Ethernet stop working after change Cat5 to Cat6
Guys a question, I changed my cat5 ethernet cable to cat6a.
Now my manjaro does not detect the wired network, it tries to connect and then says connection disabled, so it stays in a loop, I have no internet.
but it only happens in manjaro, when I switch to windows 11 it works perfect, there if I have network and everything.
in manjaro I can’t even access my default gateway to see my router.
As I write this, this was apparently solved after installing these libraries.
lspci | grep Ethernet
08:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03)
ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp8s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether c8:7f:54:a8:78:cc brd ff:ff:ff:ff:ff:ff
3: wlo1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether f0:d4:15:69:69:46 brd ff:ff:ff:ff:ff:ff
    altname wlp0s20f3
    inet 192.168.8.101/24 brd 192.168.8.255 scope global dynamic noprefixroute wlo1
       valid_lft 36678sec preferred_lft 36678sec
    inet 192.168.8.102/24 brd 192.168.8.255 scope global secondary dynamic noprefixroute wlo1
       valid_lft 36763sec preferred_lft 31363sec
    inet6 fe80::fc29:fea0:1ae1:7891/64 scope link noprefixroute
4: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
    link/ether 52:54:00:8b:d8:a3 brd ff:ff:ff:ff:ff:ff
    inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
I get this popup each minute
I tried to change the speed of the connection with several, from 100 to 2.5, put it in full duplex, including giving it the manual ipv4 dhcp but nothing. I don’t understand what is wrong with my linux
I even enabled a module that said IGC according to llama3-coder bot xD
but nothings works
sudo journalctl -xe | grep enp8s0
jun 26 17:39:58 noe-systemproductname NetworkManager[974]: <info>  [1719441598.8570] audit: op="connection-add-activate" pid=50692 uid=0 result="fail" reason="Connection 'enp8s0' is not available on device enp8s0 because device has no carrier"
jun 26 17:40:11 noe-systemproductname vmnet-natd[1223]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00011043
jun 26 17:40:11 noe-systemproductname vmnetBridge[1088]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00011043
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.2942] device (enp8s0): carrier: link connected
jun 26 17:40:11 noe-systemproductname vmnetBridge[1088]: Adding interface enp8s0 index:2
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.2943] device (enp8s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
jun 26 17:40:11 noe-systemproductname dhcpcd[8157]: enp8s0: carrier acquired
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.2950] device (enp8s0): Activation: starting connection 'Nueva conexión 802-3-ethernet' (758cf072-67f3-4144-81aa-7ce908cae2cf)
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.2951] device (enp8s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 26 17:40:11 noe-systemproductname dhcpcd[8157]: enp8s0: IAID 54:a8:78:cc
jun 26 17:40:11 noe-systemproductname dhcpcd[8157]: enp8s0: adding address fe80::140:2f36:635e:a9dd
jun 26 17:40:11 noe-systemproductname kernel: igc 0000:08:00.0 enp8s0: NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.3378] device (enp8s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.3396] device (enp8s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 26 17:40:11 noe-systemproductname vmnetBridge[1088]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00001043
jun 26 17:40:11 noe-systemproductname vmnet-natd[1223]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00001043
jun 26 17:40:11 noe-systemproductname dhcpcd[8157]: enp8s0: carrier lost
jun 26 17:40:11 noe-systemproductname NetworkManager[974]: <info>  [1719441611.3876] dhcp4 (enp8s0): activation: beginning transaction (timeout in 45 seconds)
jun 26 17:40:11 noe-systemproductname dhcpcd[8157]: enp8s0: deleting address fe80::140:2f36:635e:a9dd
jun 26 17:40:12 noe-systemproductname vmnet-natd[1223]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00001003
jun 26 17:40:12 noe-systemproductname vmnetBridge[1088]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00001003
jun 26 17:40:12 noe-systemproductname vmnetBridge[1088]: Removing interface enp8s0 index:2
jun 26 17:40:17 noe-systemproductname NetworkManager[974]: <info>  [1719441617.3388] device (enp8s0): state change: ip-config -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
jun 26 17:40:17 noe-systemproductname NetworkManager[974]: <info>  [1719441617.3633] dhcp4 (enp8s0): canceled DHCP transaction
jun 26 17:40:17 noe-systemproductname NetworkManager[974]: <info>  [1719441617.3634] dhcp4 (enp8s0): state changed no lease
jun 26 17:40:17 noe-systemproductname vmnetBridge[1088]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00001003
jun 26 17:40:17 noe-systemproductname vmnet-natd[1223]: RTM_NEWLINK: name:enp8s0 index:2 flags:0x00001003
jun 26 17:40:20 noe-systemproductname sudo[51748]:      noe : TTY=pts/3 ; PWD=/home/noe ; USER=root ; COMMAND=/usr/bin/nmcli device connect enp8s0
jun 26 17:40:20 noe-systemproductname NetworkManager[974]: <info>  [1719441620.2780] audit: op="connection-add-activate" pid=51751 uid=0 result="fail" reason="Connection 'enp8s0' is not available on device enp8s0 because device has no carrier"
sudo dmesg | grep eth
[    5.452438] igc 0000:08:00.0 eth0: MAC: c8:xxx:54:xxxx
[    6.216586] igc 0000:08:00.0 enp8s0: renamed from eth0
[    6.532360] Bluetooth: hci0: DSM reset method type: 0x00
Please help me, thank u very much guys!
Hello @Milor123 :wink:
I’m rather surprised that you have 2 Network Managers running. Once dhcpcd and once NetworkManager. Now both services are fighting for the network device and then both give up.
systemctl status dhcpcd NetworkManager
:upside_down_face:
Ohh understand,
○ dhcpcd.service - DHCP/ IPv4LL/ IPv6RA/ DHCPv6 client on all interfaces
     Loaded: loaded (/usr/lib/systemd/system/dhcpcd.service; disabled; preset: disabled)
     Active: inactive (dead)
● NetworkManager.service - Network Manager
     Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
     Active: active (running) since Thu 2024-06-27 06:01:26 -05; 27min ago
       Docs: man:NetworkManager(8)
   Main PID: 1018 (NetworkManager)
      Tasks: 4 (limit: 56831)
     Memory: 13.3M (peak: 15.0M)
        CPU: 841ms
     CGroup: /system.slice/NetworkManager.service
             └─1018 /usr/bin/NetworkManager --no-daemon
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6063] device (enp8s0): state change: unavailable>
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6075] policy: auto-activating connection 'Nueva >
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6085] device (enp8s0): Activation: starting conn>
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6088] device (enp8s0): state change: disconnecte>
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6524] device (enp8s0): state change: prepare -> >
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6532] device (enp8s0): state change: config -> i>
jun 27 06:28:17 noe-systemproductname NetworkManager[1018]: <info>  [1719487697.6536] dhcp4 (enp8s0): activation: beginning tran>
jun 27 06:28:23 noe-systemproductname NetworkManager[1018]: <info>  [1719487703.6540] device (enp8s0): state change: ip-config ->
jun 27 06:28:23 noe-systemproductname NetworkManager[1018]: <info>  [1719487703.6884] dhcp4 (enp8s0): canceled DHCP transaction
jun 27 06:28:23 noe-systemproductname NetworkManager[1018]: <info>  [1719487703.6884] dhcp4 (enp8s0): state changed no lease
These links may give some valuable insight:
Particularly the information under these headings (of the first link):
  • Differences
  • Equipment Requirements
Cheers.
Well dhcpcd is inactive, but something/someone triggered it. VMware probably or you yourself?
About NetworkManager: The output is cutoff. Use --no-pager if you can’t maximize the terminal window.
nmcli connection show <connection-name>
nmcli device show <device>
in the firts the ethernet connection wasn’t found
NAME                           UUID                                  TYPE      DEVICE
OnePiece                       66586230-9dfb-4cfa-be17-xxxx  wifi      wlo1
lo                             6f1cdf21-b11d-469f-82b8-xxxx  loopback  lo
virbr0                         7c7e71c6-0682-4e29-b688-xxxx  bridge    virbr0
GENERAL.DEVICE:                         enp8s0
GENERAL.TYPE:                           ethernet
GENERAL.HWADDR:                         CXXXX:AX:XX:X
GENERAL.MTU:                            1500
GENERAL.STATE:                          30 (desconectado)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
WIRED-PROPERTIES.CARRIER:               activado
IP4.GATEWAY:                            --
IP6.GATEWAY:                            --
I use virtIO and vmware, I am not sure, probably reading yesterday i try use commands with dhcpcd.
Then it is not there. It cannot connect when no connection profile is set. :man_shrugging:
I dont understand, I cant acces to my router, but in windows11 works, what should stay bad? T_T
and what I’m going to tell you is even stranger, yesterday I gave up with this problem, and I was given to delete the network adapter, then linux did not know what he did but it worked, and I thought the problem had been solved, but today in the morning I turned on my computer, the surprise was that I was again without internet
My brother uses a tool that lights from 1 to 9 or 8, and they all light up fine.
The cables that we put were cat6 from the modem to the router and from the router to the pc, and all the wifi devices that connect to the router have internet, when I go to windows from my pc, I also have internet, I don’t understand what is going on. Is there something wrong with the cables?
my journal -b output:
https://pastecode.io/s/6ufgmip9
I can only assume that you have deactivated the NetworkManager and then entered dhcpcd in the terminal. A connection is then temporarily negotiated and established bypassing the NetworkManager. When you restart, there is no Internet. :neutral_face:
Again… the NetworkManager needs a profile for the ethernet connection just like your wifi connection.
NetworkManager? but its looks good not?
the wifi works but when It delete and create again the ethernet connection, it keep in a loop connection, [Connected - Disconnected] each 10 seconds. :confused:
What should i do bro?
Check what is happening there…
Open a terminal and run:
journalctl -f -u NetworkManager.service --no-hostname
Open a second terminal and run:
sudo nmcli general logging level DEBUG
Now the journal should be more detailed about where it hangs/loops.
Revert the level at the end:
sudo nmcli general logging level INFO
jun 27 07:44:19 NetworkManager[993]: <info>  [1719492259.7673] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jun 27 07:44:19 NetworkManager[993]: <info>  [1719492259.7677] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jun 27 07:44:19 NetworkManager[993]: <info>  [1719492259.7683] manager: NetworkManager state is now CONNECTED_SITE
jun 27 07:44:19 NetworkManager[993]: <info>  [1719492259.7698] device (wlo1): Activation: successful, device activated.
jun 27 07:44:20 NetworkManager[993]: <info>  [1719492260.1366] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 27 07:44:20 NetworkManager[993]: <info>  [1719492260.6545] manager: startup complete
jun 27 07:44:43 NetworkManager[993]: <info>  [1719492283.1746] device (enp8s0): carrier: link connected
jun 27 07:44:43 NetworkManager[993]: <info>  [1719492283.1752] device (enp8s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
jun 27 07:46:19 NetworkManager[993]: <info>  [1719492379.8896] agent-manager: agent[21ef55ead7ced9ca,:1.49/org.kde.plasma.networkmanagement/1000]: agent registered
jun 27 07:46:59 NetworkManager[993]: <info>  [1719492419.8377] audit: op="statistics" interface="wlo1" ifindex=3 args="2000" pid=2081 uid=1000 result="success"
the second is empty
[sudo] contraseña para noe:
 noe@noe-systemproductname  ~ 
the third is empty too:
Look… the second command is just a switch. From now on, it will log with level DEBUG. So you have to reconnect the ethernet connection
ohh understand, ty bro xD
jun 27 08:23:42 NetworkManager[993]: <debug> [1719494622.4497] connectivity: (virbr0,IPv6,169) skip connectivity check due to no carrier
jun 27 08:23:42 NetworkManager[993]: <debug> [1719494622.4497] connectivity: (virbr0,IPv4,168) check completed: NONE; no carrier
jun 27 08:23:42 NetworkManager[993]: <debug> [1719494622.4497] connectivity: (virbr0,IPv6,169) check completed: NONE; no carrier
jun 27 08:23:43 NetworkManager[993]: <debug> [1719494623.5980] platform-linux: do-request-link: 3
jun 27 08:23:45 NetworkManager[993]: <debug> [1719494625.6002] platform-linux: do-request-link: 3
jun 27 08:23:46 NetworkManager[993]: <debug> [1719494626.4493] connectivity: (virbr0,IPv4,170) skip connectivity check due to no carrier
jun 27 08:23:46 NetworkManager[993]: <debug> [1719494626.4493] connectivity: (virbr0,IPv6,171) skip connectivity check due to no carrier
jun 27 08:23:46 NetworkManager[993]: <debug> [1719494626.4493] connectivity: (virbr0,IPv4,170) check completed: NONE; no carrier
jun 27 08:23:46 NetworkManager[993]: <debug> [1719494626.4494] connectivity: (virbr0,IPv6,171) check completed: NONE; no carrier
jun 27 08:23:47 NetworkManager[993]: <debug> [1719494627.6016] platform-linux: do-request-link: 3
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0724] connectivity: (enp8s0,IPv4,172) skip connectivity check due to no carrier
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0724] connectivity: (enp8s0,IPv6,173) skip connectivity check due to no carrier
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0724] connectivity: (p2p-dev-wlo1,IPv4,174) start fake request (fake result)
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0724] connectivity: (p2p-dev-wlo1,IPv6,175) start fake request (fake result)
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0725] connectivity: (enp8s0,IPv4,172) check completed: NONE; no carrier
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0725] connectivity: (enp8s0,IPv6,173) check completed: NONE; no carrier
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0725] connectivity: (p2p-dev-wlo1,IPv4,174) check completed: FAKE; fake result
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.0725] connectivity: (p2p-dev-wlo1,IPv6,175) check completed: FAKE; fake result
jun 27 08:23:49 NetworkManager[993]: <debug> [1719494629.6030] platform-linux: do-request-link: 3
jun 27 08:23:51 NetworkManager[993]: <debug> [1719494631.6052] platform-linux: do-request-link: 3
jun 27 08:23:53 NetworkManager[993]: <debug> [1719494633.6063] platform-linux: do-request-link: 3
jun 27 08:23:54 NetworkManager[993]: <debug> [1719494634.4494] connectivity: (virbr0,IPv4,176) skip connectivity check due to no carrier
jun 27 08:23:54 NetworkManager[993]: <debug> [1719494634.4495] connectivity: (virbr0,IPv6,177) skip connectivity check due to no carrier
jun 27 08:23:54 NetworkManager[993]: <debug> [1719494634.4495] connectivity: (virbr0,IPv4,176) check completed: NONE; no carrier
jun 27 08:23:54 NetworkManager[993]: <debug> [1719494634.4495] connectivity: (virbr0,IPv6,177) check completed: NONE; no carrier
jun 27 08:23:55 NetworkManager[993]: <debug> [1719494635.6078] platform-linux: do-request-link: 3
jun 27 08:23:57 NetworkManager[993]: <debug> [1719494637.6096] platform-linux: do-request-link: 3
jun 27 08:23:59 NetworkManager[993]: <debug> [1719494639.6117] platform-linux: do-request-link: 3
jun 27 08:24:01 NetworkManager[993]: <debug> [1719494641.6137] platform-linux: do-request-link: 3
jun 27 08:24:03 NetworkManager[993]: <debug> [1719494643.6159] platform-linux: do-request-link: 3
jun 27 08:24:05 NetworkManager[993]: <debug> [1719494645.6187] platform-linux: do-request-link: 3
jun 27 08:24:07 NetworkManager[993]: <debug> [1719494647.6196] platform-linux: do-request-link: 3
jun 27 08:24:08 NetworkManager[993]: <debug> [1719494648.5577] connectivity: (wlo1,IPv6,178) skip connectivity check due to no carrier
jun 27 08:24:08 NetworkManager[993]: <debug> [1719494648.5578] connectivity: (wlo1,IPv6,178) check completed: NONE; no carrier
jun 27 08:24:09 NetworkManager[993]: <debug> [1719494649.5577] connectivity: (wlo1,IPv4,179) skip connectivity check due to no carrier
jun 27 08:24:09 NetworkManager[993]: <debug> [1719494649.5578] connectivity: (wlo1,IPv4,179) check completed: NONE; no carrier
jun 27 08:24:09 NetworkManager[993]: <debug> [1719494649.6199] platform-linux: do-request-link: 3
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3907] platform: (enp8s0) signal: link changed: 2: enp8s0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 ethernet? init addrgenmode eui64 addr C8:7F:54:A8:78:CC permaddr C8:7F:54:A8:78:CC brd FF:FF:FF:FF:FF:FF driver igc tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:396,30167 tx:0,0
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3908] device[696a19f7a809a516] (enp8s0): queued link change for ifindex 2
jun 27 08:24:10 NetworkManager[993]: <info>  [1719494650.3912] device (enp8s0): carrier: link connected
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3916] device[696a19f7a809a516] (enp8s0): add_pending_action (1): 'queued-state-change-disconnected'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3917] device[696a19f7a809a516] (enp8s0): queue-state[disconnected, reason:carrier-changed, id:3493]: queue state change
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3918] manager: (enp8s0): assume: cannot generate connection: device has no existing configuration
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3919] device[696a19f7a809a516] (enp8s0): queue-state[disconnected, reason:carrier-changed, id:3493]: change state
jun 27 08:24:10 NetworkManager[993]: <info>  [1719494650.3919] device (enp8s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3919] device[696a19f7a809a516] (enp8s0): add_pending_action (2): 'in-state-change'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3919] device[696a19f7a809a516] (enp8s0): ip6: addrgenmode6: set none
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3919] platform-linux: link: change 2: user-ipv6ll: set IPv6 address generation mode to none
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3922] platform-linux: do-request-link: 2
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3922] platform: (enp8s0) signal: link changed: 2: enp8s0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 ethernet? init addrgenmode none addr C8:7F:54:A8:78:CC permaddr C8:7F:54:A8:78:CC brd FF:FF:FF:FF:FF:FF driver igc tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:396,30167 tx:0,0
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3922] device[696a19f7a809a516] (enp8s0): queued link change for ifindex 2
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3924] platform-linux: do-change-link[2]: success
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3924] device[696a19f7a809a516] (enp8s0): ip6: addrgenmode6: toggle disable_ipv6 sysctl after disabling addr-gen-mode
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3925] platform-linux: sysctl: reading '/proc/sys/net/ipv6/conf/enp8s0/disable_ipv6': '1'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3926] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/disable_ipv6' to '0' (current value is '1')
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3927] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/accept_ra' to '0' (current value is '1')
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3927] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/use_tempaddr' to '0' (current value is identical)
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3933] policy: re-enabling autoconnect for all connections on enp8s0
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3933] device[696a19f7a809a516] (enp8s0): add_pending_action (3): 'autoactivate'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3933] connectivity: (enp8s0,IPv4,180) skip connectivity check due to no IP address configured
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3933] connectivity: (enp8s0,IPv6,181) skip connectivity check due to no IP address configured
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3933] device[696a19f7a809a516] (enp8s0): remove_pending_action (2): 'in-state-change'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3934] device[696a19f7a809a516] (enp8s0): remove_pending_action (1): 'queued-state-change-disconnected'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3935] device[696a19f7a809a516] (enp8s0): remove_pending_action (0): 'autoactivate'
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3935] connectivity: (enp8s0,IPv4,180) check completed: NONE; no IP address configured
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3935] connectivity: (enp8s0,IPv6,181) check completed: NONE; no IP address configured
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.3935] manager: (enp8s0): assume: cannot generate connection: device has no existing configuration
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.4477] connectivity: (virbr0,IPv4,182) skip connectivity check due to no carrier
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.4478] connectivity: (virbr0,IPv6,183) skip connectivity check due to no carrier
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.4479] connectivity: (virbr0,IPv4,182) check completed: NONE; no carrier
jun 27 08:24:10 NetworkManager[993]: <debug> [1719494650.4479] connectivity: (virbr0,IPv6,183) check completed: NONE; no carrier
jun 27 08:24:11 NetworkManager[993]: <debug> [1719494651.6212] platform-linux: do-request-link: 3
jun 27 08:24:12 NetworkManager[993]: <debug> [1719494652.3942] connectivity: (enp8s0,IPv4,184) skip connectivity check due to no IP address configured
jun 27 08:24:12 NetworkManager[993]: <debug> [1719494652.3943] connectivity: (enp8s0,IPv6,185) skip connectivity check due to no IP address configured
jun 27 08:24:12 NetworkManager[993]: <debug> [1719494652.3943] connectivity: (enp8s0,IPv4,184) check completed: NONE; no IP address configured
jun 27 08:24:12 NetworkManager[993]: <debug> [1719494652.3943] connectivity: (enp8s0,IPv6,185) check completed: NONE; no IP address configured
jun 27 08:24:13 NetworkManager[993]: <debug> [1719494653.6227] platform-linux: do-request-link: 3
jun 27 08:24:15 NetworkManager[993]: <debug> [1719494655.6230] platform-linux: do-request-link: 3
jun 27 08:24:16 NetworkManager[993]: <debug> [1719494656.3940] connectivity: (enp8s0,IPv4,186) skip connectivity check due to no IP address configured
jun 27 08:24:16 NetworkManager[993]: <debug> [1719494656.3940] connectivity: (enp8s0,IPv6,187) skip connectivity check due to no IP address configured
jun 27 08:24:16 NetworkManager[993]: <debug> [1719494656.3941] connectivity: (enp8s0,IPv4,186) check completed: NONE; no IP address configured
jun 27 08:24:16 NetworkManager[993]: <debug> [1719494656.3941] connectivity: (enp8s0,IPv6,187) check completed: NONE; no IP address configured
jun 27 08:24:17 NetworkManager[993]: <debug> [1719494657.6244] platform-linux: do-request-link: 3
jun 27 08:24:19 NetworkManager[993]: <debug> [1719494659.6263] platform-linux: do-request-link: 3
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1139] ++ connection 'update connection' (0x560b6f293940/NMSimpleConnection/"802-3-ethernet" < 0x560b6f2b6e80/NMSimpleConnection/"802-3-ethernet") [/org/freedesktop/NetworkManager/Settings/1]:
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1140] ++ connection                [ 0x560b6f2cb9d0 < 0x560b6f272530 ]
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1140] ++ connection.autoconnect    < FALSE
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1145] Saving secrets for connection /org/freedesktop/NetworkManager/Settings/1 (enp8s0)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1145] agent-manager: agent[21ef55ead7ced9ca,:1.49/org.kde.plasma.networkmanagement/1000]: agent allowed for secrets request [a266b6ec6a1e9e8c/"enp8s0"sav]
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1147] audit: op="connection-update" uuid="121ea1bd-5b5f-4a4f-b9ec-9ca6773256a8" name="enp8s0" args="connection.autoconnect" pid=14725 uid=1000 result="success"
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1149] device[686e439d473f6a48] (lo): add_pending_action (1): 'autoactivate'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1149] device[696a19f7a809a516] (enp8s0): add_pending_action (1): 'autoactivate'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1149] agent-manager: agent[21ef55ead7ced9ca,:1.49/org.kde.plasma.networkmanagement/1000]: agent saving secrets for request [a266b6ec6a1e9e8c/"enp8s0"sav]
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1154] device[686e439d473f6a48] (lo): remove_pending_action (0): 'autoactivate'
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1154] policy: auto-activating connection 'enp8s0' (121ea1bd-5b5f-4a4f-b9ec-9ca6773256a8)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1155] active-connection[17232749542af125]: set device "enp8s0" [0x560b6f2526b0]
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1156] device[696a19f7a809a516] (enp8s0): add_pending_action (2): 'activation-5'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1158] active-connection[17232749542af125]: constructed (NMActRequest, version-id 5, type managed)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1158] device[696a19f7a809a516] (enp8s0): remove_pending_action (1): 'autoactivate'
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1174] device (enp8s0): Activation: starting connection 'enp8s0' (121ea1bd-5b5f-4a4f-b9ec-9ca6773256a8)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1175] device[696a19f7a809a516] (enp8s0): activation-stage: schedule activate_stage1_device_prepare
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1175] agent-manager: agent[21ef55ead7ced9ca,:1.49/org.kde.plasma.networkmanagement/1000]: agent saved secrets for request [a266b6ec6a1e9e8c/"enp8s0"sav]
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1176] device[696a19f7a809a516] (enp8s0): activation-stage: invoke activate_stage1_device_prepare
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1176] device[696a19f7a809a516] (enp8s0): ip4: set state pending (was none, reason: stage1)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1176] device[696a19f7a809a516] (enp8s0): ip6: set state pending (was none, reason: stage1)
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1176] device (enp8s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1177] device[696a19f7a809a516] (enp8s0): add_pending_action (2): 'in-state-change'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1178] active-connection[17232749542af125]: set state activating (was unknown)
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1178] manager: NetworkManager state is now CONNECTING
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1179] active-connection[17232749542af125]: check-master-ready: not signalling (state activating, no master)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1179] manager: ActivatingConnection now enp8s0
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1180] device[696a19f7a809a516] (enp8s0): remove_pending_action (1): 'in-state-change'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1180] device[696a19f7a809a516] (enp8s0): set-link: configure auto-negotiation
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1607] device[696a19f7a809a516] (enp8s0): activation-stage: synchronously invoke activate_stage2_device_config
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1607] device (enp8s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1607] device[696a19f7a809a516] (enp8s0): add_pending_action (2): 'in-state-change'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1609] device[696a19f7a809a516] (enp8s0): remove_pending_action (1): 'in-state-change'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1610] global-tracker: sync routing-rule
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1610] device[696a19f7a809a516] (enp8s0): bringing up device 2
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1610] platform-linux: link: change 2: flags: set 0x1/0x1 ([up] / [up])
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1611] platform-linux: do-request-link: 2
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1612] platform: (enp8s0) signal: link changed: 2: enp8s0 <UP;broadcast,multicast,up,running> mtu 1500 arp 1 ethernet? init addrgenmode none addr C8:7F:54:A8:78:CC permaddr C8:7F:54:A8:78:CC brd FF:FF:FF:FF:FF:FF driver igc tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:403,30587 tx:0,0
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1612] device[696a19f7a809a516] (enp8s0): queued link change for ifindex 2
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1613] platform-linux: do-change-link[2]: success
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1614] device[696a19f7a809a516] (enp8s0): carrier: link disconnected (deferring action for 6000 milliseconds)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1616] device[696a19f7a809a516] (enp8s0): add_pending_action (2): 'carrier-wait'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1616] device[696a19f7a809a516] (enp8s0): activation-stage: synchronously invoke activate_stage3_ip_config
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1616] firewalld: [6cfc482be1895456,change*:"enp8s0"]: firewall zone change enp8s0:default (not running, simulate success)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1642] platform: (enp8s0) signal: link changed: 2: enp8s0 <UP;broadcast,multicast,up> mtu 1500 arp 1 ethernet? init addrgenmode none addr C8:7F:54:A8:78:CC permaddr C8:7F:54:A8:78:CC brd FF:FF:FF:FF:FF:FF driver igc tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:403,30587 tx:0,0
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1645] device[696a19f7a809a516] (enp8s0): ip: set (combined) state pending (was none, reason: check-ip-state)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1645] firewalld: [6cfc482be1895456,change*:"enp8s0"]: complete: fake success
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1645] device[696a19f7a809a516] (enp8s0): activation-stage: synchronously invoke activate_stage3_ip_config
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1645] device[696a19f7a809a516] (enp8s0): ip4: required-timeout: disabled
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1645] device[696a19f7a809a516] (enp8s0): ip6: required-timeout: disabled
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1645] active-connection[17232749542af125]: set state-flags layer2-ready,lifetime-bound-to-profile-visibility (was lifetime-bound-to-profile-visibility)
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1646] device (enp8s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1646] device[696a19f7a809a516] (enp8s0): add_pending_action (3): 'in-state-change'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1649] device[696a19f7a809a516] (enp8s0): remove_pending_action (2): 'in-state-change'
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1649] device[696a19f7a809a516] (enp8s0): ip:manual4: set state pending
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1649] device[696a19f7a809a516] (enp8s0): ip:manual6: set state pending
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1650] device[696a19f7a809a516] (enp8s0): ip:dhcp4: set state pending (was none)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1650] device[696a19f7a809a516] (enp8s0): ipv4.dhcp-client-id: no explicit client-id configured
jun 27 08:24:20 NetworkManager[993]: <info>  [1719494660.1650] dhcp4 (enp8s0): activation: beginning transaction (timeout in 45 seconds)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1652] device[696a19f7a809a516] (enp8s0): ip6: addrgenmode6: set eui64
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1652] platform-linux: link: change 2: user-ipv6ll: set IPv6 address generation mode to eui64
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1654] platform-linux: do-request-link: 2
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1654] platform: (enp8s0) signal: link changed: 2: enp8s0 <UP;broadcast,multicast,up> mtu 1500 arp 1 ethernet? init addrgenmode eui64 addr C8:7F:54:A8:78:CC permaddr C8:7F:54:A8:78:CC brd FF:FF:FF:FF:FF:FF driver igc tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:403,30587 tx:0,0
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1654] device[696a19f7a809a516] (enp8s0): queued link change for ifindex 2
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1655] platform-linux: do-change-link[2]: success
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1656] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/disable_ipv6' to '1' (current value is '0')
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1658] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/use_tempaddr' to '0' (current value is identical)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1658] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/hop_limit' to '64' (current value is identical)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1659] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/accept_ra' to '1' (current value is '0')
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1659] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/disable_ipv6' to '0' (current value is '1')
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1661] dhcp4 (enp8s0): event: send DISCOVER to 255.255.255.255
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1662] dns-mgr: (device_l3cd_changed): queueing DNS updates (1)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1662] dns-mgr: (device_l3cd_changed): DNS configuration did not change
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1663] dns-mgr: (device_l3cd_changed): no DNS changes to commit (0)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1665] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/use_tempaddr' to '0' (current value is identical)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1665] device[696a19f7a809a516] (enp8s0): ip6: set state done (was pending, reason: check-ip-state)
jun 27 08:24:20 NetworkManager[993]: <debug> [1719494660.1665] active-connection[17232749542af125]: set state-flags layer2-ready,ip6-ready,lifetime-bound-to-profile-visibility (was layer2-ready,lifetime-bound-to-profile-visibility)
jun 27 08:24:21 NetworkManager[993]: <debug> [1719494661.6283] platform-linux: do-request-link: 3
jun 27 08:24:22 NetworkManager[993]: <debug> [1719494662.1671] device[696a19f7a809a516] (enp8s0): ip:manual6: set state done
jun 27 08:24:22 NetworkManager[993]: <debug> [1719494662.1672] device[696a19f7a809a516] (enp8s0): ip:manual4: set state done
jun 27 08:24:22 NetworkManager[993]: <debug> [1719494662.1682] dhcp4 (enp8s0): event: send DISCOVER to 255.255.255.255
jun 27 08:24:23 NetworkManager[993]: <debug> [1719494663.6308] platform-linux: do-request-link: 3
jun 27 08:24:24 NetworkManager[993]: <debug> [1719494664.3948] connectivity: (enp8s0,IPv4,188) skip connectivity check due to no carrier
jun 27 08:24:24 NetworkManager[993]: <debug> [1719494664.3948] connectivity: (enp8s0,IPv6,189) skip connectivity check due to no carrier
jun 27 08:24:24 NetworkManager[993]: <debug> [1719494664.3948] connectivity: (enp8s0,IPv4,188) check completed: NONE; no carrier
jun 27 08:24:24 NetworkManager[993]: <debug> [1719494664.3948] connectivity: (enp8s0,IPv6,189) check completed: NONE; no carrier
jun 27 08:24:25 NetworkManager[993]: <debug> [1719494665.6321] platform-linux: do-request-link: 3
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1628] device[696a19f7a809a516] (enp8s0): carrier: link disconnected (calling deferred action)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1629] device[696a19f7a809a516] (enp8s0): add_pending_action (3): 'queued-state-change-unavailable'
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): queue-state[unavailable, reason:carrier-changed, id:3567]: queue state change
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): remove_pending_action (2): 'carrier-wait'
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): queue-state[unavailable, reason:carrier-changed, id:3567]: change state
jun 27 08:24:26 NetworkManager[993]: <info>  [1719494666.1630] device (enp8s0): state change: ip-config -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): add_pending_action (3): 'in-state-change'
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): deactivating device (reason 'carrier-changed') [40]
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): ip4: set state none (was pending, reason: ip-state-clear)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] device[696a19f7a809a516] (enp8s0): ip6: set state none (was done, reason: ip-state-clear)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] firewalld: [01f9af25de11372d,remove*:"enp8s0"]: firewall zone remove enp8s0:default (not running, simulate success)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1630] firewalld: [01f9af25de11372d,remove*:"enp8s0"]: complete: drop request simulating success
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1631] device[696a19f7a809a516] (enp8s0): ip:dhcp4: set state none (was pending)
jun 27 08:24:26 NetworkManager[993]: <info>  [1719494666.1962] dhcp4 (enp8s0): canceled DHCP transaction
jun 27 08:24:26 NetworkManager[993]: <info>  [1719494666.1963] dhcp4 (enp8s0): state changed no lease
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1963] device[696a19f7a809a516] (enp8s0): ip:manual4: set state none
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1963] device[696a19f7a809a516] (enp8s0): ip:manual6: set state none
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1963] device[696a19f7a809a516] (enp8s0): ip: set (combined) state none (was pending, reason: ip-state-clear)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1964] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/disable_ipv6' to '1' (current value is '0')
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1964] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/use_tempaddr' to '0' (current value is identical)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.1964] device[696a19f7a809a516] (enp8s0): set-link: reset auto-negotiation (0 Mbit, unknown duplex)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2403] dns-mgr: (device_l3cd_changed): queueing DNS updates (1)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2403] dns-mgr: (device_l3cd_changed): DNS configuration did not change
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2403] dns-mgr: (device_l3cd_changed): no DNS changes to commit (0)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2404] global-tracker: sync ip4-route
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2405] platform-linux: sysctl: setting '/proc/sys/net/ipv6/conf/enp8s0/use_tempaddr' to '0' (current value is identical)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2405] global-tracker: sync ip6-route
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2405] global-tracker: sync mptcp-addr (reapply)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2405] global-tracker: sync routing-rule
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2406] active-connection[17232749542af125]: set state deactivated (was activating)
jun 27 08:24:26 NetworkManager[993]: <info>  [1719494666.2407] manager: NetworkManager state is now DISCONNECTED
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2407] active-connection[17232749542af125]: check-master-ready: not signalling (state deactivated, no master)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2407] device[696a19f7a809a516] (enp8s0): remove_pending_action (2): 'activation-5'
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] dns-mgr: (update_routing_and_dns): queueing DNS updates (1)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] dns-mgr: (update_routing_and_dns): DNS configuration did not change
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] dns-mgr: (update_routing_and_dns): no DNS changes to commit (0)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] manager: ActivatingConnection now (none)
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] device[696a19f7a809a516] (enp8s0): device not yet available for transition to DISCONNECTED
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] device[696a19f7a809a516] (enp8s0): remove_pending_action (1): 'in-state-change'
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2408] device[696a19f7a809a516] (enp8s0): remove_pending_action (0): 'queued-state-change-unavailable'
jun 27 08:24:26 NetworkManager[993]: <debug> [1719494666.2409] active-connection[17232749542af125]: disposing
jun 27 08:24:27 NetworkManager[993]: <debug> [1719494667.6337] platform-linux: do-request-link: 3
jun 27 08:24:29 NetworkManager[993]: <debug> [1719494669.6359] platform-linux: do-request-link: 3
jun 27 08:24:31 NetworkManager[993]: <debug> [1719494671.6363] platform-linux: do-request-link: 3
jun 27 08:24:33 NetworkManager[993]: <debug> [1719494673.6386] platform-linux: do-request-link: 3
jun 27 08:24:35 NetworkManager[993]: <debug> [1719494675.6409] platform-linux: do-request-link: 3
jun 27 08:24:37 NetworkManager[993]: <debug> [1719494677.6431] platform-linux: do-request-link: 3
jun 27 08:24:39 NetworkManager[993]: <debug> [1719494679.6453] platform-linux: do-request-link: 3
jun 27 08:24:40 NetworkManager[993]: <debug> [1719494680.3944] connectivity: (enp8s0,IPv4,190) skip connectivity check due to no carrier
jun 27 08:24:40 NetworkManager[993]: <debug> [1719494680.3945] connectivity: (enp8s0,IPv6,191) skip connectivity check due to no carrier
jun 27 08:24:40 NetworkManager[993]: <debug> [1719494680.3945] connectivity: (enp8s0,IPv4,190) check completed: NONE; no carrier
jun 27 08:24:40 NetworkManager[993]: <debug> [1719494680.3945] connectivity: (enp8s0,IPv6,191) check completed: NONE; no carrier
jun 27 08:24:41 NetworkManager[993]: <debug> [1719494681.6469] platform-linux: do-request-link: 3
jun 27 08:24:42 NetworkManager[993]: <debug> [1719494682.4490] connectivity: (virbr0,IPv4,192) skip connectivity check due to no carrier
jun 27 08:24:42 NetworkManager[993]: <debug> [1719494682.4491] connectivity: (virbr0,IPv6,193) skip connectivity check due to no carrier
jun 27 08:24:42 NetworkManager[993]: <debug> [1719494682.4491] connectivity: (virbr0,IPv4,192) check completed: NONE; no carrier
jun 27 08:24:42 NetworkManager[993]: <debug> [1719494682.4491] connectivity: (virbr0,IPv6,193) check completed: NONE; no carrier
jun 27 08:24:43 NetworkManager[993]: <debug> [1719494683.6484] platform-linux: do-request-link: 3
jun 27 08:24:45 NetworkManager[993]: <debug> [1719494685.6498] platform-linux: do-request-link: 3
jun 27 08:24:47 NetworkManager[993]: <debug> [1719494687.6520] platform-linux: do-request-link: 3
jun 27 08:24:49 NetworkManager[993]: <debug> [1719494689.6535] platform-linux: do-request-link: 3
jun 27 08:24:51 NetworkManager[993]: <debug> [1719494691.6557] platform-linux: do-request-link: 3
That seems to be the stopper… auto-negotiation seems not to work properly?
Share:
sudo ethtool enp8s0
I am not sure
 sudo ethtool enp8s0
Settings for enp8s0:
	Supported ports: [ TP ]
	Supported link modes:   10baseT/Half 10baseT/Full
	                        100baseT/Half 100baseT/Full
	                        1000baseT/Full
	                        2500baseT/Full
	Supported pause frame use: Symmetric
	Supports auto-negotiation: Yes
	Supported FEC modes: Not reported
	Advertised link modes:  10baseT/Half 10baseT/Full
	                        1000baseT/Full
	                        2500baseT/Full
	Advertised pause frame use: Symmetric
	Advertised auto-negotiation: Yes
	Advertised FEC modes: Not reported
	Speed: 100Mb/s
	Duplex: Full
	Auto-negotiation: on
	Port: Twisted Pair
	PHYAD: 0
	Transceiver: internal
	MDI-X: off (auto)
	Supports Wake-on: pumbg
	Wake-on: g
        Current message level: 0x00000007 (7)
                               drv probe link
	Link detected: yes
Auto-negotiation starts at 100 Mbps, then works up from there (in any modern Ethernet device). So it seems it didn’t even get very far.
What link connect speed are you getting in Win11? And you can send and receive at around 250MB/s?
Am I missing that you tried another cable?
Indeed, this should have been the first thing.
a) Swap out your cat6x cable(s) for the cat5x cable(s) you were using previously. See if your network then works as expected.
b) Swap out your cat6x cables one by one and test for any improvement after each cable is swapped out. Naturally, you will need to have another cable available.
Another possibility (using cat6x).
  • Disable auto-negotiation
  • Set it to instead start with a higher 1000Mb/s link speed.
  • Cross fingers.
Good luck.
@molski @megavolt
Windows 11 Speed with the cable that linux dont work:
Manjaro internet manager, all settings tried and nothing works
Windows configuration:
Nothings work guys :/, what should i do guys ?
The Cable is broken, use a different one. You can clearly see that Windows also only set the Ethernet device to 100 Mbps, which is only used if there is no other speed available.
You did not test the cable, instead you did a speed test of your nvme drive. You should read the documentation on how to use this program. Hint, you need to pick a Network Volume and not c:.
