Hi everyone,
After updating my Manjaro system to Linux kernel 6.17.11, my PC can no longer suspend properly.
Every attempt to enter sleep results in a crash and freeze, and the system never resumes.
Hardware
GPU: AMD Radeon RX 6700 XT
Motherboard: MSI PRO B760-VC WIFI
System: Manjaro KDE
What happens
When I run systemctl suspend, the screen goes black as usual, but:
the system never actually enters proper sleep,
leaving the machine completely unresponsive.
Keyboard, mouse, and power button do nothing, and I have to force reboot.
Logs
The journal shows repeated failures from the amdgpu driver:
amdgpu 0000:03:00.0: amdgpu: MODE1 reset
amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset failed
amdgpu 0000:03:00.0: PM: pci_pm_suspend_noirq(): amdgpu_pmops_suspend_noirq [amdgpu] returns -62
amdgpu 0000:03:00.0: PM: failed to suspend async noirq: error -62
[drm:psp_v11_0_memory_training [amdgpu]] *ERROR* send training msg failed.
amdgpu: Failed to process memory training!
amdgpu: amdgpu_device_ip_resume failed (-62)
Before upgrading to kernel 6.17.x, suspend/resume worked normally.
What I have already checked
Firmware is up to date
Reverting back to an older kernel (6.16 or LTS) makes suspend work again
Reports from other users
I found several Arch Linux users reporting the exact same issue with kernel 6.17.x, amdgpu, and RX 6000-series GPUs. It looks like a regression in the amdgpu driver or kernel power-management stack.
Question
Is anyone else on Manjaro experiencing broken suspend/resume with kernel 6.17.x and AMD GPUs (especially RX 6700 XT)?
Is this a known regression upstream, and is there a recommended workaround besides downgrading the kernel?
Any guidance or confirmations would be appreciated!
Thanks.
~ inxi -zv8 ✔
Kernel: 6.17.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
root=UUID=59ec4a53-6ed0-46ca-abdf-4fe3268ce294 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Desktop Mobo: Micro-Star model: PRO B760-VC WIFI (MS-7D98) v: 2.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: B.H0 date: 09/16/2025
System RAM: total: 32 GiB available: 31.11 GiB used: 6.51 GiB (20.9%)
Device-1: Controller0-DIMMA1 type: no module installed
Device-2: Controller0-DIMMA2 type: DDR5 detail: synchronous size: 16 GiB
speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMK32GX5M2B6000C30
serial: N/A
Device-3: Controller1-DIMMB1 type: no module installed
Device-4: Controller1-DIMMB2 type: DDR5 detail: synchronous size: 16 GiB
serial: N/A
Info: model: 13th Gen Intel Core i5-13600KF bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x132
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1007 min/max: 800/5100:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1007 2: 1007 3: 1007
4: 1007 5: 1007 6: 1007 7: 1007 8: 1007 9: 1007 10: 1007 11: 1007 12: 1007
13: 1007 14: 1007 15: 1007 16: 1007 17: 1007 18: 1007 19: 1007 20: 1007
bogomips: 139776
de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Sapphire driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73df
class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left model: Dell S2721DS serial: <filter>
built: 2021 res: mode: 2560x1440 hz: 75 scale: 100% (1) dpi: 110 gamma: 1.2
chroma: red: x: 0.651 y: 0.329 green: x: 0.298 y: 0.620 blue: x: 0.149
y: 0.051 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
diag: 676mm (26.6") ratio: 16:9 modes: 2560x1440, 1920x1200, 2048x1080,
1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: HDMI-A-1 pos: bottom-r model: Samsung SyncMaster built: 2009
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 305 gamma: 1.2 chroma: red:
x: 0.651 y: 0.337 green: x: 0.282 y: 0.604 blue: x: 0.141 y: 0.071 white:
x: 0.314 y: 0.329 size: 160x90mm (6.3x3.54") diag: 184mm (7.2")
ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
navi22 LLVM 21.1.6 DRM 3.64 6.17.11-1-MANJARO) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 25.3.1-arch1.2
device-ID: 1002:73df surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top,lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.1:4
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: Thesycon System & Consulting GmbH DX1 driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.3:6
chip-ID: 152a:8750 class-ID: fe01
API: ALSA v: k6.17.11-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel 700 Series CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
IF-ID-1: br-19dffd487dd9 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth84459a6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 5.01 TiB used: 3.08 TiB (61.4%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
model: SSD 990 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 1B2QKXG7 temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 45.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC47 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HUA723020ALA641
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Verbatim model: Vi550 S3
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 647.99 GiB (70.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
label: N/A uuid: 59ec4a53-6ed0-46ca-abdf-4fe3268ce294
used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
uuid: BC84-67B8
ID-3: /mnt/HDD2to raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.69 TiB (93.0%) fs: ntfs dev: /dev/sdc4 maj-min: 8:36 label: HDD2to
uuid: 503CDF6B3CDF4A9C
ID-4: /mnt/WinNVME raw-size: 930.62 GiB size: 930.62 GiB (100.00%)
used: 774.5 GiB (83.2%) fs: ntfs dev: /dev/nvme1n1p3 maj-min: 259:3
label: WinNVME uuid: 227E563B7E560845
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: B454-078D
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p4 maj-min: 259:4 size: 795 MiB fs: ntfs
label: Windows RE tools uuid: 56B298E4B298C9BF
ID-4: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: Seagate500go
uuid: 78E65C90E65C508C
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdb2 maj-min: 8:18 size: 465.19 GiB fs: ntfs label: N/A
uuid: 9412080D1207F2D2
ID-7: /dev/sdb3 maj-min: 8:19 size: 568.8 MiB fs: ntfs label: N/A
uuid: 1A86863786861383
ID-8: /dev/sdc1 maj-min: 8:33 size: 450 MiB fs: ntfs
label: R\xc3\xa9cup\xc3\xa9ration uuid: BA48CF6A48CF244B
ID-9: /dev/sdc2 maj-min: 8:34 size: 100 MiB fs: vfat label: N/A
uuid: 24D0-4EDB
ID-10: /dev/sdc3 maj-min: 8:35 size: 16 MiB fs: <superuser required>
ID-11: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
ID-12: /dev/sdd2 maj-min: 8:50 size: 476.92 GiB fs: ntfs
label: SSD_Verbatim_500Go uuid: B4FE60E7FE60A2FA
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.1:4 info: C-Media Blue Snowball type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-3: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-6.3:6 info: Thesycon System & Consulting GmbH DX1 type: audio
driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 152a:8750 class-ID: fe01
Device-2: 1-7:5 info: Itron iONE ASUS Strix Tactic Pro Gaming Keyboard
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 195d:2039 class-ID: 0300
Device-3: 1-8:7 info: Kingston HyperX Pulsefire FPS Pro
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 0951:1729 class-ID: 0300
Device-4: 1-11:8 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d98 class-ID: 0300
serial: <filter>
Device-5: 1-14:9 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
mem: 56.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1934 libs: 480 tools: pamac pm: flatpak pkgs: 0
1: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
2: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
3: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 562
1: cpu: 100% command: ps pid: 16072 mem: 4.18 MiB (0.0%)
2: cpu: 20.6% command: exe pid: 2883 mem: 510.0 MiB (1.6%)
3: cpu: 7.5% command: zen-bin pid: 3213 mem: 659.4 MiB (2.0%)
4: cpu: 5.8% command: thumbnail.so started-by: kioworker pid: 16033
mem: 214.4 MiB (0.6%)
5: cpu: 5.7% command: Discord pid: 2776 mem: 253.6 MiB (0.7%)
Memory top: 5 of 562
1: mem: 710.0 MiB (2.2%) command: anki started-by: python3 pid: 6618
cpu: 0.7%
2: mem: 659.4 MiB (2.0%) command: zen-bin pid: 3213 cpu: 7.5%
3: mem: 514.0 MiB (1.6%) command: plasmashell pid: 1571 cpu: 0.7%
4: mem: 510.0 MiB (1.6%) command: exe pid: 2883 cpu: 20.6%
5: mem: 472.8 MiB (1.4%) command: kwin_wayland pid: 1306 cpu: 5.0%
Processes: 562 Power: uptime: 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.3.8 running-in: konsole inxi: 3.3.40
