Hello. I’ve just switched from Ubuntu 20.04LTS. I’m having an issue where I plug in an external monitor, the system recognizes it and extends my workspaces onto it, but the monitor is blank. If I check the display settings it shows the monitor name and the frequency 75hz. If I try to change it to 60hz or unplug the monitor, the system locks up.
This laptop has always had i915 issues since I started using Linux a few years ago. I get massive screen tearing and flashing, and have to add intel_idle.max_cstate=1 to my grub file to make it stop. It’s an i915 error.
i915 0000:00:02.0: [drm] *ERROR* CPU pipe A FIFO underrun
Anyway, new problem. external monitor no worky, crashes system on disconnect. It’s a DP cable going to a USBC to DP dongle from Startech if it matters.
[tim@elitebook ~]$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP EliteBook Folio G1 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8170 v: KBC Version 29.73 serial: <filter> UEFI: HP v: N91 Ver. 01.45 date: 01/05/2020
Battery: ID-1: BAT0 charge: 25.1 Wh condition: 25.6/25.6 Wh (100%) volts: 8.6/7.7 model: Hewlett-Packard Primary
type: Li-ion serial: <filter> status: Unknown
Device-1: hid-00:1f:20:fe:33:30-battery model: Bluetooth Mouse M336/M337/M535 serial: N/A charge: N/A
status: Discharging
Memory: RAM: total: 7.66 GiB used: 1.9 GiB (24.9%)
CPU: Info: Dual Core model: Intel Core m5-6Y54 bits: 64 type: MT MCP arch: Skylake rev: 3 L2 cache: 4 MiB
bogomips: 12007
Speed: 500 MHz min/max: 400/2700 MHz Core speeds (MHz): 1: 500 2: 501 3: 500 4: 500
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel HD Graphics 515 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:191e
class ID: 0300
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-1:2 chip ID: 04f2:b58f class ID: 0e02
Device-3: Chicony HP IR Camera type: USB driver: uvcvideo bus ID: 1-7:4 chip ID: 04f2:b58e class ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 515 (SKL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:9d70 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: 3000 bus ID: 6d:00.0 chip ID: 8086:24f3
class ID: 0280
IF: wlp109s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus ID: 1-5:3 chip ID: 8087:0a2b
class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 238.47 GiB used: 12.8 GiB (5.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVPV256HDGL-000H1 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: BXW74H0Q temp: 34.9 C scheme: GPT
Partition: ID-1: / size: 224.77 GiB used: 12.8 GiB (5.7%) fs: ext4 dev: /dev/dm-0
mapped: luks-8014fb2b-1bdd-43d2-a194-12b958a1a3f6 label: N/A uuid: daf21609-8d6c-4979-a6cf-9ba867e9828d
ID-2: /boot/efi size: 299.4 MiB used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: 8642-D53A
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
mapped: luks-2e5545fc-56a2-492b-8129-d66ea8496aac label: N/A uuid: e3cab305-1e13-483e-ad0c-037ebfd06ed7
Unmounted: Message: No Unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Chicony HP HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
Device-2: 1-5:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0a2b class ID: e001
Device-3: 1-7:4 info: Chicony HP IR Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 04f2:b58e class ID: 0e02 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
Sensors: System Temperatures: cpu: 41.0 C mobo: 0.0 C
Info: Processes: 182 Uptime: 1h 05m wakeups: 1917 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1279
Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
[tim@elitebook ~]$ journalctl -p3 -b -1
-- Journal begins at Tue 2021-03-09 13:09:59 EST, ends at Wed 2021-03-10 09:01:01 EST. --
Mar 10 08:01:46 elitebook kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 exceeds size of target Buffer (64 bits) (>
Mar 10 08:01:46 elitebook kernel: ACPI Error: Aborting method \_SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (20200717/psparse-529)
Mar 10 08:01:47 elitebook kernel: i2c_hid i2c-ALP000F:00: unexpected HID descriptor bcdVersion (0x0000)
Mar 10 08:01:49 elitebook wpa_supplicant[674]: nl80211: kernel reports: Attribute failed policy validation
Mar 10 08:01:49 elitebook wpa_supplicant[674]: Failed to create interface p2p-dev-wlp109s0: -22 (Invalid argument)
Mar 10 08:01:49 elitebook wpa_supplicant[674]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp109s0
Mar 10 08:01:50 elitebook kernel: Bluetooth: hci0: Reading supported features failed (-16)
Mar 10 08:02:05 elitebook kwin_x11[1106]: kwin_xkbcommon: XKB: Couldn't process include statement for 'us(\0)'
Mar 10 08:02:05 elitebook kwin_x11[1106]: kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
Mar 10 08:02:05 elitebook kwin_x11[1106]: kwin_xkbcommon: XKB: Failed to compile xkb_symbols
Mar 10 08:02:05 elitebook kwin_x11[1106]: kwin_xkbcommon: XKB: Failed to compile keymap
Mar 10 08:02:05 elitebook kernel: i915 0000:00:02.0: [drm] *ERROR* CPU pipe B FIFO underrun
The current DMESG doesn’t have any i915 errors, though I could connect the monitor and pull another log if that would help. I can repeat the crash consistently.
I’ve installed an older kernel (5.4 LTS) using the Manjaro Settings Manager, but I haven’t tried it yet.
Thanks in advance!
EDIT: Is there a better way to format my code so that it’s easier to read? This came out pretty messy.
I changed down to the 5.4.101-1 LTS kernel, which is the same as I was running with Ubuntu, and am getting the same failure.
-- Journal begins at Tue 2021-03-09 13:09:59 EST, ends at Wed 2021-03-10 16:22:14 EST. --
Mar 10 15:49:49 elitebook kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 exceeds size >
Mar 10 15:49:49 elitebook kernel: ACPI Error: Aborting method \_SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (20200717/pspar>
Mar 10 15:49:54 elitebook kernel: Bluetooth: hci0: Reading supported features failed (-16)
Mar 10 15:50:32 elitebook kwin_x11[1078]: kwin_xkbcommon: XKB: Couldn't process include statement for 'us(\0)'
Mar 10 15:50:32 elitebook kwin_x11[1078]: kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
Mar 10 15:50:32 elitebook kwin_x11[1078]: kwin_xkbcommon: XKB: Failed to compile xkb_symbols
Mar 10 15:50:32 elitebook kwin_x11[1078]: kwin_xkbcommon: XKB: Failed to compile keymap
Mar 10 15:50:33 elitebook bluetoothd[681]: Failed to set mode: Blocked through rfkill (0x12)
Mar 10 15:50:57 elitebook wpa_supplicant[1659]: nl80211: kernel reports: Attribute failed policy validation
Mar 10 15:50:57 elitebook wpa_supplicant[1659]: Failed to create interface p2p-dev-wlp109s0: -22 (Invalid argument)
Mar 10 15:50:57 elitebook wpa_supplicant[1659]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp109s0
Mar 10 16:19:15 elitebook systemd-coredump[4888]: Failed to send coredump datagram: Connection reset by peer
Mar 10 16:19:16 elitebook systemd-cryptsetup[4903]: Device luks-8014fb2b-1bdd-43d2-a194-12b958a1a3f6 is still in use.
Mar 10 16:19:16 elitebook systemd-cryptsetup[4903]: Failed to deactivate: Device or resource busy
Mar 10 16:19:16 elitebook kernel: watchdog: watchdog0: watchdog did not stop!
DMESG from when I plugged in the monitor:
[ 65.548427] usb 3-1: new full-speed USB device number 2 us
ing xhci_hcd
[ 65.689894] usb 3-1: New USB device found, idVendor=1fc9,
idProduct=5002, bcdDevice= 6.45
[ 65.689901] usb 3-1: New USB device strings: Mfr=1, Produc
t=2, SerialNumber=3
[ 65.689906] usb 3-1: Product: Type-C Video Adapter
[ 65.689910] usb 3-1: Manufacturer: NXP
[ 65.689914] usb 3-1: SerialNumber: 0000020f4bb5
[ 65.772689] usb 3-1: USB disconnect, device number 2
[ 66.138013] usb 3-1: new full-speed USB device number 3 us
ing xhci_hcd
[ 66.279484] usb 3-1: New USB device found, idVendor=1fc9,
[ 66.279491] usb 3-1: New USB device strings: Mfr=1, Produc
t=2, SerialNumber=3
[ 66.279496] usb 3-1: Product: Type-C Video Adapter
[ 66.279501] usb 3-1: Manufacturer: NXP
[ 66.279504] usb 3-1: SerialNumber: 0000020f4bb5
[ 68.548045] [drm] Reducing the compressed framebuffer size
. This may lead to less power savings than a non-reduced-size
. Try to increase stolen memory size if available in BIOS.
[ 68.604947] [drm:intel_cpu_fifo_underrun_irq_handler [i915
]] *ERROR* CPU pipe B FIFO underrun
[ 72.539259] audit: type=1131 audit(1615411301.510:92): pid
=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=
'unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/
systemd" hostname=? addr=? terminal=? res=success'
[ 270.138470] proc: Bad value for 'hidepid'
[ 270.198394] audit: type=1130 audit(1615411499.169:93): pid
[ 300.232835] audit: type=1131 audit(1615411529.208:94): pid
[ 460.743562] audit: type=1100 audit(1615411689.723:95): pid
=2415 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:a
uthentication grantors=pam_faillock,pam_permit,pam_faillock a
cct="tim" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev
/pts/1 res=success'
I was really hoping rolling back the kernel to stable was going to fix this. Looks like a window manager issue and not the kernel. I used gnome3 on Ubuntu.
