External monitor does not wake
Greetings,
I have 2 external monitors connected to a Lenovo Legion y540 with Nvidia Optimus GTX1650 via HDMI and USB-CWhen idle, the monitors go into Standby as usual, but since the latest update on the 23rd, the USB-C monitor does not wake up. I have to unplug and re-connect for it to work again.It’s probably another Nvidia update that’s re-introduced this old bug.Does anyone have a workaround - apart from disabling power-saving on the displays :slight_smile: ?
Thanks
  Kernel: 6.12.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=432cb4a9-67db-4cab-babe-8dba06904b6b rw rootflags=subvol=@
    quiet splash resume=UUID=b2ceb5fb-544a-437c-b946-65ed79479ff3
    udev.log_priority=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 81SY v: Legion Y540-15IRH-PG0
    serial: <superuser required> Chassis: type: 10 v: Legion Y540-15IRH-PG0
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN
    part-nu: LENOVO_MT_81SY_BU_idea_FM_Legion Y540-15IRH-PG0
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: BHCN44WW
    date: 01/20/2022
  ID-1: BAT0 charge: 39.6 Wh (96%) condition: 41.2/52.5 Wh (78.5%)
    volts: 12.44 min: 11.34 model: LGC L17L3PG1 type: Li-poly serial: <filter>
    charging: status: not charging cycles: 683
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.22 GiB used: 5.27 GiB (16.9%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
    total: 64 manufacturer: 0898 part-no: KD4AGSA8M-26N1900 serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
    governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
    7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
    ports: active: none off: eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 580.119.02 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: none off: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 01:00.0
    chip-ID: 10de:1f91 class-ID: 0300
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1.4:7
    chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Device-4: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:8 chip-ID: 04f2:b6d9
  Display: x11 server: X.org v: 1.21.1.21 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
    dri: iris gpu: i915,nv_platform,nvidia,nvidia-nvswitch display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: right
    model: Dell S2421HN serial: <filter> built: 2021 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
    x: 0.329 y: 0.612 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  Monitor-2: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary,left
    model: Dell S2421HN serial: <filter> built: 2022 res: mode: 1920x1080 hz: 60
  Monitor-3: eDP-1 note: disabled model: LG Display 0x05e5 built: 2018
    res: 1920x1080 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.369 green:
    x: 0.349 y: 0.557 blue: x: 0.153 y: 0.110 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b memory: 30.48 GiB unified: yes
    gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  Device-4: Afatech Gaming Headset driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
    chip-ID: 1b80:b532 class-ID: 0300
  API: ALSA v: k6.12.63-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: on status: off (using pipewire-pulse)
    tools: pacat,pactl,pavucontrol
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:13
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 1.86 TiB used: 45.71 GiB (2.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 Pro 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 52A8T27A temp: 34.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
    size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 1.00
  ID-1: / raw-size: 256 GiB size: 256 GiB (100.00%) used: 42.95 GiB (16.8%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7 label: ROOT
    uuid: 432cb4a9-67db-4cab-babe-8dba06904b6b
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 632 KiB (0.0%)
    fs: vfat block-size: 512 B dev: /dev/nvme0n1p6 maj-min: 259:6 label: EFI
    uuid: 11B2-8B11
  ID-3: /data01 raw-size: 256 GiB size: 256 GiB (100.00%)
    used: 2.76 GiB (1.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8
    maj-min: 259:8 label: DATA uuid: fe1f0c06-4f26-416e-a108-df1c935fbc51
  ID-4: /home raw-size: 256 GiB size: 256 GiB (100.00%)
    used: 42.95 GiB (16.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
    maj-min: 259:7 label: ROOT uuid: 432cb4a9-67db-4cab-babe-8dba06904b6b
  ID-5: /var/cache raw-size: 256 GiB size: 256 GiB (100.00%)
  ID-6: /var/log raw-size: 256 GiB size: 256 GiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
    zswap: no
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: SWAP
    uuid: b2ceb5fb-544a-437c-b946-65ed79479ff3
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: N/A
    uuid: FA1F-57FE
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 399.28 GiB fs: ntfs label: N/A
    uuid: 684222294221FD06
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 735 MiB fs: ntfs label: N/A
    uuid: D2CE7A3ACE7A16C7
  ID-5: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: N/A
    uuid: 3183E4F87D63E8F0
  Hub-2: 1-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
    chip-ID: 2109:0811 class-ID: 0900
  Hub-3: 1-1.1:4 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
    chip-ID: 1a40:0201 class-ID: 0900
  Device-1: 1-1.1.4:7 info: Logitech Webcam C270 type: video,audio
  Hub-4: 1-1.2:6 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
  Hub-5: 1-1.3:9 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
  Device-1: 1-1.3.6:12 info: Wacom CTL-4100 [Intuos (S)] type: HID
    driver: usbhid,wacom interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 056a:0374 class-ID: 0300
    serial: <filter>
  Hub-6: 1-1.4:11 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
  Device-1: 1-1.4.1:14 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Device-2: 1-1.4.3:15 info: BY Tech Gaming Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:010c class-ID: 0300
  Device-3: 1-1.4.7:16 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-4: 1-2:3 info: Afatech Gaming Headset type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-5: 1-4:21 info: Realtek BillBoard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 2mA chip-ID: 0bda:2172 class-ID: 1100 serial: <filter>
  Device-6: 1-6:8 info: Chicony Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6d9 class-ID: 0e02
    serial: <filter>
  Device-7: 1-9:10 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
  Device-8: 1-14:13 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-7: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-8: 2-1:2 info: VIA Labs Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
  System Temperatures: cpu: 69.0 C pch: 68.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1277 libs: 328 tools: pamac,yay
    1: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 347
  1: cpu: 7.0% command: firefox pid: 22975 mem: 586.6 MiB (1.8%)
  2: cpu: 5.3% command: firefox pid: 4184 mem: 862.8 MiB (2.6%)
  3: cpu: 3.7% command: firefox pid: 11177 mem: 577.5 MiB (1.8%)
  4: cpu: 2.9% command: Xorg pid: 1117 mem: 209.5 MiB (0.6%)
  5: cpu: 1.3% command: firefox pid: 6735 mem: 481.0 MiB (1.5%)
  Memory top: 5 of 347
  1: mem: 862.8 MiB (2.6%) command: firefox pid: 4184 cpu: 5.3%
  2: mem: 653.1 MiB (2.0%) command: firefox pid: 4643 cpu: 0.6%
  3: mem: 586.6 MiB (1.8%) command: firefox pid: 22975 cpu: 7.0%
  4: mem: 580.4 MiB (1.8%) command: firefox pid: 4412 cpu: 0.8%
  5: mem: 577.5 MiB (1.8%) command: firefox pid: 11177 cpu: 3.7%
  Processes: 347 Power: uptime: 3h 32m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.42 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 258
  Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: kitty inxi: 3.3.40
[2025-12-23T09:13:17+0200] [ALPM] upgraded iana-etc (20251114-1 -> 20251120-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded readline (8.3.001-1 -> 8.3.003-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded bash (5.3.8-1 -> 5.3.9-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded babl (0.1.116-1 -> 0.1.118-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded util-linux-libs (2.41.2-1 -> 2.41.3-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded libgpg-error (1.57-1 -> 1.58-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded systemd-libs (258.2-2 -> 258.3-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded bind (9.20.16-1 -> 9.20.17-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded cpupower (6.17-2 -> 6.18-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded device-mapper (2.03.37-1 -> 2.03.38-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded spirv-tools (1:1.4.328.1-1 -> 1:1.4.335.0-1)
[2025-12-23T09:13:17+0200] [ALPM] upgraded egl-x11 (1.0.4-0 -> 1.0.4-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded nvidia-utils (580.119.02-1 -> 580.119.02-2)
[2025-12-23T09:13:18+0200] [ALPM] upgraded egl-wayland (4:1.1.21-0 -> 4:1.1.21-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded enchant (2.8.12-2 -> 2.8.14-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded exfatprogs (1.3.0-1 -> 1.3.1-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded glslang (1:1.4.328.1-1 -> 1:1.4.335.0-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded vulkan-icd-loader (1.4.328.1-1 -> 1.4.335.0-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded shaderc (2025.4-2 -> 2025.5-1)
[2025-12-23T09:13:18+0200] [ALPM] upgraded libplacebo (7.351.0-3 -> 7.351.0-4)
[2025-12-23T09:13:18+0200] [ALPM] upgraded opus (1.5.2-1 -> 1.6-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded util-linux (2.41.2-1 -> 2.41.3-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded ffmpeg (2:8.0.1-1 -> 2:8.0.1-2)
[2025-12-23T09:13:19+0200] [ALPM] upgraded ffmpegthumbnailer (2.2.4-1 -> 2.3.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded firefox (146.0-1 -> 146.0.1-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded gegl (0.4.64-1 -> 0.4.66-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded imagemagick (7.1.2.10-1 -> 7.1.2.11-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded ipython (9.7.0-1 -> 9.7.0-2)
[2025-12-23T09:13:19+0200] [ALPM] upgraded kconfig (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded kguiaddons (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded ki18n (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded kcolorscheme (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded kcoreaddons (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded kcrash (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:19+0200] [ALPM] upgraded kdbusaddons (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded knotifications (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded kwidgetsaddons (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded kwindowsystem (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded kwallet (6.20.0-1 -> 6.21.0-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded lib32-spirv-tools (1:1.4.328.1-1 -> 1:1.4.335.0-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded libdecor (0.2.4-1 -> 0.2.5-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded libnm (1.54.2-1 -> 1.54.3-1)
[2025-12-23T09:13:20+0200] [ALPM] upgraded libnotify (0.8.7-1 -> 0.8.7-2)
[2025-12-23T09:13:20+0200] [ALPM] upgraded systemd (258.2-2 -> 258.3-1)
[2025-12-23T09:13:21+0200] [ALPM] installed libmakepkg-dropins (18-1)
[2025-12-23T09:13:21+0200] [ALPM] warning: /etc/makepkg.conf.d/fortran.conf installed as /etc/makepkg.conf.d/fortran.conf.pacnew
[2025-12-23T09:13:21+0200] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2025-12-23T09:13:21+0200] [ALPM] upgraded pacman (7.0.0.r10.ga2d0293-3 -> 7.1.0.r7.gb9f7d4a-3)
[2025-12-23T09:13:21+0200] [ALPM] upgraded perl-error (0.17030-2 -> 0.17030-3)
[2025-12-23T09:13:21+0200] [ALPM] upgraded perl-timedate (2.33-8 -> 2.33-9)
[2025-12-23T09:13:21+0200] [ALPM] upgraded perl-mailtools (2.22-2 -> 2.22-3)
[2025-12-23T09:13:21+0200] [ALPM] upgraded libpamac (11.7.4-1 -> 11.7.4-4)
[2025-12-23T09:13:22+0200] [ALPM] upgraded libsigc++ (2.12.1-1 -> 2.12.1-2)
[2025-12-23T09:13:22+0200] [ALPM] upgraded libsigc++-3.0 (3.6.0-1 -> 3.8.0-1)
[2025-12-23T09:13:22+0200] [ALPM] upgraded liburing (2.12-1 -> 2.13-1)
[2025-12-23T09:13:22+0200] [ALPM] upgraded linux612 (6.12.62-1 -> 6.12.63-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded linux612-headers (6.12.62-1 -> 6.12.63-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded linux612-nvidia-open (580.119.02-2 -> 580.119.02-3)
[2025-12-23T09:13:25+0200] [ALPM] upgraded lvm2 (2.03.37-1 -> 2.03.38-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-xml-writer (0.900-5 -> 0.900-6)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-encode-locale (1.05-14 -> 1.05-15)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-uri (5.34-1 -> 5.34-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-http-date (6.06-4 -> 6.06-5)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-file-listing (6.16-5 -> 6.16-6)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-http-cookiejar (0.014-4 -> 0.014-5)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-io-html (1.004-7 -> 1.004-8)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-lwp-mediatypes (6.04-7 -> 6.04-8)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-http-message (7.01-1 -> 7.01-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-http-cookies (6.11-3 -> 6.11-4)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-http-daemon (6.16-5 -> 6.16-6)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-http-negotiate (6.01-15 -> 6.01-16)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-net-http (6.24-1 -> 6.24-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-try-tiny (0.32-3 -> 0.32-4)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-www-robotrules (6.02-15 -> 6.02-16)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-html-tagset (3.24-3 -> 3.24-4)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-libwww (6.81-1 -> 6.81-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded mhwd-nvidia-570xx (570.207-1 -> 570.207-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded mhwd-nvidia-575xx (575.64.05-2 -> 575.64.05-3)
[2025-12-23T09:13:25+0200] [ALPM] upgraded mhwd-nvidia (580.119.02-1 -> 580.119.02-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded networkmanager (1.54.2-1 -> 1.54.3-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded networkmanager-vpn-plugin-openvpn (1.12.3-1 -> 1.12.4-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded networkmanager-openvpn (1.12.3-1 -> 1.12.4-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded nvidia-settings (580.119.02-1 -> 580.119.02-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded pamac-cli (11.7.4-1 -> 11.7.4-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-ipc-system-simple (1.30-8 -> 1.30-9)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-file-basedir (0.09-6 -> 0.09-7)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-file-desktopentry (0.22-14 -> 0.22-15)
[2025-12-23T09:13:25+0200] [ALPM] upgraded perl-file-mimeinfo (0.35-3 -> 0.35-4)
[2025-12-23T09:13:25+0200] [ALPM] upgraded python-filelock (3.20.0-1 -> 3.20.0-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded uv (0.9.17-1 -> 0.9.18-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded python-uv (0.9.17-1 -> 0.9.18-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded rtkit (0.13-3 -> 0.14-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded strawberry (1.2.15-1 -> 1.2.16-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded sysstat (12.7.8-1 -> 12.7.9-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded systemd-sysvcompat (258.2-2 -> 258.3-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded xapp (3.2.0-0 -> 3.2.0-2)
[2025-12-23T09:13:25+0200] [ALPM] upgraded timeshift (25.07.7-1 -> 25.12.1-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded unrar (1:7.2.2-1 -> 1:7.2.3-1)
[2025-12-23T09:13:25+0200] [ALPM] upgraded webkit2gtk (2.50.3-1 -> 2.50.4-1)
[2025-12-23T09:13:26+0200] [ALPM] upgraded webkit2gtk-4.1 (2.50.3-1 -> 2.50.4-1)
[2025-12-23T09:13:26+0200] [ALPM] upgraded wxwidgets-common (3.2.9-3 -> 3.2.9-4)
[2025-12-23T09:13:26+0200] [ALPM] upgraded wxwidgets-gtk3 (3.2.9-3 -> 3.2.9-4)
[2025-12-23T09:13:26+0200] [ALPM] upgraded yay (12.5.3-1 -> 12.5.7-1)
There are issues with the Nvidia 580xx series drivers and apparently the 590xx series isn’t expected to be much better. It has been suggested to install the 570xx or 575xx series drivers for the time being.
See the Stable Update 2025-12-15 Announcement:
This is just a guess, but the symptoms you describe may be related.
Thanks @soundofthunder Hope we have a better transition to the 590 series that Arch :slight_smile:
I was going to try the switching between tty’s trick to force it back on, but toggled Display Power Management and adjusted the sleep times in XFCE Power Manager and it seems to have resolved it for now, but I doubt it’s a solution to the issue.
