Hello, I’m a new Linux user, first time using Linux and I have a MSI Z390 Gaming Plus motherboard. Ethernet is not working so for the time being I’m using my phone; I’ve already tried to get the e1000e module working but I haven’t had success.
(The module has been loaded has shown by systemctl status systemd-modules-load.service:)
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static)
Active: active (exited) since Thu 2021-12-09 20:10:21 CET; 48min ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 254 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=0/SUCCESS)
Main PID: 254 (code=exited, status=0/SUCCESS)
CPU: 311ms
dic 09 20:10:20 hamster systemd-modules-load[254]: Inserted module 'crypto_user'
dic 09 20:10:21 hamster systemd-modules-load[254]: Inserted module 'e1000e'
dic 09 20:10:21 hamster systemd-modules-load[254]: Failed to insert module 'ipmi_si': No such device
dic 09 20:10:21 hamster systemd-modules-load[254]: Inserted module 'nvidia'
dic 09 20:10:21 hamster systemd-modules-load[254]: Inserted module 'nvidia_drm'
dic 09 20:10:21 hamster systemd-modules-load[254]: Inserted module 'uinput'
dic 09 20:10:21 hamster systemd[1]: Finished Load Kernel Modules.
Notice: journal has been rotated since unit was started, output may be incomplete.
This is the output of inxi -Nazy:
inxi -Nazy
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: N/A
modules: e1000e port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Thanks in advance.
