Hello,
My laptop has a lot of ports but I personally prefer a clean desk setup so I just bought a usb hub and connects two external monitors. The usb hub is connected to my laptop via thunderbolt.
My issue is that somehow manjaro is only able to connect one of my two external monitors. If I enable one, another one can still be detected, see the screenshot below (here I am using BenQ as my external monitor, and Ancor is the one I wish to enable. Manjaro is able to idenitfy the monitor)
But when I enable it, it does not do anything. In fact when I close the setting and reopen, Ancor is not enabled again.
However, I notice
- On windows using usb-c hub is working fine, windows can detect and enable both of my external monitors
- Using my laptop’s own hub is also working fine, both external monitors can be enabled
- When I disable BenQ and enable Ancor, it then becomes BenQ that can be detected but not enabled.
The results of xrandr --listmonitors: can only find two
Monitors: 2
0: +*eDP-1 2560/382x1440/215+0+0 eDP-1
1: +DP-1-2 3840/621x2160/341+2560+0 DP-1-2
The results of xrandr, it can find three monitors:
Screen 0: minimum 320 x 200, current 6400 x 2160, maximum 16384 x 16384
eDP-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
2560x1440 165.00*+ 60.00 + 59.99 59.99 59.96 59.95
1920x1440 85.00 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96 59.93
1600x1200 85.00 75.00 70.00 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 connected 3840x2160+2560+0 (normal left inverted right x axis y axis) 621mm x 341mm
3840x2160 30.00*+ 29.98
2560x1600 59.97
2560x1440 59.95
1920x1080 60.00 60.00 50.00 59.94
1680x1050 59.88
1280x1024 75.02 60.02
1440x900 59.90
1280x960 60.00
1152x864 75.00
1280x720 60.00 50.00 59.94
1440x576 50.00
1024x768 75.03 70.07 60.00
1440x480 60.00 59.94
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
1600x900 (0xe5) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
The results of inxi -Gazy:
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: DP-6,eDP-1 off: DP-5 empty: DP-1,DP-2,DP-7 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU]
vendor: Hewlett-Packard driver: nvidia v: 535.104.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24a0 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 0408:5477
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a driver:
X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 6400x2160 s-dpi: 96 s-size: 1691x571mm (66.57x22.48")
s-diag: 1785mm (70.27")
Monitor-1: DP-1-2 pos: right res: 3840x2160 hz: 30 dpi: 157
size: 621x341mm (24.45x13.43") diag: 708mm (27.89") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 2560x1440 hz: 165 dpi: 170
size: 382x215mm (15.04x8.46") diag: 438mm (17.26") modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
It can also find two monitors.
Any help is greatly appreciated. Thanks!
