Everything freezes for ~40 seconds when opening "enter edit mode" / "spectacle" / "compositor" [ system kwin_x11[935]: Could not get Interfaces ]
Hello,
So a year ago, I suddenly noticed that whenever I try to edit the taskbar from “enter edit mode” the laptop freezes excluding the cursor. But as I don’t enter into edit mode often, I didn’t bother with that.
But last week, the same thing happened for Spectacle, the screenshot-taking app, after a system upgrade. As I use spectacle frequently, now I’m worried. Cause, when it freezes it takes nearly 30-50 seconds to recover and start the desired app.
I also noticed that the same thing happens when I open “compositor” from settings.
I’m giving all the information I can. Please tell me if I have to add more.
inxi --admin --verbosity=7 --filter --width
  Kernel: 6.1.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=97fdd153-9839-4383-a792-0cd6da7fefe7 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: TravelMate P449-G2-M v: V1.09
  Mobo: Acer model: Pavo_Grus_SK v: V1.09 serial: <superuser required>
    UEFI-[Legacy]: Insyde v: 1.09 date: 01/29/2018
  ID-1: BAT0 charge: 26.3 Wh (68.0%) condition: 38.7/48.3 Wh (80.2%)
    volts: 15.5 min: 15.2 model: AC14B8K type: Li-ion serial: N/A
    status: discharging
  System RAM: available: 7.62 GiB used: 2.47 GiB (32.4%)
  Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 799 high: 802 min/max: 400/3100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 802 2: 800 3: 794 4: 800
    bogomips: 21607
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: Chicony HD WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:6 chip-ID: 04f2:b577
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting unloaded: vesa alternate: fbdev dri: iris gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14c3 built: 2015 res: 1366x768
    hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: 1366x768
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel HD Graphics 620 (KBL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.1.29-1-MANJARO status: kernel-api with: 1: aoss
    type: oss-emulator 2: apulse type: pulse-emulator
  Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-LM vendor: Acer Incorporated ALI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0a2a
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 238.47 GiB used: 200.51 GiB (84.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW256G7
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: PSF121C temp: 18.9 C
    scheme: GPT
  ID-1: / raw-size: 50.51 GiB size: 49.42 GiB (97.83%) used: 33.26 GiB (67.3%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 97fdd153-9839-4383-a792-0cd6da7fefe7
  ID-2: /home raw-size: 42.97 GiB size: 42.12 GiB (98.02%)
    used: 29.18 GiB (69.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 8ee8fa3c-f277-48ee-b6d1-265e6dd29710
  ID-3: /run/media/ovi/storage raw-size: 144.99 GiB
    size: 144.99 GiB (100.00%) used: 138.06 GiB (95.2%) fs: ntfs
    dev: /dev/nvme0n1p5 maj-min: 259:3 label: storage uuid: CC7675037674F016
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-2.1:4 info: Alcor Micro AU9540 Smartcard Reader
    type: smart card driver: N/A interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 50mA
    chip-ID: 058f:9540 class-ID: 0b00
  Device-2: 1-5:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Device-3: 1-6:5 info: LighTuning EgisTec Touch Fingerprint Sensor
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 1c7a:0570 class-ID: 0000 serial: <filter>
  Device-4: 1-7:6 info: Chicony HD WebCam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b577 class-ID: 0e02
  Device-5: 1-8:7 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 45.0 C pch: 37.5 C mobo: N/A
  Processes: 209 Uptime: 22m wakeups: 45128 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1761 pm: pacman pkgs: 1727 libs: 445 tools: pamac,trizen,yay
  pm: flatpak pkgs: 18 pm: snap pkgs: 16 Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.27
mhwd -li -d
   ATTACHED:    PCI
   VERSION:     2020.01.13
   INFO:        X.org modesetting video driver.
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   INFO:        X.org vesa video driver.
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2018.05.04
   INFO:        Standard open source drivers.
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300 0380 0302
   VENDORIDS:   1002 8086 10de
mhwd -l
> 0000:00:02.0 (0300:8086:5916) Display controller Intel Corporation:
           video-linux            2018.05.04                true            PCI
journalctl for spectacle
May 27 16:35:32 system kstart5[1835]: Omitting both --window and --windowclass arguments is not recommended
May 27 16:35:32 system dbus-daemon[865]: [session uid=1000 pid=865] Activating via systemd: service name='org.kde.Spectacle' unit='app-org.kde.spectacle.service' requested by ':1.69' (uid=1000 pid=1844 comm="/usr/bin/qdbus org.kde.Spectacle / RectangularRegi")
May 27 16:35:32 system systemd[840]: Starting Spectacle screenshot capture utility...
May 27 16:35:32 system systemd[840]: Started /usr/bin/qdbus.
May 27 16:35:33 system dbus-daemon[865]: [session uid=1000 pid=865] Successfully activated service 'org.kde.Spectacle'
May 27 16:35:33 system systemd[840]: Started Spectacle screenshot capture utility.
May 27 16:35:58 system kwin_x11[935]: Could not get Interfaces.  "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 27 16:36:05 system kioslave5[1243]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
journalctl for edit mode
May 27 16:45:14 system kwin_x11[935]: Could not get Interfaces.  "No such object path '/org/a11y/atspi/null'"
May 27 16:45:15 system kwin_x11[935]: Could not get Interfaces.  "No such object path '/org/a11y/atspi/null'"
May 27 16:45:16 system kwin_x11[935]: Could not get Interfaces.  "No such object path '/org/a11y/atspi/null'"
May 27 16:45:16 system plasmashell[986]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:310:17: QML SpinBox: Binding loop detected for property "implicitWidth"
May 27 16:45:16 system plasmashell[986]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:302:17: QML Heading: Binding loop detected for property "verticalAlignment"
May 27 16:45:16 system plasmashell[986]: QQmlComponent: Component is not ready
May 27 16:45:16 system plasmashell[986]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
May 27 16:45:16 system plasmashell[986]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/panelconfiguration/ToolBar.qml:284:9: QML SpinBox: Binding loop detected for property "implicitWidth"
May 27 16:45:41 system kwin_x11[935]: Could not get Interfaces.  "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 27 16:46:06 system kwin_x11[935]: Could not get Interfaces.  "No such object path '/org/a11y/atspi/accessible/2147485804'"
May 27 16:46:06 system kwin_x11[935]: kwin_core: XCB error: 152 (BadDamage), sequence: 16386, resource id: 16784192, major code: 143 (DAMAGE), minor code: 3 (Subtract)
May 27 16:46:26 system plasmashell[986]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
May 27 16:46:26 system systemd[840]: Started Kate - Advanced Text Editor.
May 27 16:46:27 system kate[2281]: kf.sonnet.core: No language dictionaries for the language: "en_US"
May 27 16:46:43 system kwin_x11[935]: kwin_core: XCB error: 3 (BadWindow), sequence: 22130, resource id: 16784592, major code: 129 (SHAPE), minor code: 6 (Input)
May 27 16:46:43 system kate[2281]: qt.accessibility.atspi: WARNING Qt AtSpiAdaptor: Accessible invalid:  QAccessibleInterface(0x556541edffd0 invalid) "/org/a11y/atspi/accessible/2147483841"
May 27 16:46:43 system kwin_x11[935]: Could not get Interfaces.  "No such object path '/org/a11y/atspi/accessible/2147483841'"
May 27 16:46:43 system systemd[840]: app-org.kde.kate-78cbfb56c85b469ebfe1db018746f263.scope: Consumed 1.876s CPU time.
journalctl for compositor
May 27 16:40:26 system kwin_x11[935]: Could not get Interfaces.  "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 27 16:40:52 system kwin_x11[935]: Could not get Interfaces.  "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 27 16:40:53 system systemsettings[2055]: qml: The item SubCategoryPage_QMLTYPE_114(0x55ca6b7708d0) is already in the PageRow
May 27 16:41:23 system kioslave5[2107]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
May 27 16:41:26 system plasmashell[986]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
May 27 16:41:26 system systemd[840]: Started Kate - Advanced Text Editor.
May 27 16:41:26 system kate[1883]: kf.sonnet.core: No language dictionaries for the language: "en_US"
May 27 16:41:58 system kate[1883]: kf.sonnet.core: No language dictionaries for the language: "en_US"
May 27 16:42:17 system kate[1883]: kf.sonnet.core: No language dictionaries for the language: "en_US"
I can see a common log: system kwin_x11[935]: Could not get Interfaces. . I tried searching with it, but couldn’t get anything.
Thank you.
UPD-1: If I disable the compositor by shift + alt + F12 everything works like a charm. So the issue is in the compositor? How do I fix it?
UPD-2: I also tried opening “enter edit mode” while running dbus-monitor in the terminal. it gave me the following output. (of course, I used it enabling the compositor)
dbus-monitor
dbus-monitor
signal time=1685283810.871414 sender=org.freedesktop.DBus -> destination=:1.157 serial=2 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameAcquired
   string ":1.157"
signal time=1685283810.871511 sender=org.freedesktop.DBus -> destination=:1.157 serial=4 path=/org/freedesktop/DBus; interface=org.freedesktop.DBus; member=NameLost
   string ":1.157"
method call time=1685283814.267584 sender=:1.17 -> destination=org.kde.KWin serial=3973 path=/VirtualKeyboard; interface=org.kde.kwin.VirtualKeyboard; member=willShowOnActive
error time=1685283814.268048 sender=:1.12 -> destination=:1.17 error_name=org.freedesktop.DBus.Error.UnknownObject reply_serial=3973
   string "No such object path '/VirtualKeyboard'"
method call time=1685283814.496780 sender=:1.17 -> destination=org.kde.KWin serial=3974 path=/KWin; interface=org.freedesktop.DBus.Properties; member=Get
   string "org.kde.KWin"
   string "showingDesktop"
signal time=1685283814.496823 sender=:1.12 -> destination=(null destination) serial=1438 path=/KWin; interface=org.kde.KWin; member=showingDesktopChanged
   boolean true
signal time=1685283819.250381 sender=:1.24 -> destination=(null destination) serial=779 path=/org/kde/Solid/PowerManagement; interface=org.kde.Solid.PowerManagement; member=batteryRemainingTimeChanged
   uint64 16654000
signal time=1685283819.250584 sender=:1.24 -> destination=(null destination) serial=780 path=/org/kde/Solid/PowerManagement; interface=org.kde.Solid.PowerManagement; member=smoothedBatteryRemainingTimeChanged
   uint64 17010344
method call time=1685283839.158603 sender=:1.17 -> destination=org.kde.KWin serial=3975 path=/KWin; interface=org.freedesktop.DBus.Properties; member=Get
signal time=1685283849.309925 sender=:1.24 -> destination=(null destination) serial=781 path=/org/kde/Solid/PowerManagement; interface=org.kde.Solid.PowerManagement; member=batteryRemainingTimeChanged
   uint64 18172000
signal time=1685283849.310006 sender=:1.24 -> destination=(null destination) serial=782 path=/org/kde/Solid/PowerManagement; interface=org.kde.Solid.PowerManagement; member=smoothedBatteryRemainingTimeChanged
   uint64 17067188
method return time=1685283864.240650 sender=:1.12 -> destination=:1.17 serial=1439 reply_serial=3974
   variant       boolean true
method return time=1685283864.260779 sender=:1.12 -> destination=:1.17 serial=1440 reply_serial=3975
method call time=1685283868.228196 sender=:1.17 -> destination=org.kde.KWin serial=3976 path=/KWin; interface=org.freedesktop.DBus.Properties; member=Get
signal time=1685283868.237023 sender=:1.12 -> destination=(null destination) serial=1441 path=/KWin; interface=org.kde.KWin; member=showingDesktopChanged
   boolean false
method return time=1685283868.246123 sender=:1.12 -> destination=:1.17 serial=1442 reply_serial=3976
   variant       boolean false
method call time=1685283868.271891 sender=:1.17 -> destination=org.kde.KWin serial=3977 path=/KWin; interface=org.freedesktop.DBus.Properties; member=Get
method return time=1685283868.315153 sender=:1.12 -> destination=:1.17 serial=1443 reply_serial=3977
Hey I’m having the same issue, @a_0vi did you figure out how to fix it?
The full line:
kwin_wayland[1630]: org.kde.qaccessibilityclient: Could not get Interfaces. "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Edit: Thanks, your logs helped and I fixed my issue :smiley:
I’m really sorry for the late reply.
I didn’t find any solutions…I’m dealing the problem by disabling the compositor. So I can’t enjoy any animations as well.
How did you find the solution btw? Plz share, If It gives solution to my problem then I can mark your response as a solution.
Thank you.
I deleted kwinrc in ~/.config and restarted, that fixed it. Hope it works for you too!
After restarting, the compositor, which was previously been disable, was enabled automatically.
So the animations were enabled, spectacle didn’t freeze, enter mode didn’t as well. (It also fixed chrome menu problem I was having for a long time ) :hugs:
But after I tried to disable the compositor again, everything freezed. And wouldn’t restore so I had to restart. So if I keep the compositor enabled, everything works fine now. So this is the solution I guess.
Thank you very much.
