General description
I installed a fresh Manjaro install (encrypted system with swap, everything else is left on default).
After some (~4) reboots this happened:
$ journalctl | grep error
Okt 19 08:07:46 firefly kernel: EXT4-fs error (device dm-0) in ext4_free_inode:360: Corrupt filesystem
Okt 19 08:07:54 firefly kernel: EXT4-fs (dm-0): Delayed block allocation failed for inode 21532154 at logical offset 0 with max blocks 3 with error 117
Okt 19 08:07:55 firefly NetworkManager[630]: <warn> [1634623675.2781] dhcp4 (wlp1s0): error saving lease to /var/lib/NetworkManager/internal-bfccb1eb-5b95-46ab-ad25-75fff87881f4-wlp1s0.lease: Failed to write file “/var/lib/NetworkManager/internal-bfccb1eb-5b95-46ab-ad25-75fff87881f4-wlp1s0.lease.Y4ACB1”: fsync() failed: Structure needs cleaning
Generally the system is unusable, e.g. vim fails to save a file with fsync failed, I have to reconfigure the KDE wallet on startup, or Firefox settings are partially reset.
System information
It is a Acer swift notebook, the specs are in my profile.
I can add my current installed packages if wanted (dont’t want this to become to long)
Disk layout
[moanos@firefly ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 953,9G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
├─nvme0n1p2 259:2 0 937G 0 part
│ └─luks-6870dd62-ec17-4dcd-be06-836f830c9597 254:0 0 937G 0 crypt /run/timeshift/backup
└─nvme0n1p3 259:3 0 16,6G 0 part
└─luks-e0e79f4f-8569-4c2b-9b6a-d1fe941c31d9 254:1 0 16,6G 0 crypt [SWAP]
[moanos@firefly ~]$ df -h
Filesystem Size Used Avail Use% Mounted on
dev 7,5G 0 7,5G 0% /dev
run 7,6G 1,6M 7,6G 1% /run
/dev/dm-0 922G 520G 355G 60% /
tmpfs 7,6G 92M 7,5G 2% /dev/shm
/dev/nvme0n1p1 300M 448K 299M 1% /boot/efi
tmpfs 7,6G 53M 7,5G 1% /tmp
tmpfs 1,6G 88K 1,6G 1% /run/user/1000
History
I had the same problem with this computer before. That is why I let the SSD change, it is currently brand new.
Debugging attempts
(will try to update this if you have suggestions on what to try)
Smart
Smart values are fine
FSCK
Inodes get repaired on startup, problem stays
Searching for similar problems
I read an old forum post here and deinstalled spotify. (Can’t link, sorry)
