I have spent an hour or more trying to install ExpressVPN. I keep going through the install process via the terminal & get the following error each time:
error: Cannot find the fakeroot binary . error making: expressvpn
hm… i would rather say, install it, when it is not there?
pamac install fakeroot
But anyway… AUR packages are made mainly for ArchLinux. Manjaro is based on ArchLinux and many things works, but sometimes the dependencies are different.
Why not use OpenVPN files…?
Ok, you have to do the import for every country/server, but after that, it is much easier to use directly from your LAN connection.
