You know I am not against Wayland at all. I think it is a also the right path to got with. I just would like to get the problems away. By the way I am not new to this forum.
Here the information you requested. I hope it will help a little further and finally we can solve the problem.
soundofthunder:
inxi -zv8
Kernel: 6.17.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
root=UUID=… rw rootflags=subvol=@
pci=realloc pci=nocrs thunderbolt.clx=0 quiet
cryptdevice=UUID=…:luks-…
root=/dev/mapper/luks-… splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
wm: kwin_wayland tools: xscreensaver,xscreensaver-systemd vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: … v: ThinkPad P16 Gen 2
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: … serial:
part-nu: LENOVO_MT_21FA_BU_Think_FM_ThinkPad P16 Gen 2
uuid: Firmware: UEFI vendor: LENOVO
v: N3TET59W (1.59 ) date: 05/07/2025
ID-1: BAT0 charge: 82.5 Wh (95.6%) condition: 86.3/93.5 Wh (92.2%)
volts: 12.8 min: 11.52 model: SMP 5B10W51893 type: Li-poly serial:
charging: status: not charging control: start: 0% end: 100% cycles: 126
System RAM: total: 64 GiB available: 62.45 GiB used: 5.07 GiB (8.1%)
Array-1: capacity: 128 GiB note: est. slots: 4 modules: 2
EC: Single-bit ECC max-module-size: 32 GiB note: est.
Device-1: Controller0-ChannelA/B-DIMM0 type: no module installed
Device-2: Controller0-ChannelA/B-DIMM1 type: DDR5 detail: synchronous
size: 32 GiB speed: spec: 5600 MT/s actual: 4000 MT/s volts: curr: 1
width (bits): data: 64 total: 72 manufacturer: SK Hynix
part-no: ““I wil provide, if necessary”” serial:
Device-3: Controller1-ChannelA/B-DIMM0 type: no module installed
Device-4: Controller1-ChannelA/B-DIMM1 type: DDR5 detail: synchronous
part-no: “I wil provide, if necessary” serial:
Info: model: 13th Gen Intel Core i9-13950HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x132
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 800 min/max: 800/5300:5500:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
bogomips: 154828
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v1 mitigation: usercopy/swapgs barriers and \__user pointer
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: DP-2 off: eDP-1 empty: DP-1, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3
chip-ID: 30c9:0050 class-ID: fe01 serial:
Device-3: EMEET SmartCam S600
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 328f:00ad
class-ID: 0300 serial:
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: DP-2 model: Lenovo Y34wz-30 serial: built: 2023 res:
mode: 3440x1440 hz: 120 scale: 125% (1.25) to: 2752x1152 dpi: 110 gamma: 1.2
chroma: red: x: 0.694 y: 0.302 green: x: 0.251 y: 0.667 blue: x: 0.145
y: 0.055 white: x: 0.314 y: 0.329 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: 3440x1440, 2560x1440, 1920x1080, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x720, 1024x768, 832x624, 800x600,
720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 76 2: parse_edid:
unknown tag 112
Monitor-2: eDP-1 model: BOE Display 0x0ae0 built: 2021 res: 2560x1600
dpi: 189 gamma: 1.2 chroma: red: x: 0.643 y: 0.333 green: x: 0.298 y: 0.624
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
modes: 2560x1600
EDID-Warnings: 1: parse_edid: unknown tag 112
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 60.98 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 4 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:a788 surfaces: N/A
wl: wayland-info x11: xdpyinfo,xprop
Device-1: Intel Raptor Lake High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
Device-2: EMEET SmartCam S600
API: ALSA v: k6.17.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel 700 Series CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.2:3 chip-ID: 0bda:8156
class-ID: 0000 serial:
IF: enp72s0u2u2 state: up speed: 1000 Mbps duplex: full mac:
broadcast:
IF-ID-1: virbr0 state: down mac:
IP v4: scope: global broadcast:
Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
WAN IP:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0033
class-ID: e001
Device-1: luks-… maj-min: 253:0
type: LUKS dm: dm-0 size: 341.79 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 341.8 GiB
Device-2: luks-… maj-min: 253:1
type: LUKS dm: dm-1 size: 1.53 TiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 1.53 TiB
Local Storage: total: 1.86 TiB used: 1.12 TiB (60.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
tech: SSD serial: fw-rev: 5106APLA temp: 31.9 C scheme: GPT
ID-1: / raw-size: 341.79 GiB size: 341.79 GiB (100.00%)
used: 196.14 GiB (57.4%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-… label: N/A
uuid: …
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.80%)
used: 904 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: …
ID-3: /home raw-size: 341.79 GiB size: 341.79 GiB (100.00%)
uuid: …
ID-4: /mnt/Daten raw-size: 1.53 TiB size: 1.53 TiB (100.00%)
used: 947.94 GiB (60.5%) fs: btrfs dev: /dev/dm-1 maj-min: 253:1
mapped: luks-… label: Daten
uuid: …
ID-5: /var/cache raw-size: 341.79 GiB size: 341.79 GiB (100.00%)
uuid: …
ID-6: /var/log raw-size: 341.79 GiB size: 341.79 GiB (100.00%)
uuid: …
Device-1: 1-3:18 info: Synaptics type: driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:0126 class-ID: ff00 serial:
Device-2: 1-4:3 info: Luxvisions Innotech Integrated RGB Camera
type: video driver: uvcvideo interfaces: 5 rev: 2.0
Hub-2: 1-6:4 info: Lenovo USB2.1 Hub ports: 6 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:10a9
Hub-3: 1-6.3:6 info: Lenovo USB2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:10ab
Hub-4: 1-6.3.2:9 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Device-1: 1-6.3.2.2:13 info: CHERRY Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 046a:a087 class-ID: 0301
Device-2: 1-6.3.2.3:14 info: Lenovo USB-A Unified Pairing Receiver
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 17ef:6116 class-ID: 0301
Device-3: 1-6.3.3:12 info: CHERRY MX BOARD 10.0N FL RGB Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:00df class-ID: 0301
Device-4: 1-6.4:8 info: Lenovo Gaming Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 17ef:10ac class-ID: 0300
serial:
Device-5: 1-6.6:11 info: Realtek HID Device type: HID
chip-ID: 0bda:1100 class-ID: 0300
Device-6: 1-7:5 info: EMEET SmartCam S600 type: video,audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
chip-ID: 328f:00ad class-ID: 0300 serial:
Device-7: 1-9:7 info: Generic EMV Smartcard Reader type: smart card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 50mA chip-ID: 2ce3:9563 class-ID: 0b00
Device-8: 1-14:10 info: Intel AX211 Bluetooth type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-5: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 4-2:2 info: Lenovo USB3.2 Hub ports: 3 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:10a8
Device-1: 4-2.2:3 info: Realtek USB 10/100/1G/2.5G LAN type: Network
driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 256mA chip-ID: 0bda:8156 class-ID: 0000
serial:
Hub-9: 4-2.3:4 info: Lenovo USB3.2 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:10aa
System Temperatures: cpu: 51.0 C mobo: 35.5 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Packages: 2168 pm: pacman pkgs: 2122 libs: 436 tools: pamac,yay pm: flatpak
pkgs: 46
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 505
1: cpu: 1.4% command: kate pid: 5134 mem: 359.1 MiB (0.5%)
2: cpu: 1.3% command: konsole pid: 4659 mem: 355.4 MiB (0.5%)
3: cpu: 0.5% command: firefox pid: 2843 mem: 701.2 MiB (1.0%)
4: cpu: 0.4% command: kwin_wayland pid: 1264 mem: 367.6 MiB (0.5%)
5: cpu: 0.3% command: firefox pid: 3260 mem: 319.8 MiB (0.5%)
Memory top: 5 of 505
1: mem: 701.2 MiB (1.0%) command: firefox pid: 2843 cpu: 0.5%
2: mem: 585.6 MiB (0.9%) command: plasmashell pid: 2461 cpu: 0.0%
3: mem: 367.6 MiB (0.5%) command: kwin_wayland pid: 1264 cpu: 0.4%
4: mem: 359.1 MiB (0.5%) command: kate pid: 5134 cpu: 1.4%
5: mem: 355.4 MiB (0.5%) command: konsole pid: 4659 cpu: 1.3%
Processes: 505 Power: uptime: 8h 47m states: freeze,mem,disk suspend: s2idle
wakeups: 4 fails: 3 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 24.96 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.40
A structured summarization you find below.
