Manjaro forum doesn’t let me put pics or links in my post (maybe because I just made an account) so I have to do something like this, just delete blank spaces: imgur . com/a/mo3MKsV
Hello! Since gnome 40 update my extension window always opens on left monitor (my primary monitor is on the right) and top left corner, just like in the screenshot (my secondary display is smaller than the primary one so it cuts off most of the window). This placement makes using extension app very annoying. Disabling second monitor seems to work but I want to use it. If I switch placement of monitor in settings it seems to work just fine and extension window opens on my primary display but physically I have my primary monitor on my right side so I don’t want to do that.
It seems that gnome defaults extensions window to the top left corner of left monitor. Settings of extensions open on the same place too, so even if I drag extension window to my primary monitor I have to drag more windows if I want to tweak something.
Ideally I want 1) extension app to open on my primary (right) monitor and 2) extension app to open in the centre of the monitor, not top left (I have center new window turned on in tweaks app). However, I feel like 1) is much more annoying than 2) so fixing it is more important for me. Thanks for your help!
