Hello, i’ve decided to try Manjaro and the live CD was a beautiful experience.
I’m using a laptop (Dell inspiron with an nvidia g.card).
while using the Live CD version (boot using thumb drive), my external display was functioning well.
It seems that manjaro installed with nvidia drivers which detect the discrete graphics card, but not the display (which is connected using HDMI).
I’ve tried installing optimus-manager, which didn’t change much.
xrandr only lists one display - the integrated laptop one.
Thank you in advance.
Olli
8 March 2024 22:19
2
please post the output of
inxi -v8zy
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e143a976-64c2-45df-9b09-6dd59036365c rw quiet splash
resume=UUID=ca41b1b6-f615-4023-8c90-3ccd212b9c10 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 065C71 v: A00 serial: <superuser required> part-nu: 0798
uuid: <superuser required> UEFI: Dell v: 1.15.0 date: 08/30/2021
ID-1: BAT0 charge: 54.1 Wh (100.0%) condition: 54.1/74.0 Wh (73.1%)
volts: 12.9 min: 11.1 model: Samsung SDI DELL 0GFJ6F4 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.49 GiB used: 3.22 GiB (20.8%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB
speed: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Kingston part-no: K821PJ-MIB
serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 44817
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0300
Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris
gpu: i915,nvidia display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 15.13 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 550.54.14 device-ID: 10de:1c8c
surfaces: xcb,xlib,wayland
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: Dell RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:3165 class-ID: 0280
Info: services: NetworkManager,wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0a2a
class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.03 TiB used: 10.67 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNK128GVN8 M.2 2280
128GB size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 4101 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10JPVX-75JC3T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A03 scheme: GPT
ID-1: / raw-size: 101.91 GiB size: 99.75 GiB (97.88%) used: 10.67 GiB (10.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: e143a976-64c2-45df-9b09-6dd59036365c
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0C7D-A3F4
ID-1: swap-1 type: partition size: 17.04 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: ca41b1b6-f615-4023-8c90-3ccd212b9c10
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 489.11 GiB fs: ntfs label: The
uuid: 34AA40E6AA40A668
ID-3: /dev/sdb3 maj-min: 8:19 size: 442.38 GiB fs: ext4 label: N/A
uuid: ffb3b7f2-a75c-40d0-96e8-3e46b1289f83
Device-1: 1-2:2 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Device-2: 1-3:3 info: Kingston HyperX Alloy Origins Core type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 0951:16e6 class-ID: 0300
Device-3: 1-4:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Device-4: 1-12:5 info: Sunplus Innovation Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 1bcf:28c1 class-ID: 0e02
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 49.0 C pch: 44.5 C mobo: 38.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Packages: pm: pacman pkgs: 1138 libs: 329 tools: pamac pm: flatpak pkgs: 0
1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
3: http://manjaro.grena.ge/stable/$repo/$arch
Processes:
CPU top: 5 of 231
1: cpu: 6.4% command: firefox pid: 1222 mem: 547.7 MiB (3.4%)
2: cpu: 2.4% command: kwin_wayland pid: 698 mem: 348.7 MiB (2.1%)
3: cpu: 1.5% command: plasmashell pid: 860 mem: 460.7 MiB (2.9%)
4: cpu: 1.2% command: firefox pid: 2067 mem: 129.0 MiB (0.8%)
5: cpu: 1.0% command: firefox pid: 1543 mem: 291.7 MiB (1.8%)
Memory top: 5 of 231
1: mem: 547.7 MiB (3.4%) command: firefox pid: 1222 cpu: 6.4%
2: mem: 460.7 MiB (2.9%) command: plasmashell pid: 860 cpu: 1.5%
3: mem: 348.7 MiB (2.1%) command: kwin_wayland pid: 698 cpu: 2.4%
4: mem: 291.7 MiB (1.8%) command: firefox pid: 1543 cpu: 1.0%
5: mem: 260.3 MiB (1.6%) command: konsole pid: 2207 cpu: 0.8%
Processes: 231 Power: uptime: 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Olli
8 March 2024 22:54
4
okay step 1:
post the output of
echo $XDG_SESSION_TYPE && glxinfo | grep server
you’ll see that you’re running wayland what doesn’t charm with nvidia.
reboot and look at the login-screen at the left, bottom corner. there is a menu where to choose between wayland and x11. choose x11, login, repeat the command to make sure you’re on x11.
the other output is the gpu. sgi = intel, nvidia is that what we’ll want. but first things first.
report if you done the first steps.
Everything’s just as you said.
glx vendor is “sgi”.
Yes.
Sometimes I’m prompted to select if I want to display on one screen or the other, it doesn’t matter what I choose though - nothing changes and I’m prompted again a few moments later.
i’ve tried to run:
prime-offload
optimus-manager --switch hybrid
after logging in again, the display freezes on the loading screen.
Olli
8 March 2024 23:48
8
that’s clear, your type of laptop is hardwired. this means you can use the laptopdisplay on intel or nvidia but the external display need the use of the nvidia card.
next step, install envycontrol to switch the cards
pamac install envycontrol
stop, disable and mask optimus (you can remove it later if everything is fine)
sudo systemctrl stop optimus-manager && sudo systemctrl disable optimus-manager && sudo systemctrl mask optimus-manager
make sure optimus is disabled
systemctrl status optimus-manager
it must be inactive
use envycontrol to switch to nvidia
sudo envycontrol -s nvidia
reboot, login and check again
nvidia ? if not, no problem. in this case we’ll edit grub but try this first
Works!
I hope this thread helps more people.
For future reference:
After inputting:
i had to correct “systemctrl” to systemctl.
Also, for some reason optimus-manager simply doesn’t exist (Command not found).
Regardless, the external monitor works well and becomes the primary display once i close the laptop’s lid.
Much appreciated Olli!
Olli
8 March 2024 23:59
10
that’s why i thought it’s installed.
a little bit late and a little bit tired, sorry for the typo-mismatch.
It was, i have no clue how it disappeared - I did not remove it and was using it moments before you’ve solved the problem.
Cheers for the effort - thank you.
Olli
9 March 2024 00:19
12
check the system-settings → display
you can configure it from there
system
Closed
10 March 2024 12:20
13
