Hi,
I updated all packages yesterday, and today my external hdmi monitor is not recognized.
I have a Dell G15 laptop.
$ inxi -Fxz ✔
Kernel: 6.3.13-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: GNOME v: 44.5 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Dell G15 5510 v: N/A
serial: <superuser required>
Mobo: Dell model: 0983D5 v: A00 serial: <superuser required> UEFI: Dell
v: 1.5.0 date: 07/02/2021
ID-1: BAT0 charge: 46.3 Wh (100.0%) condition: 46.3/54.9 Wh (84.4%)
volts: 12.5 min: 11.4 model: BYD DELL DVG8M14 status: full
Info: quad core model: Intel Core i5-10200H bits: 64 type: MT MCP
arch: Comet Lake rev: 2 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1837 high: 2400 min/max: 800/4100 cores: 1: 2400 2: 900
3: 900 4: 2400 5: 899 6: 2400 7: 2400 8: 2400 bogomips: 38408
Device-1: Intel Comet Lake-H GT1 [UHD Graphics 610] vendor: Dell
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: N/A arch: Turing bus-ID: 01:00.0
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB
bus-ID: 1-5:3
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1920x1080~120Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT1)
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
API: ALSA v: k6.3.13-2-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.80 status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
IF-ID-1: br-157273287d81 state: down mac: <filter>
IF-ID-2: br-40375c2a675e state: down mac: <filter>
IF-ID-3: br-4302c8813cb1 state: down mac: <filter>
IF-ID-4: br-4f794159031e state: down mac: <filter>
IF-ID-5: br-6024da1c98b3 state: down mac: <filter>
IF-ID-6: br-daea8f93652d state: down mac: <filter>
IF-ID-7: br-dddbd15d5bb1 state: down mac: <filter>
IF-ID-8: docker0 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:4
Local Storage: total: 476.94 GiB used: 335.65 GiB (70.4%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530 NVMe WDC 512GB
size: 476.94 GiB temp: 40.9 C
ID-1: / size: 468.09 GiB used: 335.65 GiB (71.7%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 26 GiB used: 131.2 MiB (0.5%) file: /swapfile
System Temperatures: cpu: 64.0 C pch: 51.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 307 Uptime: 49m Memory: total: 8 GiB note: est.
available: 7.54 GiB used: 5.47 GiB (72.6%) Init: systemd Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: 1754 Shell: Zsh v: 5.9 inxi: 3.3.30
$ xrandr ✔
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 120.21*+ 59.97 59.96 60.21 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
