Hi, I installed latest Manjaro KDE on ThinkPad W520. Specs: i7-2720qm and NVidia Quadro 2000M. Open source drivers with nouveau work on intel and nvidia GPUs but external display has tearing and artifacts with some context menus. If i set it to nvidia-390xx only external display works if plugged on boot but laptop’s internal display stays black. With video-hybrid-intel-nvidia-390xx-bumblebee internal display works but nvidia-settings gives X server error and no output on external display regardless of it being plugged on boot. I noticed that on switchable driver nothing is loaded on lsmod. My gpu works without nox2apic and for testing I installed x11 instead of using Wayland. I read online that PRIME is incompatible for 390xx drivers. I am more on newbie side.
Welcome to the Manjaro community @NIPro
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
- inxi man pages (Arch Manual)
Running `inxi` in `chroot`
Required reading
Resources
Note that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions: ![]()
[MiniHowTo] Present code or command output
Note: Grave accent (or, backtick) characters are used. ![]()
- for example, typing: `code here` will display the text as
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
Inxi:
Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=81fe24ac-28bf-487d-b710-28177b8adda1 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 428424G v: ThinkPad W520
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 428424G serial: <filter>
uuid: 81148001-50b8-11cb-b81d-80016cf77b8c Firmware: UEFI vendor: LENOVO
v: 8BET63WW (1.43 ) date: 10/20/2016
ID-1: BAT0 charge: 9.9 Wh (11.7%) condition: 84.7/94 Wh (90.1%)
power: 37.3 W volts: 10.96 min: 10.8 model: Panasonic 42T4801 type: Li-ion
serial: <filter> charging: status: charging control: start: 0% end: 100%
cycles: N/A
System RAM: total: 16 GiB available: 15.44 GiB used: 2.61 GiB (16.9%)
igpu: 128 MiB
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMSO4GX3M1A1333C9 serial: N/A
Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
manufacturer: Kingston part-no: 9905428-051.A00LF serial: <filter>
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
Slot: 1 type: PCIe status: available info: ExpressCard length: other
bus-ID: 00:00.0
Slot: N/A type: MediaCard status: available length: other bus-ID: 00:00.0
Info: model: Intel Core i7-2720QM bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3300 base/boost: 2200/2200 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 35087
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: NVIDIA GF106GLM [Quadro 2000M] vendor: Lenovo driver: nouveau
v: kernel alternate: nova_core non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s ports:
active: none empty: DP-1, DP-2, DP-3, LVDS-2, VGA-2 bus-ID: 01:00.0
chip-ID: 10de:0dda class-ID: 0300 temp: 33.0 C
Device-3: Chicony Lenovo Integrated Camera (0.3MP) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6:4
chip-ID: 04f2:b217 class-ID: 0e02
Display: unspecified server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus,nouveau gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: LVDS-1 model: Lenovo 0x40b2 built: 2009 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.678 y: 0.314
green: x: 0.216 y: 0.667 blue: x: 0.141 y: 0.067 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: crocus device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 25.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) device-ID: 8086:0126 memory: 1.46 GiB unified: yes
x11: xdpyinfo, xprop, xrandr
vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.1 chip-ID: 10de:0be9
class-ID: 0403
API: ALSA v: k6.18.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:4238
class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
Device-1: Broadcom BCM2045B (BDC-2.1) driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4:7
chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 232.89 GiB used: 9.81 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT33N rev: LT23
dev-links: cdrom
ID-1: / raw-size: 81.12 GiB size: 79.29 GiB (97.75%) used: 9.81 GiB (12.4%)
fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 81fe24ac-28bf-487d-b710-28177b8adda1
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 2.4 MiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda4 maj-min: 8:4
label: N/A uuid: E8DC-ACFC
ID-1: swap-1 type: partition size: 21.35 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4790a6f9-ca88-4fd8-8c36-89f8d31efe25
ID-1: /dev/sda3 maj-min: 8:3 size: 74.5 GiB fs: ntfs label: N/A
uuid: 4574817F17E19C14
ID-2: /dev/sda5 maj-min: 8:5 size: 13.97 GiB fs: ext4 label: N/A
uuid: 78f52145-bf4b-48c8-a860-54bc043bbfbf
ID-3: /dev/sda7 maj-min: 8:7 size: 40.94 GiB fs: ext4 label: N/A
uuid: e3f168a0-c02c-48b2-b180-8fd4b3f5c13e
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 2-1.4:7 info: Broadcom BCM2045B (BDC-2.1) type: bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Device-2: 2-1.6:4 info: Chicony Lenovo Integrated Camera (0.3MP)
type: video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
Hub-4: 3-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-5: 4-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 34.0 C
Fan Speeds (rpm): cpu: 1975
Packages: pm: pacman pkgs: 1240 libs: 336 tools: pamac pm: flatpak pkgs: 0
1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 245
1: cpu: 100% command: ps pid: 3321 mem: 3.94 MiB (0.0%)
2: cpu: 17.7% command: firefox pid: 1200 mem: 610.3 MiB (3.8%)
3: cpu: 8.6% command: firefox pid: 2166 mem: 270.8 MiB (1.7%)
4: cpu: 4.0% command: Xorg pid: 624 mem: 89.0 MiB (0.5%)
5: cpu: 3.9% command: kwin_x11 pid: 860 mem: 164.9 MiB (1.0%)
Memory top: 5 of 245
1: mem: 610.3 MiB (3.8%) command: firefox pid: 1200 cpu: 17.7%
2: mem: 370.1 MiB (2.3%) command: plasmashell pid: 892 cpu: 1.7%
3: mem: 282.3 MiB (1.7%) command: firefox pid: 1957 cpu: 1.0%
4: mem: 270.8 MiB (1.7%) command: firefox pid: 2166 cpu: 8.6%
5: mem: 202.0 MiB (1.2%) command: firefox pid: 2475 cpu: 0.7%
Processes: 245 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2 default: Bash
v: 5.3.9 running-in: konsole inxi: 3.3.40
