External Display stuck in splash screen occasionally
I have two external monitors connected to my laptop for a total of three displays. The two external monitors remain stuck in the splash screen during boot sometimes, while the built-in display of the laptop exits the splash screen and shows the login screen. Both external monitors remain in splash even if I log in. This goes away once I reboot. The issue only happens sometimes, and I have not noticed any patterns yet.
I am running a dual boot with Manjaro KDE Plasma + Windows.
inxi
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=a996c710-41d2-4853-9c56-29d80812ba67 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
  Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
  Mobo: HP model: 8575 v: 21.17 serial: <superuser required>
    part-nu: 7NM78PA#ACJ uuid: <superuser required> Firmware: UEFI vendor: AMI
    v: F.27 date: 03/22/2023
  ID-1: BAT0 charge: 32.8 Wh (100%) condition: 32.8/32.8 Wh (100%)
    volts: 12.31 min: 11.4 model: HP Primary type: Li-ion serial: N/A charging:
    status: full cycles: N/A
  Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 900 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
    8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 62431
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
    vendor: Hewlett-Packard driver: nvidia v: 580.105.08
    alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as
    of 2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
    ports: active: DP-2,HDMI-A-2 empty: none bus-ID: 01:00.0
    chip-ID: 10de:1f91 class-ID: 0300
  Device-3: Linux Foundation Multifunction Composite Gadget
    driver: cdc_acm,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 1-1.3:7 chip-ID: 1d6b:0104 class-ID: 0a00
    serial: <filter>
  Device-4: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
    Integrated Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 05c8:03bc class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915,nv_platform,nvidia,nvidia-nvswitch d-rect: 5760x1080
    display-ID: 0
  Monitor-1: DP-2 pos: center model: Dell U2417H serial: <filter>
    built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  Monitor-2: HDMI-A-2 pos: primary,left model: LG (GoldStar) ULTRAGEAR
    serial: <filter> built: 2025 res: mode: 1920x1080 hz: 120 scale: 100% (1)
    dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-3: eDP-1 pos: right model: ChiMei InnoLux 0x1502 built: 2018 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b memory: 15.06 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 2 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: nvidia v: 580.105.08
    device-ID: 10de:1f91 surfaces: N/A
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.4.4:4
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u1u4u4 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.36 TiB used: 209.12 GiB (15.0%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
    tech: SSD serial: <filter> fw-rev: 030 scheme: GPT
  ID-1: / raw-size: 165.65 GiB size: 161.99 GiB (97.79%)
    used: 112.72 GiB (69.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 25.7 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 8 GiB used: 308.1 MiB (3.8%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 75.0 C pch: 76.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2990 fan-2: 2793
  Memory: total: 16 GiB available: 15.43 GiB used: 6.06 GiB (39.3%)
  Processes: 321 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1407 libs: 375 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
journal from a boot with issues:
Dec 15 16:06:03 omen kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Dec 15 16:06:03 omen kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-v>
Dec 15 16:06:03 omen kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admi>
Dec 15 16:06:03 omen kernel: VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXISTS (20240827/dsw>
Dec 15 16:06:03 omen kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20240827/dsw>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXISTS (20240827/dsw>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXISTS (20240827/dsw>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (2024082>
Dec 15 16:06:03 omen kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 15 16:06:03 omen kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 15 16:06:03 omen kernel: blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
Dec 15 16:06:03 omen kernel: blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
Dec 15 16:06:03 omen kernel: blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
Dec 15 16:06:03 omen kernel: blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
Dec 15 16:06:03 omen kernel: ata5.00: Model 'CT1000BX500SSD1', rev 'M6CR030', applying quirks: nolpm
Dec 15 16:06:03 omen kernel: ata5.00: LPM support broken, forcing max_power
Dec 15 16:06:03 omen kernel: nvme nvme0: missing or invalid SUBNQN field.
Dec 15 16:06:03 omen kernel: nvidia: loading out-of-tree module taints kernel.
Dec 15 16:06:03 omen kernel: NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64  580.105.08  Release Build  (root@)
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Dec 15 16:06:04 omen kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
Dec 15 16:06:05 omen kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Dec 15 16:06:06 omen NetworkManager[642]: <warn>  [1765794966.6370] device (p2p-dev-wlo1): error setting IPv4 forwarding to '0': Resource te>
Dec 15 16:06:07 omen kernel: kvm_intel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/do>
Dec 15 16:06:11 omen dbus-broker-launch[640]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedeskt>
Dec 15 16:06:11 omen NetworkManager[642]: ((../NetworkManager/src/libnm-systemd-core/src/libsystemd/sd-event/sd-event.c:4488)): assertion '<>
Dec 15 16:06:26 omen systemd[1]: plymouth-quit.service: start operation timed out. Terminating.
Dec 15 16:06:26 omen systemd[1]: plymouth-quit.service: Failed with result 'timeout'.
Dec 15 16:06:26 omen systemd[1]: Failed to start Terminate Plymouth Boot Screen.
Dec 15 16:06:30 omen sddm[830]: Could not setup default cursor
Dec 15 16:06:30 omen dbus-broker-launch[640]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.>
Dec 15 16:06:30 omen dbus-broker-launch[896]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named a>
Dec 15 16:06:30 omen dbus-broker-launch[896]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bu>
Dec 15 16:06:30 omen dbus-broker-launch[896]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named a>
Dec 15 16:06:33 omen sddm-greeter-qt6[893]: Hunspell dictionary is missing for "en_GB". Search paths QList("/usr/share/qt6/qtvirtualkeyboard>
Dec 15 16:06:44 omen sddm-helper[843]: Signal received: SIGTERM
Dec 15 16:06:44 omen sddm[830]: Error from greeter session: "Process crashed"
Dec 15 16:06:44 omen sddm[830]: Auth: sddm-helper (--socket /tmp/sddm-auth-6a447a2a-d7e6-462f-ae61-cac5e4363a77 --id 2 --start /usr/bin/sddm>
Dec 15 16:06:44 omen sddm[830]: Auth: sddm-helper exited with 1
Dec 15 16:06:44 omen sddm[830]: Signal received: SIGTERM
Dec 15 16:06:44 omen systemd[1]: fstrim.service: Main process exited, code=killed, status=15/TERM
Dec 15 16:06:44 omen systemd[1]: fstrim.service: Failed with result 'signal'.
Dec 15 16:06:44 omen systemd[1]: sys-devices-pci0000:00-0000:00:01.0-0000:01:00.1-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_WA>
Dec 15 16:06:44 omen systemd[1]: sys-devices-pci0000:00-0000:00:1f.3-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_WANTS job, igno>
Dec 15 16:06:44 omen systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for syst>
Dec 15 16:06:45 omen dbus-broker-launch[640]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Dec 15 16:06:45 omen kernel: watchdog: watchdog0: watchdog did not stop!
I noticed this in the journalctl logs:
Have you tried to remove plymouth? Have you tried an older Nvidia driver? 580-version is still a bit buggy.
