My hard disk is not detecting what to do it does detected in fdisk -l
I used this command to generate any kind of problems available in external hdd
sudo smartctl --all /dev/sdc
Output:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.14.2-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Elements / My Passport (USB, AF)
Device Model: WDC WD20NMVW-11EDZS7
Serial Number: WD-WX31A8690TTR
LU WWN Device Id: 5 0014ee 20dd84775
Firmware Version: 01.01A01
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue Sep 21 21:10:41 2021 IST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (37020) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 409) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 195 051 Pre-fail Always - 66
3 Spin_Up_Time 0x0027 210 201 021 Pre-fail Always - 4491
4 Start_Stop_Count 0x0032 084 084 000 Old_age Always - 16483
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 071 071 000 Old_age Always - 21577
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 3442
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 205
193 Load_Cycle_Count 0x0032 153 153 000 Old_age Always - 141773
194 Temperature_Celsius 0x0022 121 104 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 4
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 4 occurred at disk power-on lifetime: 2023 hours (84 days + 7 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 61 06 38 4f c2 00
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
e1 d0 06 38 4f c2 00 00 00:35:30.906 IDLE IMMEDIATE
e0 d0 06 38 4f c2 00 00 00:31:16.315 STANDBY IMMEDIATE
e7 d0 06 38 4f c2 00 00 00:31:16.314 FLUSH CACHE
b0 d0 06 38 4f c2 00 00 00:29:43.403 SMART READ DATA
b0 d0 06 38 4f c2 00 00 00:25:43.631 SMART READ DATA
Error 3 occurred at disk power-on lifetime: 2023 hours (84 days + 7 hours)
b0 d0 06 38 4f c2 00 00 00:21:43.859 SMART READ DATA
Error 2 occurred at disk power-on lifetime: 2023 hours (84 days + 7 hours)
b0 d0 06 38 4f c2 00 00 00:17:44.087 SMART READ DATA
Error 1 occurred at disk power-on lifetime: 2023 hours (84 days + 7 hours)
04 61 06 38 4f c2 00 Device Fault; Error: ABRT
ef 90 06 38 4f c2 00 00 00:05:44.879 SET FEATURES [Disable SATA feature]
b0 d0 08 38 4f c2 00 00 00:05:12.802 SMART READ DATA
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Conveyance offline Completed without error 00% 21526 -
# 2 Conveyance offline Completed without error 00% 4294 -
# 3 Conveyance offline Completed without error 00% 3393 -
# 4 Conveyance offline Completed without error 00% 2943 -
# 5 Conveyance offline Completed without error 00% 2052 -
# 6 Conveyance offline Completed without error 00% 1372 -
# 7 Conveyance offline Completed without error 00% 958 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Can anyone help me out and tell me whats going on?
