Hi everyone, so I’ve recently installed Manjaro KDE on my laptop and has had issues with my second monitor not being detected. More specifically, I’m not using a graphic driver right now because when I install the “video-hybrid-intel-nvidia-390xx-bumblebee” driver from “Hardware Configuration” and reboot, my second monitor doesn’t get detected. Same goes for the “video-nvidia-390xx” driver because then the external display is the only one that works. I’m currently able to use both displays without drivers, but it causes screen tearing which is annoying. First time on the forums and any help would be appreciated, and I’m a newbie.
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=39f79ccf-5b10-458f-a6c6-1daa4e8a1562 rw quiet apparmor=1
security=apparmor resume=UUID=102bea20-facf-45a1-ad4f-fae1f2dcc789
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E6430 v: 01
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0H3MT5 v: A00 serial: <superuser required> UEFI: Dell
v: A24 date: 08/08/2019
ID-1: BAT0 charge: 52.8 Wh (100.0%) condition: 52.8/99.9 Wh (52.9%)
volts: 12.5 min: 11.1 model: SMP DELL 5F1R523 type: Li-ion serial: <filter>
status: full
RAM: total: 5.7 GiB used: 2.25 GiB (39.5%)
RAM Report:
Info: model: Intel Core i5-3360M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1520 high: 1802 min/max: 1200/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1802 2: 1697 3: 1387
4: 1196 bogomips: 22333
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel ports: active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GF108GLM [NVS 5200M] vendor: Dell driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1, DP-2, LVDS-2, VGA-2 bus-ID: 01:00.0 chip-ID: 10de:0dfc
class-ID: 0300
Device-3: Ruision UVC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2.2:4 chip-ID: fefe:4321 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915,nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 868x285mm (34.17x11.22")
s-diag: 914mm (35.97")
Monitor-1: HDMI-A-1 mapped: HDMI-1-1 pos: primary,right model: Sceptre M27
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: LVDS-1 pos: primary,left model: LG Display 0x033e built: 2012
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 22.0.3
compat-v: 3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0082 class-ID: 0280
Device-1: Dell BCM20702A0 Bluetooth Module type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 413c:8197 class-ID: fe01 serial: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 530.5 GiB used: 10.9 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD3200BEKT-75PVMT1 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer
size: 232.41 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5HH rev: SD11
dev-links: cdrom
ID-1: / raw-size: 228.14 GiB size: 223.5 GiB (97.97%) used: 10.9 GiB (4.9%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 39f79ccf-5b10-458f-a6c6-1daa4e8a1562
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: BF80-E1E4
ID-1: swap-1 type: partition size: 3.96 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 102bea20-facf-45a1-ad4f-fae1f2dcc789
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: DAB8-B0B5
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 297.39 GiB fs: ntfs label: N/A
uuid: 9414BA3814BA1D64
ID-4: /dev/sda4 maj-min: 8:4 size: 604 MiB fs: ntfs label: N/A
uuid: B2D0D559D0D523FF
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: SanDisk Cruzer type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5530 class-ID: 0806 serial: <filter>
Device-2: 1-1.4:4 info: Dell BCM20702A0 Bluetooth Module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 413c:8197
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.8:3 info: Broadcom BCM5880 Secure Applications Processor
with fingerprint swipe sensor
type: Smart Card driver: N/A interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5801 class-ID: fe00 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-2.1:3 info: Holtek Gaming Mouse [Redragon M711]
type: Mouse,Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:fc30 class-ID: 0300
Device-2: 3-2.2:4 info: Ruision UVC Camera type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1 speed: 480 Mb/s
power: 2mA chip-ID: fefe:4321 class-ID: 0102 serial: <filter>
Device-3: 3-2.3:5 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 60.0 C mobo: 50.0 C sodimm: SODIMM C gpu: nouveau
temp: 51.0 C
Fan Speeds (RPM): cpu: 2874
Processes: 228 Uptime: 4m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1207 lib: 333
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
