Sorry about that, this is the output from
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=34622b9f-c5f4-445b-85b2-eb2a6a1b4132 rw nouveau.modeset=0 quiet
splash resume=UUID=8fde4ab7-b2d1-45ca-9d70-3a933c09d6ff
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Razer product: Blade 14 - RZ09-0370 v: 1.04
serial: Chassis: type: 10 serial:
Mobo: Razer model: PI411 v: 4 serial:
part-nu: RZ09-0370BEA3 uuid: UEFI: Razer v: 1.06
date: 06/07/2021
ID-1: BAT0 charge: 55.0 Wh (98.0%) condition: 56.1/62.0 Wh (90.5%)
volts: 16.8 min: 15.5 model: Razer Blade type: Unknown serial:
status: discharging
System RAM: total: 16 GiB available: 15.03 GiB used: 3.97 GiB (26.4%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E1 serial: N/A
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1597 high: 2383 min/max: 400/4680 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2026 2: 400 3: 2287
4: 1397 5: 2130 6: 1397 7: 1397 8: 1396 9: 2341 10: 1751 11: 2383 12: 400
13: 1867 14: 1896 15: 2084 16: 400 bogomips: 105443
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Razer USA
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Razer USA driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 50.0 C
Monitor-1: eDP-1 res: 2048x1152 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 2 drv: swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi inactive: gbm
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.54 6.6.25-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Laptop GPU driver: nvidia v: 550.67 device-ID: 10de:249d
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland
Device-1: NVIDIA GA104 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Razer USA
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Razer USA
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp2s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 465.76 GiB used: 358.08 GiB (76.9%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 448.93 GiB size: 440.81 GiB (98.19%)
used: 358.04 GiB (81.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 34622b9f-c5f4-445b-85b2-eb2a6a1b4132
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 227A-7A0D
ID-1: swap-1 type: partition size: 16.54 GiB used: 36.2 MiB (0.2%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 8fde4ab7-b2d1-45ca-9d70-3a933c09d6ff
Device-1: 1-3:2 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Device-2: 1-4:3 info: Razer USA Blade type: keyboard,mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0270 class-ID: 0300
Hub-4: 3-1:11 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 3-1.1:12 info: SINOWEALTH Wired Gaming Mouse type: mouse,keyboard
driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 480mA chip-ID: 258a:0033 class-ID: 0301
Device-2: 3-1.2:13 info: KiwiKey Wanderland type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 4b57:574c class-ID: 0300
Device-3: 3-1.5:14 info: VIA Labs USB Billboard Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 2109:8886 class-ID: 1100 serial:
Device-4: 3-4:3 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56d5 class-ID: 0e02 serial:
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-1:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
System Temperatures: cpu: 53.5 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): N/A
Processes: 354 Power: uptime: 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.95 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1560 pm: pacman pkgs: 1549 libs: 472 tools: pamac pm: flatpak
pkgs: 11 Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh v: 5.9
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
