole mtp-probe[15531]: bus: 2, device: 13 was not an MTP device
Jul 21 13:21:07 el-tadpole kernel: scsi 0:0:0:0: Direct-Access WDC WD40 EFRX-68WT0N0 80.0 PQ: 0 ANSI: 6
Jul 21 13:21:07 el-tadpole kernel: scsi 0:0:0:0: Attached scsi generic sg0 type 0
Jul 21 13:21:07 el-tadpole kernel: sd 0:0:0:0: [sda] 7814037164 512-byte logical blocks: (4.00 TB/3.64 TiB)
Jul 21 13:21:07 el-tadpole kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 21 13:21:07 el-tadpole kernel: sd 0:0:0:0: [sda] Mode Sense: 31 00 00 00
Jul 21 13:21:07 el-tadpole kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 21 13:21:07 el-tadpole kernel: sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
Jul 21 13:21:07 el-tadpole kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Here’s my inxi
System: Kernel: 5.12.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.3
tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05 serial: <filter>
Chassis: type: 31 v: IdeaPad Flex 5 14ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: EECN35WW
date: 04/16/2021
Battery: ID-1: BAT0 charge: 31.7 Wh (60.4%) condition: 52.5/52.5 Wh (100.0%) volts: 11.5 min: 11.5
model: Celxpert L19C3PD6 serial: <filter> status: Unknown
CPU: Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2
rev: 1 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31958
Speed: 3005 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 3005 2: 2384
3: 2892 4: 2338 5: 2263 6: 1456 7: 1467 8: 2297
Graphics: Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0 chip-ID: 1002:1636
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 174f:243f
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu
resolution: 2560x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.16-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.4
direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus-ID: 04:00.5 chip-ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.12.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8822ce v: N/A port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:3
chip-ID: 0bda:8153
IF: enp4s0f3u1u4 state: down mac: <filter>
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 0bda:c123
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled rfk-block: hardware: no
software: yes address: see --recommends
Drives: Local Storage: total: 4.1 TiB used: 89.46 GiB (2.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 serial: <filter>
ID-2: /dev/sda type: USB vendor: Western Digital model: WD40 EFRX-68WT0N0 size: 3.64 TiB
serial: <filter>
Partition: ID-1: / size: 451.77 GiB used: 89.44 GiB (19.8%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 16.9 MiB (5.6%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 16.58 GiB used: 768 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 51.2 C mobo: 41.0 C gpu: amdgpu temp: 43.0 C
Info: Processes: 236 Uptime: 2h 5m Memory: 15.07 GiB used: 2.66 GiB (17.6%) Init: systemd v: 248
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1408 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.05
How to track what’s the problem is?
Thank you
NOT TESTED
