My external monitor stopped working after unplugging it. I can see the login prompt to start a session, but once I log in the KDE logo appears for a second and then it’s gone and the monitor won’t display anything. It has worked normally until now, and I’m not sure what causes the flaw. I didn’t update anything before or after this happened and the system is up-to-date. I tried both HDMI and USB-C (to HDMI dongle).
I found a post (“Monitor Stopped Working Suddenly – Displays at login, not after” – I don’t seem to be allowed to post the link) and changing users works, but I’d like to stay with the actual user if possible.
Any ideas on what may have caused the issue and how to fix it?
Thinkpad p53
inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=8ad4c5a0-a095-4ad0-9e56-f777755bfc33 rw
quiet udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20QNCTO1WW v: ThinkPad P53 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20QNCTO1WW v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: N2NET37W (1.22 )
date: 04/28/2020
Battery: ID-1: BAT0 charge: 80.8 Wh condition: 82.8/90.0 Wh (92%) volts: 12.7/11.2 model: Celxpert 5B10W13902
type: Li-poly serial: <filter> status: Unknown cycles: 26
Memory: RAM: total: 30.98 GiB used: 2.84 GiB (9.2%)
CPU: Topology: 6-Core model: Intel Core i7-9850H bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: D (13) microcode: D6 L2 cache: 12.0 MiB bogomips: 62431
Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2
bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Graphics: Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3e9b
Device-2: NVIDIA TU106GLM [Quadro RTX 3000 Mobile / Max-Q] vendor: Lenovo driver: nvidia v: 440.100
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f36
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:3 chip ID: 13d3:56bc
serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting,nvidia display ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1014x317mm (39.9x12.5") s-diag: 1062mm (41.8")
Monitor-1: DP-1 res: 1920x1200 dpi: 89 size: 550x340mm (21.7x13.4") diag: 647mm (25.5")
Monitor-2: eDP-1-1 res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Quadro RTX 3000/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: BEHRINGER type: USB driver: snd-usb-audio bus ID: 1-5.2:7 chip ID: 1397:0509
Sound Server: ALSA v: k5.8.11-1-MANJARO
Network: Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
chip ID: 8086:15bb
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 52:00.0 chip ID: 8086:2723
IF: wlp82s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 953.87 GiB used: 215.06 GiB (22.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730 SDBQNTY-1T00-1001 size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 11130101
scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 452.84 GiB size: 444.74 GiB (98.21%) used: 215.03 GiB (48.4%) fs: ext4
dev: /dev/nvme0n1p5 label: N/A uuid: 8ad4c5a0-a095-4ad0-9e56-f777755bfc33
ID-2: /boot/efi raw size: 260.0 MiB size: 256.0 MiB (98.46%) used: 29.1 MiB (11.4%) fs: vfat
dev: /dev/nvme0n1p1 label: SYSTEM uuid: 844C-1034
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 size: 499.78 GiB fs: bitlocker label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 size: 1000.0 MiB fs: ntfs label: WinRE_DRV uuid: F6964F7E964F3E7D
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-5:2 info: Fresco Logic USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s chip ID: 1d5c:5010
Hub: 1-5.1:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0608
Device-1: 1-5.1.3:8 info: Logitech Marble Mouse (4-button) type: Mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s chip ID: 046d:c408
Hub: 1-5.1.4:10 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0608
Device-1: 1-5.1.4.1:11 info: Apple Aluminium Keyboard (ISO) type: Keyboard,HID driver: apple,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 05ac:0250 serial: <filter>
Device-2: 1-5.2:7 info: BEHRINGER type: Audio driver: snd-usb-audio interfaces: 6 rev: 2.0
speed: 480 Mb/s chip ID: 1397:0509
Device-3: 1-5.3:9 info: Fresco Logic type: Billboard driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 1d5c:7102
Device-4: 1-8:3 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 4
rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56bc serial: <filter>
Device-5: 1-9:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00bd serial: <filter>
Device-6: 1-11:6 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card driver: N/A interfaces: 1
rev: 2.0 speed: 12 Mb/s chip ID: 058f:9540
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 6-2:2 info: Fresco Logic USB3.0 Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d5c:5000
Sensors: System Temperatures: cpu: 56.0 C mobo: 43.0 C gpu: nvidia temp: 45 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 287 Uptime: 28m Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1668 lib: 475 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
