- both native and external monitors run in 1080p @ 144hz
- if i try to move the external monitor from right to left in the display settings, the external monitor freezes.
- when screenlock gets activated, external monitor will not wake up anymore and in the settings it is disabled.
- i also had issue where external monitor randomly froze. this was semi-fixed with removing google chrome’s hardware acceleration. more info here: External monitor (primary) behind laptop freezes frequently
i have been using the same system and installation couple of years without any issues.
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=1edf72db-d3e8-47d1-9201-a5cfa27e1efb rw quiet
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Micro-Star product: GF65 Thin 10SDR v: REV:1.0
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16W1IMS.50B date: 05/19/2020
ID-1: BAT1 charge: 46.7 Wh (92.1%) condition: 50.7/51.3 Wh (98.8%)
volts: 12.6 min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.17 GiB used: 3.23 GiB (10.4%)
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3035 high: 4793 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 2951 3: 4698
4: 2600 5: 2600 6: 2600 7: 2600 8: 2600 9: 3188 10: 2600 11: 4793 12: 2600
bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:2191
class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-1-0 pos: primary,right res: 1920x1080 hz: 144 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: eDP-1 pos: left res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: br-43524aa4e9b7 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth4423070 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth52bca71 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth606a363 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vetha21809f state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: vethab753c7 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0026 class-ID: e001
Device-1: luks-cab6c7fd-4b0a-4197-8b19-d8f2119cc7e4 maj-min: 254:0
type: LUKS dm: dm-0 size: 427.62 GiB
Components:
p-1: nvme1n1p3 maj-min: 259:4 size: 427.62 GiB
Local Storage: total: 1.38 TiB used: 621.05 GiB (44.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 3B2QEXM7 temp: 33.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1032 size: 476.94 GiB block-size: physical: 512 B
rev: 21111000 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 36.19 GiB (75.8%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A
uuid: 1edf72db-d3e8-47d1-9201-a5cfa27e1efb
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
label: NO_LABEL uuid: 3ED8-9B8B
ID-3: /disk raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 499.93 GiB (54.6%) fs: ext4 dev: /dev/nvme0n1 maj-min: 259:1
label: disk uuid: fd9709f4-de6f-4289-b2e3-61b5ac58233e
ID-4: /home raw-size: 427.62 GiB size: 419.83 GiB (98.18%)
used: 84.93 GiB (20.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cab6c7fd-4b0a-4197-8b19-d8f2119cc7e4 label: N/A
uuid: a62fb052-0601-468e-81d4-1fd028bc804b
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
Device-3: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
System Temperatures: cpu: 51.0 C pch: 51.0 C mobo: N/A
Processes: 352 Uptime: 7m wakeups: 5 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1709 libs: 476 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
> 0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:9bc4) Display controller Intel Corporation:
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 144.15*+ 60.01 59.97 59.96 60.20 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
HDMI-1-0 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 143.98*+ 119.98 119.88 99.93 60.00 59.94 50.00
3840x2160 59.94 50.00 29.97 25.00 23.98
1280x1024 75.02
1280x720 59.94
1024x768 119.99 75.03 60.00
800x600 119.97 75.00 60.32
720x576 50.00
720x480 59.94
640x480 120.01 75.00 59.94 59.93
1280x1024 (0x52) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1024x768 (0x69) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x6b) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x86) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x87) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0x9a) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x9b) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
i hope somebody can finally help me out.
