Hello,
I got recently two external USB 3.0 hdd drive, which are not accessible in any way.
They show up at the bios, when i connect them straight via scsi-cable, but dont work after booting. I can connect/ disconnect them via USB, it shows up at inxi, but i can not access them with fdisk or gparted.
It gives the error “no matching device or no matching adress found”
I did connect them Windows 7(!), it recognize it, format it after a while with exFat and its there and accessible. But with Linux it still does not show up.
What is the difference there, that an old Windows system can automatically integrate newer hardware, but Linux can not do that.
The brand from the drive is an "Caraele 2.5 hdd 1TB.
Inside seems is a Samsung or Seagate ST1000LM024 with an Puya P25D21H 2Mbit EEPROM and a Initio inic3639PN chip.
I have now one USB-hdd, what is formated under Windows with exFat and one untouched.
Is there a way, that they can be found with Linux, before i do another try by formating it with NTFS.
Inxi -Db
Host: oli Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: GA-890GPA-UD3H serial: N/A
BIOS: Award v: FF date: 11/24/2010
Info: 6-core AMD Phenom II X6 1090T [MCP] speed (MHz): avg: 1333
min/max: 800/3200
Device-1: NVIDIA GM206 [GeForce GTX 960] driver: nvidia v: 470.94
Device-2: Logitech type: USB driver: snd-usb-audio,uvcvideo
Display: server: X.Org 1.21.1.2 driver: loaded: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2
v: 4.6.0 NVIDIA 470.94
driver: r8169
Local Storage: total: 2.05 TiB used: 536 GiB (25.6%)
ID-1: /dev/sda vendor: Seagate model: ST31000524AS size: 931.51 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 840 EVO 250GB
ID-3: /dev/sdc type: USB vendor: Seagate model: ST1000LM024
Processes: 244 Uptime: 10m Memory: 15.62 GiB used: 3.07 GiB (19.7%)
Shell: Bash inxi: 3.3.11
