External monitor gets disconnected after sleep
I am using Manjaro Gnome on my Lenovo Thinkpad. I am using an external LG monitor. After reconnecting HDMI cable I often faces problem in getting my screen on External monitor.
Suppose my external monitor is working fine and i put my laptop on sleep mode then on opening it again my external monitor says ““No Signal Please check your connection””. I have to power off my external monitor and connect again to get signal. This creates a lot unease.
inxi -Gazy
[raman@Manjaro ~]$ inxi -Gazy
  Device-1: Intel Meteor Lake-P [Intel Graphics] vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
    ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:7d45 class-ID: 0300
  Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 30c9:00cd
    compositor: gnome-shell v: 48.5 driver: gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2025 res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 3840x2160 min: 640x480
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x1614 built: 2021 res: 1920x1200
    dpi: 142 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 1920x1200
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (MTL)
    device-ID: 8086:7d45 memory: 30.14 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
[raman@Manjaro ~]$
I want to see my laptop screen on external monitor as soon as it is connected with hdmi.
Please provide your system information (full inxi output) as described (below) and any other useful details.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
inxi output
This text will be hidden
[raman@Manjaro ~]$ inxi --filter --verbosity=8
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=ce43b5b6-7094-4d0a-aeaf-e54ca176aa56 rw quiet splash apparmor=1
  Desktop: GNOME v: 48.5 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21L3002VPB v: ThinkPad L16 Gen 1
  Mobo: LENOVO model: 21L3002VPB v: SDK0T76530 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21L3_BU_Think_FM_ThinkPad
    L16 Gen 1 uuid: <superuser required> UEFI: LENOVO v: R2HET40W (1.19 )
    date: 04/30/2025
  ID-1: BAT0 charge: 32.8 Wh (55.3%) condition: 59.3/57 Wh (104.1%)
    power: 6.1 W volts: 11.39 min: 11.31 model: Sunwoda 5B11H56398 type: Li-poly
    serial: <filter> charging: status: discharging control: start: 75%
    end: 80% cycles: 92
  System RAM: total: 32 GiB available: 30.86 GiB used: 3.32 GiB (10.8%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 16 GiB speed: 5600 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: SK Hynix part-no: HMCG78AGBSA095N serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
    total: 64 manufacturer: Kingston part-no: 9905790-178.A00G
    serial: <filter>
  Info: model: Intel Core Ultra 7 155U bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x25
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 12 threads: 14 mt: 2 tpc: 2
    st: 10 smt: enabled cache: L1: 1.2 MiB desc: d-10x32 KiB, 2x48 KiB; i-12x64
    KiB L2: 10 MiB desc: 5x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4800:3800:2100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    bogomips: 75292
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
    built: 2025 res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.651
    y: 0.333 green: x: 0.286 y: 0.635 blue: x: 0.153 y: 0.043 white: x: 0.314
    y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1280x720, 1024x768, 800x600,
    720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
    dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
    blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 1920x1200
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Intel vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:550b class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
  Local Storage: total: 476.94 GiB used: 59.8 GiB (12.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1112AXLA temp: 23.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 59.8 GiB (12.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: ce43b5b6-7094-4d0a-aeaf-e54ca176aa56
    used: 392 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 250F-337B
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-5:2 info: Luxvisions Innotech Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00cd class-ID: fe01
    serial: <filter>
  Device-2: 3-6:3 info: Generic EMV Smartcard Reader type: smart card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 2ce3:9563 class-ID: 0b00
  Device-3: 3-7:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
  System Temperatures: cpu: 37.0 C mobo: 28.5 C
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 1620 libs: 378
    tools: gnome-software,pamac,paru,yay pm: flatpak pkgs: 0
    1: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    5: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    8: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 379
  1: cpu: 26.8% command: firefox pid: 3072 mem: 577.2 MiB (1.8%)
  2: cpu: 15.5% command: firefox pid: 3318 mem: 259.3 MiB (0.8%)
  3: cpu: 12.1% command: gnome-shell pid: 2235 mem: 318.5 MiB (1.0%)
  4: cpu: 6.2% command: firefox pid: 3346 mem: 335.6 MiB (1.0%)
  5: cpu: 1.8% command: firefox pid: 3205 mem: 69.8 MiB (0.2%)
  Memory top: 5 of 379
  1: mem: 577.2 MiB (1.8%) command: firefox pid: 3072 cpu: 26.8%
  2: mem: 335.6 MiB (1.0%) command: firefox pid: 3346 cpu: 6.2%
  3: mem: 318.5 MiB (1.0%) command: gnome-shell pid: 2235 cpu: 12.1%
  4: mem: 259.3 MiB (0.8%) command: firefox pid: 3318 cpu: 15.5%
  5: mem: 153.0 MiB (0.4%) command: firefox pid: 3194 cpu: 0.7%
  Processes: 379 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
    image: 12.33 GiB services: gsd-power,upowerd Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
    running-in: gnome-terminal inxi: 3.3.39
[raman@Manjaro ~]$
Topic abandoned.
