External monitor switch
On my Ideapad, after last upgrade external monitor switch
disappeared.
When I connect an external monitor the internal one is automatically disabled and I can’t choose whether to duplicate the screen, extend or …
Thanks to Timeshift I returned to the previous configuration
Please provide system information as described (below).
I’m not sure that anyone can help with your issue now that you;
using Timeshift.
However, if the issue arises again, be sure to let us know. Remember to provide as much useful information as possible.
Required reading
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly. :eyes:
Output of the inxi command with appropriate parameters will achieve this (naturally, formatted according to forum requirements) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
I discovered that it is a bug of Plasma 6.3.4
https://bugs.kde.org/show_bug.cgi?id=502486
https://bugs.kde.org/show_bug.cgi?id=503437
Wait for Plasma 6.3.5
