Since Monday i have been using the hdmi out on my laptop paired with a docking station that has one non displaylink usbc-displayport to use my two external monitors and it has been working fine. When i woke up today and turned my laptop on i had lost my signal from both ports.
I ran xrandr --listproviders
and i still show 0 and 1, i ran just regular xrandr
and it shows the hdmi and dp ports available but says they are disconnected.
Im running the linux-video drivers and my hardware is a intel 10750h with a nvidia 2060 mobile gpu.
any help is greatly appreciated!
result of xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x45 cap: 0xb, Source Output, Sink Output, Sink Offload crtcs: 4 outputs: 2 associated providers: 1 name:Intel
Provider 1: id: 0xaf cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 4 associated providers: 1 name:modesetting
result of xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm 1920x1080 240.00*+ 60.00
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
eDP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
