Every time I open terminal 'bash: 0: command not found' is displayed twice
Everytime i open a terminal i get the mentioned error.
I traced to to this line in my .bashrc (the default .bashrc file)
[ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
sure enough, when i execute that file, i get two instances of the error.
is this a known issue? my bash completion seems to work fine, so i don’t think this is a huge error.
Remove that and replace it with:
# enable bash completion in interactive shells
if ! shopt -oq posix; then
  if [ -f /usr/share/bash-completion.d/bash_completion.bash ]; then
    . /usr/share/bash-completion/bash_completion.bash
  elif [ -f /etc/bash_completion.d ]; then
    . /etc/bash_completion.d
  fi
fi
interesting, now when i do
source .bashrc
i get no error, yay!
however, upon opening new terminals i still get the bash: 0: command not found x2
Apparently you have a typo somewhere in your .bashrc. Possibly an extra space before a 0? Possibly twice? Or something isn’t quoted or escaped properly.
More likely:
https://stackoverflow.com/questions/35664648/bash-if-variable-then-returns-0-command-not-found
but they aren’t “my” files, they are the ones already on the system by default… i have no idea what to edit, the bash_completion is really long.
and the issue is in the bash_completion file, that is the one that spits the error.
e.g.
$ . /usr/share/bash-completion/bash_completion
They are now since it’s in your ~/ folder and you did just edit it. :wink:
This is the original that was copied there:
https://gitlab.manjaro.org/packages/core/bash/-/raw/master/dot.bashrc
If there’s a problem with our default Bash settings, we’d like to fix it.
❯ bash
:man_shrugging:
lol, touche.
i thought that’s what i was doing here, but im confused now!
where is the original bash_completion file?
That belongs to the bash-completion package which is imported from the Arch extra repo and is not modified in any way. I don’t think there’s anything wrong with it.
Do you use Timeshift? I have snapshots of .bashrc and .zshrc going back a few months… just saying :wink:
If you ever have a problem with .bashrc, browse your timeshift/snapshot folder and look for an older version and use something to compare them (I use meld).
What happens if you do mv .bashrc bashrc.BAD and then quit and open a new terminal?
thanks, good suggestion.
this happened out of the box, i installed manjaro yesterday morning.
ok, i believe i tracked down the source of the issue.
this file, /etc/bash.bashrc has the same ‘erroneous’ line as the default .bashrc file. (i.e. [ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
I replaced that line with this (as per @Yochanan suggestion above):
  fi
fi
I no longer receive bash: 0: command not found when opening terminals anymore.
Not sure if this issue is entirely resolved, as bash_completion still results in errors. but it seems that file does not get used anymore with the code snippets applied.
For me the problem appear after installing nvm.
So in my case I had a hidden file in root dir .bashrc. At the end of the file I had 2 lines
‘source /usr/share/nvm/init-nvm.sh’
So after i delete that 2 lines everything came back to normal. I hope this helps.
** None of the above solutions worked for me.
