Every package ie "invalid or corrupted"
Latest KDE ISO from the website (manjaro-kde-21.1.5-211008-linux513.iso), directly after booting: Whatever you do in the package manager (the graphical one or pacman in console), be it updating or installing a new package, will not work due to some issue with signatures. It will just report every single package as “invalid or corrupted”. Tried to find a solution for 30 min, none that I found worked. Thought I’d look for the solution here, but couldn’t find any report of this issue. I just assumed that you are aware of this, as this is a pretty big issue for a stable ISO? I thought I’d report it here anyway, just in case.
seems that your kernel is outdated. please post the output of uname -a first.
As I said, this is literally directly after booting the official Live ISO! The kernel version is whatever it is on that ISO.
that’s curious, you’re sure that this iso is a original ? in case to make sure to download again and create a new live-iso. booting with a live-iso with that errors are not common.
@fladd
Consider to use a bit more fresh ISOs linked in the [Stable Update] 2021-10-16 - Haskell, Python, KDE Gear, KDE Framework, Thunderbird - #3 by philm
It is official.
It is a rare case, but to be sure after download consider to check hash sums of your downloaded image(s) to be 100% sure that the ISO file(s) came undamaged.
Also, directly after you load your installed copy consider to get a fresh servers mirrors to to get updates from:
sudo pacman-mirrors -B stable -a -c Sweden -P https
or use any other country checked in the stable column of the https://repo.manjaro.org/
May be that time you will be more lucky :wink:
Downloaded it again, verified the SHA1 signature. Same thing. Here is a screen capture of the bug starting from boot https://imgur.com/HzlaRc9
I found that conclusion to be a strange one: if nobody talks about an issue, than it is a well-known.
Well, I just figured that Manjaro is a pretty well known distro, and that when one of the main stable ISOs is having a significant issue that more people would recognize this (and then maybe report it) :slight_smile:
Do not want to use the latest ISO?
I assumed that the ISO on the official download page is the latest, but apparently that was not the case. Well, I tried the ISO from the forum link you posted, but the issue is the same.
or someone is again giving information that are misleading. i cannot believe that a live distro is so corrupted.
WHAT are you doing ? Booting from a live-iso or installing from it ? Please give exact and precise information !
I am booting from a Live ISO, as you can clearly see in my screen capture. But nevermind. I just wanted to report this for the Manjaro devs actually, as I thought this was a pretty obvious thing they might want to fix in their official ISO. I think I myself won’t proceed with Manjaro, so please deal with this information as you want. Good luck.
@fladd
It’s a bit not fear: “by my heavy blurred pictures I pointed you that something not works”.
The case obviously needs more info. To note that general info and to quit is not a bug report or case investigation. If you want to help yourself and to support the project to prevent that - probably unique - cases, please consider to come back to provide more info (I do not know what exactly, I think you will be asked by more skilled members).
Thanks!
The user points to the issue while update. A couple of key frames could be are
Sorry for the quality, it is best from the uploaded video.
I got the manjaro-kde-21.1.6-211016-linux513.iso and tried to reproduce.
No luck: update procedure worked for me.
details
$ pacman -Qi virtualbox | grep Ver
Version         : 6.1.26-1
Made no any actions. just went directly to the pacmac’s update tab and hit the button:
Pamac’s log (copied from it’s GUI):
Preparing...
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/core/x86_64/core.db: Error 404
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/extra.db: Error 404
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/community/x86_64/community.db: Error 404
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/multilib/x86_64/multilib.db: Error 404
Resolving dependencies...
Checking inter-conflicts...
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/calamares-3.2.44.3-1-x86_64.pkg.tar.zst: Error 404
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/libpamac-11.1.3-1-x86_64.pkg.tar.zst: Error 404
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/libpamac-snap-plugin-11.1.3-1-x86_64.pkg.tar.zst: Error 404
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/libpamac-flatpak-plugin-11.1.3-1-x86_64.pkg.tar.zst: Error 404
Download of calamares (3.2.44.3-1) started
Download of libpamac (11.1.3-1) started
Download of libpamac (11.1.3-1) finished
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/manjaro-settings-manager-kcm-0.5.6-20-x86_64.pkg.tar.zst: Error 404
Download of libpamac-flatpak-plugin (11.1.3-1) started
Download of libpamac-flatpak-plugin (11.1.3-1) finished
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/pamac-cli-10.2.2-5-x86_64.pkg.tar.zst: Error 404
Download of manjaro-settings-manager-kcm (0.5.6-20) started
Download of calamares (3.2.44.3-1) finished
http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/extra/x86_64/pamac-gtk-10.2.2-5-x86_64.pkg.tar.zst: Error 404
Download of libpamac-snap-plugin (11.1.3-1) started
Download of libpamac-snap-plugin (11.1.3-1) finished
Download of pamac-cli (10.2.2-5) started
Download of pamac-cli (10.2.2-5) finished
Download of pamac-gtk (10.2.2-5) started
Download of pamac-gtk (10.2.2-5) finished
Download of manjaro-settings-manager-kcm (0.5.6-20) finished
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap because system is booted in Live CD mode...
Upgrading calamares (3.2.44-3 -> 3.2.44.3-1)...
Upgrading libpamac (11.1.1-1 -> 11.1.3-1)...
Upgrading libpamac-flatpak-plugin (11.1.1-1 -> 11.1.3-1)...
Upgrading libpamac-snap-plugin (11.1.1-1 -> 11.1.3-1)...
Upgrading manjaro-settings-manager-kcm (0.5.6-16 -> 0.5.6-20)...
Upgrading pamac-cli (10.2.2-1 -> 10.2.2-5)...
Upgrading pamac-gtk (10.2.2-1 -> 10.2.2-5)...
Reloading system manager configuration...
Arming ConditionNeedsUpdate...
Refreshing PackageKit...
Reloading system bus configuration...
Updating icon theme caches...
Updating the desktop file MIME type cache...
Updating the MIME type database...
$ cat /var/log/pacman.log
[2021-10-20T22:11:56+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -Sy virtualbox-guest-utils xf86-video-vmware open-vm-tools xf86-input-vmmouse spice-vdagent qemu-guest-agent gtkmm3'
[2021-10-20T22:11:56+0000] [PACMAN] synchronizing package lists
[2021-10-20T22:11:57+0000] [ALPM] transaction started
[2021-10-20T22:11:57+0000] [ALPM] installed xf86-video-vmware (13.3.0-2)
[2021-10-20T22:11:57+0000] [ALPM] installed virtualbox-guest-utils (6.1.26-1)
[2021-10-20T22:11:57+0000] [ALPM] installed libdnet (1.12-13)
[2021-10-20T22:11:57+0000] [ALPM] installed libmspack (1:0.10.1alpha-3)
[2021-10-20T22:11:57+0000] [ALPM] installed uriparser (0.9.4-1)
[2021-10-20T22:11:57+0000] [ALPM] installed gdk-pixbuf-xlib (2.40.2-1)
[2021-10-20T22:11:57+0000] [ALPM] installed open-vm-tools (6:11.3.5-1)
[2021-10-20T22:11:57+0000] [ALPM] installed xf86-input-vmmouse (13.1.0-5)
[2021-10-20T22:11:57+0000] [ALPM] installed spice-vdagent (0.21.0-1)
[2021-10-20T22:11:57+0000] [ALPM] installed qemu-guest-agent (6.1.0-2)
[2021-10-20T22:12:07+0000] [ALPM] transaction completed
[2021-10-20T22:12:07+0000] [ALPM] running '20-systemd-sysusers.hook'...
[2021-10-20T22:12:07+0000] [ALPM-SCRIPTLET] Creating group vboxsf with gid 109.
[2021-10-20T22:12:07+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-10-20T22:12:08+0000] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-10-20T22:12:08+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-10-20T22:12:08+0000] [ALPM] running '30-systemd-update.hook'...
[2021-10-20T22:12:08+0000] [ALPM] running '90-packagekit-refresh.hook'...
[2021-10-20T22:12:10+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -D --asexplicit virtualbox-guest-utils xf86-video-vmware open-vm-tools xf86-input-vmmouse spice-vdagent qemu-guest-agent gtkmm3'
[2021-10-20T22:14:39+0000] [PAMAC] synchronizing package lists
[2021-10-20T22:14:59+0000] [ALPM] running '00-timeshift-autosnap.hook'...
[2021-10-20T22:14:59+0000] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap because system is booted in Live CD mode...
[2021-10-20T22:14:59+0000] [ALPM] transaction started
[2021-10-20T22:14:59+0000] [ALPM] upgraded calamares (3.2.44-3 -> 3.2.44.3-1)
[2021-10-20T22:14:59+0000] [ALPM] upgraded libpamac (11.1.1-1 -> 11.1.3-1)
[2021-10-20T22:14:59+0000] [ALPM] upgraded libpamac-flatpak-plugin (11.1.1-1 -> 11.1.3-1)
[2021-10-20T22:15:00+0000] [ALPM] upgraded libpamac-snap-plugin (11.1.1-1 -> 11.1.3-1)
[2021-10-20T22:15:00+0000] [ALPM] upgraded manjaro-settings-manager-kcm (0.5.6-16 -> 0.5.6-20)
[2021-10-20T22:15:00+0000] [ALPM] upgraded pamac-cli (10.2.2-1 -> 10.2.2-5)
[2021-10-20T22:15:00+0000] [ALPM] upgraded pamac-gtk (10.2.2-1 -> 10.2.2-5)
[2021-10-20T22:15:00+0000] [ALPM] transaction completed
[2021-10-20T22:15:00+0000] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-10-20T22:15:01+0000] [ALPM] running '30-systemd-update.hook'...
[2021-10-20T22:15:01+0000] [ALPM] running '90-packagekit-refresh.hook'...
[2021-10-20T22:15:01+0000] [ALPM] running 'dbus-reload.hook'...
[2021-10-20T22:15:01+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-10-20T22:15:01+0000] [ALPM] running 'update-desktop-database.hook'...
[2021-10-20T22:15:01+0000] [ALPM] running 'update-mime-database.hook'...
$ cat /etc/pacman-mirrors.conf
## /etc/pacman-mirrors.conf
## Branch Pacman should use (stable, testing, unstable)
Branch = stable
## Generation method
## 1) rank - rank mirrors depending on their access time
## 2) random - randomly generate the output mirrorlist
# Method = rank
## Filename to use when ranking mirrors
## The file must be present in core repo
# TestFile = core.db.tar.gz
## Define protocols and priority
## separated by comma 'https,http' or 'http,https'
## ATM available protocols are: http, https, ftp
## Not specifying a protocol will ban the protocol from being used
## If a mirror has more than one protocol defined only the first is written to the mirrorlist
## Empty means all in reversed alphabetic order
# Protocols =
## When set to False - all certificates are accepted.
## Use only if you fully trust all ssl-enabled mirrors.
# SSLVerify = True
$ cat /etc/pacman.d/mirrorlist
## Manjaro Linux default mirrorlist
## Generated on 2021-10-20 22:12
## Please use 'pacman-mirrors -f [NUMBER] [NUMBER]' to modify mirrorlist
## (Use 0 for all mirrors)
## Country : Hungary
Server = http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/$repo/$arch
## Country : Hong_Kong
Server = http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable/$repo/$arch
## Country : Germany
Server = https://mirror.netcologne.de/manjaro/stable/$repo/$arch
## Country : Belgium
Server = http://ftp.belnet.be/mirrors/manjaro/stable/$repo/$arch
## Country : France
Server = http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
## Country : Brazil
Server = http://pet.inf.ufsc.br/mirrors/manjarolinux/stable/$repo/$arch
## Country : Philippines
Server = http://mirror.rise.ph/manjaro/stable/$repo/$arch
## Country : Brazil
Server = http://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
## Country : China
Server = https://mirrors.zju.edu.cn/manjaro/stable/$repo/$arch
## Country : Turkey
Server = http://ftp.linux.org.tr/manjaro/stable/$repo/$arch
## Country : Denmark
Server = https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
## Country : Sweden
Server = https://mirror.zetup.net/manjaro/stable/$repo/$arch
## Country : Sweden
Server = https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
## Country : Ecuador
Server = https://mirror.cedia.org.ec/manjaro/stable/$repo/$arch
## Country : Spain
Server = http://ftp.caliu.cat/manjaro/stable/$repo/$arch
Server = https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
## Country : Indonesia
Server = http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Server = https://mirror.espoch.edu.ec/manjaro/stable/$repo/$arch
## Country : Colombia
Server = http://mirror.upb.edu.co/manjarostable/$repo/$arch
Server = https://manjaro.cu.be/stable/$repo/$arch
## Country : Brazil
Server = https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Server = https://mirror.netzspielplatz.de/manjaro/packages/stable/$repo/$arch
## Country : United_States
Server = https://mirror.clarkson.edu/manjaro/stable/$repo/$arch
## Country : Romania
Server = http://mirrors.serverhost.ro/manjaro/packages/stable/$repo/$arch
Server = http://kambing.ui.ac.id/manjaro/stable/$repo/$arch
## Country : Bulgaria
Server = http://manjaro.telecoms.bg/stable/$repo/$arch
## Country : France
Server = http://kibo.remi.lu/stable/$repo/$arch
## Country : Canada
Server = https://osmirror.org/manjaro/stable/$repo/$arch
## Country : Poland
Server = http://mirror.chmuri.net/manjaro/stable/$repo/$arch
## Country : China
Server = https://mirrors.shuosc.org/manjaro/stable/$repo/$arch
## Country : Japan
Server = http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
## Country : Greece
Server = https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
Server = http://distro.ibiblio.org/manjaro/stable/$repo/$arch
Server = https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Server = http://mirror.dacentec.com/manjaro/stable/$repo/$arch
## Country : Brazil
Server = http://linorg.usp.br/manjaro/stable/$repo/$arch
Server = http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
## Country : Czech
Server = https://mirror.dkm.cz/manjaro/stable/$repo/$arch
## Country : China
Server = https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
Server = https://mirrors.netix.net/manjaro/stable/$repo/$arch
Server = https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
## Country : Netherlands
Server = http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
## Country : China
Server = https://mirrors.sjtug.sjtu.edu.cn/manjarostable/$repo/$arch
Server = https://mirror.koddos.net/manjaro/stable/$repo/$arch
Server = https://repo.rhindon.net/manjaro/stable/$repo/$arch
Server = https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
Server = http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
## Country : Italy
Server = https://manjaro.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
## Country : China
Server = https://mirrors.shu.edu.cn/manjaro/stable/$repo/$arch
## Country : Italy
Server = https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
## Country : Bangladesh
Server = http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
## Country : United_Kingdom
Server = http://mirror.catn.com/pub/manjaro/stable/$repo/$arch
## Country : Italy
Server = https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
## Country : Russia
Server = http://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
Server = https://mirror.philpot.de/manjaro/stable/$repo/$arch
## Country : South_Africa
Server = http://manjaro.mirror.ac.za/stable/$repo/$arch
Server = https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Server = http://mirror.ragenetwork.de/manjaro/stable/$repo/$arch
Server = http://repo.manjaro.org.uk/stable/$repo/$arch
## Country : Poland
Server = https://mirror.tuchola-dc.pl/manjaro/stable/$repo/$arch
## Country : Austria
Server = http://mirror.inode.at/manjaro/stable/$repo/$arch
## Country : Belarus
Server = http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
## Country : Taiwan
Server = http://free.nchc.org.tw/manjaro/stable/$repo/$arch
## Country : Iran
Server = https://repo.sadjad.ac.ir/manjaro/stable/$repo/$arch
Server = https://manjaro.moson.eu/stable/$repo/$arch
Server = http://manjaro.mirrors.uk2.net/stable/$repo/$arch
## Country : Russia
Server = https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
## Country : Australia
Server = http://mirror.ventraip.net.au/Manjaro/stable/$repo/$arch
## Country : China
Server = http://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
## Country : Chile
Server = http://manjaro.dcc.uchile.cl/stable/$repo/$arch
## Country : Costa_Rica
Server = https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
## Country : Singapore
Server = https://download.nus.edu.sg/mirror/manjaro/stable/$repo/$arch
Server = http://manjaro.melbourneitmirror.net/stable/$repo/$arch
Server = https://www.uex.dk/public/manjaro/stable/$repo/$arch
## Country : Japan
Server = http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Server = https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
Server = http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
## Country : Portugal
Server = http://manjaro.barata.pt/stable/$repo/$arch
Could be that caused by some of update servers which was behaves abnormally?
In the rolling release world even that .iso can be too old :grinning_face_with_smiling_eyes: because of deprecated keys, have you tried this?
https://wiki.manjaro.org/index.php/Pacman_troubleshooting#Errors_about_Keys
I think it is a bit irrelevant as the user said:
The whole sentence with the wiki link are not in any way irrelevant, if he has tried 2 different .isos and he is having the same problem, then it’s most probably a VM misconfiguration on his part, pay attention in particular to this in the wiki: :point_down:
Warning The following commands only work, when your system time is set correctly!
Caused by a completely different matter - I just tested the latest KDE - and there was no issues running an update of the system.
Ensure your system clock is correct.
