Please help, I upadated yesterday and running on Manjaro, but I have no external monitors showing anymore. Currently on Plasma 6.0.4, KDE framework 6.1.0, Qt 6.7.0 and Kernel 6.9.0.1-MANJARO. I do not have an Nvidia GPU but using an intel iGPU inside a Dell Latitude 5520. I originally thought it was my Dock that was messed up so I ordered a new one (it has been working flawlessly for years) today, I decided to dig in a little bit more while I wait for the new dock and it turns out that Wayland just isn’t seeing the external monitors. I found an HDMI and plugged directly from the laptop to the monitor, bypassing the dock, and still no display. The monitor will even flicker on and say no output when I plug it in, so the display sees something but not getting the output and the laptop isn’t seeing anything.
As far as error messages, I am not getting anything in dmesg, I watched it as I plugged in the monitor directly and unplugged again and nothing. This is the only errors I have in the journal but they don’t appear to be for the monitor:
May 14 10:46:41 redacted kwin_wayland[4513]: kf.svg: The theme "Sweet" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
May 14 10:46:45 redacted plasmashell[4702]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.simplemenu", fileName: "/usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/metadata.json") doe>
May 14 10:46:46 redacted systemd[4438]: Started Display Configuration.
May 14 10:46:46 redacted kded6[4665]: org.kde.plasma.appmenu: Got an error
May 14 10:46:47 redacted systemsettings[10617]: file:///usr/lib/qt6/qml/org/kde/kirigami/Dialog.qml:334:18: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth"
May 14 10:46:47 redacted systemsettings[10617]: qrc:/kcm/kcm_kscreen/main.qml:39:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
May 14 10:46:47 redacted systemsettings[10617]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_76 to IconPropertiesGroup_QMLTYPE_76
May 14 10:46:47 redacted systemsettings[10617]: qrc:/kcm/kcm_kscreen/main.qml:39:5: QML OverlaySheet: Binding loop detected for property "implicitWidth"
I am going crazy and tried to revert back to X11 but the monitors don’t work. I can actually see them when running xrandr but the system settings won’t allow me to enable them again. I am not sure how to fix this.
I have tried installing drivers again, and removing all mentions of Nvidia (originally the laptop had an Nvidia GPU but the SSD was transferred to this host, it has worked for well over a year though.
Any help the community could provide would be really appreciated.
I downgraded to Kernel 6.6.30-2-MANJARO with the same issue present
