Hi there,
I’ve just finished installing Manjaro in my laptop with all the proprietary drivers as per the installation options, but my external monitor is not being recognized. I’ve selected the “Configure new displays when connected” option under Settings Manager > Display and tried to reboot, but with no result.
It uses integrated intel graphics as well as Nvidia, and I’ve read around these forums different options but I’m just quite lost about what to do exactly. Please any help is much appreciated.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a194c01e-c496-4b13-bc8c-331adc3b2108 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Portable System: Dell product: Dell System XPS L502X v: N/A
serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter>
Mobo: Dell model: 0YR8NN v: A00 serial: <filter> UEFI-[Legacy]: Dell v: A10
date: 02/20/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
RAM: total: 7.66 GiB used: 2.05 GiB (26.7%)
Info: Dual Core model: Intel Core i7-2640M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 4 MiB bogomips: 22356
Speed: 798 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 798 2: 1125
3: 809 4: 884
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep smx ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0126
class-ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 525M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:0df5
class-ID: 0300
Device-3: Quanta Laptop_Integrated_Webcam_2HDM type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 0408:2fb1 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.2.1 compat-v: 3.0 direct render: Yes
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0083 class-ID: 0280
vendor: Dell driver: r8169 v: kernel port: 2000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 7.61 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500423AS
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: DEM1 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW SN-208BB rev: D300
dev-links: cdrom
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%) used: 7.61 GiB (1.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: a194c01e-c496-4b13-bc8c-331adc3b2108
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Quanta Laptop_Integrated_Webcam_2HDM type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 250mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C mobo: 48.0 C
Processes: 193 Uptime: 3h 19m wakeups: 13 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1051 lib: 302
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
$ xrandr
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767
LVDS1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1366x768 60.01*+
1280x720 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
680x384 60.00
640x360 59.84 59.32 60.00
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
