Ethernet not connecting even though plugged in
Hello, I just installed manjaro and the wifi works but the ethernet does not. I’m very new to linux so I may need a more in depth explanation. I’ve tried to install the e1000e solution I found from a post from 2022 but it didn’t work. This also happened when I installed Linux Mint. I have the Realtek RTL8125 2.5GbE network card.
… and what would that have been?
(a link to what you refer to?)
The output of:
inxi -zv8
could be a good start as well.
So not uncommon…
If I recall correct - this is an onboard chip, often used on AMD based systems.
Please see this search - I believe you can find a solution
Search results for 'RTL8125' - Manjaro Linux Forum
  Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=51700f0e-1fab-4a11-8300-7812b4aadd2e rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: Gigabyte model: X870E AORUS ELITE WIFI7 v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: FA date: 11/22/2024
  System RAM: total: 32 GiB available: 30.47 GiB used: 4.07 GiB (13.3%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMP32GX5M2X7000C34 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3295 min/max: 545/5050 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3295 2: 3295 3: 3295
    4: 3295 5: 3295 6: 3295 7: 3295 8: 3295 bogomips: 67098
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
    cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
    x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: disabled; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: ASUSTeK driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports:
    active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DVI-D-1 bus-ID: 01:00.0
    chip-ID: 1002:67df class-ID: 0300 temp: 50.0 C
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-3, DP-4, HDMI-A-3, HDMI-A-4, Writeback-1 bus-ID: 79:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 44.0 C
  Display: x11 server: X.org v: 1.21.1.18 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: 100140681
    built: 2023 res: N/A dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.345
    green: x: 0.322 y: 0.631 blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 479x260mm (18.86x10.24") diag: 545mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,left model: Acer KA242Y
    serial: <filter> built: 2020 res: mode: 1920x1080 hz: 75 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.294 y: 0.616
    blue: x: 0.145 y: 0.067 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 ACO DRM 3.61 6.12.34-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no
    x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 79:00.1 chip-ID: 1002:1640 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 79:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Astro Gaming A30 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
    chip-ID: 9886:0050 class-ID: 0102
  API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
    driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: d000 bus-ID: 0d:00.0 chip-ID: 10ec:8922 class-ID: 0280
  IF: wlp13s0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: N/A
    modules: r8169 pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000
    bus-ID: 0e:00.0 chip-ID: 10ec:8125 class-ID: 0200
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0bda:8922
  Local Storage: total: 3.18 TiB used: 199.96 GiB (6.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620361WD temp: 51.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate model: FireCuda 530
    ZP500GM30023 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU6SM001
    temp: 43.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
    used: 10.02 GiB (2.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
    label: N/A uuid: 51700f0e-1fab-4a11-8300-7812b4aadd2e
    used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
    uuid: 5734-6386
  ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-4: /run/media/razznik/66EAAA240D7EABB5 raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 6.42 GiB (0.7%) fs: ntfs
    dev: /dev/nvme0n1p1 maj-min: 259:5 label: N/A uuid: 66EAAA240D7EABB5
  ID-5: /run/media/razznik/Storage raw-size: 1.82 TiB
    size: 1.82 TiB (100.00%) used: 183.52 GiB (9.9%) fs: ntfs dev: /dev/sda2
    maj-min: 8:2 label: Storage uuid: 3C52F53A52F4FA0A
  ID-6: /var/cache raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-7: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Astro Gaming A30 type: HID,audio
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
  Device-2: 1-6:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8922 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Razer USA Basilisk V3 Pro type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00aa class-ID: 0301
    serial: <filter>
  Device-2: 3-4:3 info: Microsoft Xbox Controller type: <vendor specific>
    driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 045e:0b12 class-ID: ff00 serial: <filter>
  Device-3: 3-7:4 info: Integrated Express GIGABYTE Device type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
  Device-4: 3-12:5 info: Areson Corp 2.4G Wireless Receiver
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 25a7:fa70 class-ID: 0301
  Hub-4: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 9-2:2 info: BY Tech Gaming Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:0049 class-ID: 0300
  Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 12-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 64.8 C mobo: 37.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 50.0 C fan: 1441 watts: 38.12 device: amdgpu
    temp: 44.0 C
  Packages: pm: pacman pkgs: 1133 libs: 375 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    2: http://manjaro.grena.ge/stable/$repo/$arch
    3: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 414
  1: cpu: 21.1% command: steam pid: 7369 mem: 373.3 MiB (1.1%)
  2: cpu: 7.1% command: [kworker/7:3-events] pid: 11587 mem: 0.00 MiB (0.0%)
  3: cpu: 6.1% command: steamwebhelper pid: 7731 mem: 582.3 MiB (1.8%)
  4: cpu: 4.6% command: steamwebhelper pid: 7654 mem: 287.0 MiB (0.9%)
  5: cpu: 3.3% command: brave pid: 11358 mem: 247.8 MiB (0.7%)
  Memory top: 5 of 414
  1: mem: 582.3 MiB (1.8%) command: steamwebhelper pid: 7731 cpu: 6.1%
  2: mem: 451.8 MiB (1.4%) command: ./steamwebhelper pid: 7630 cpu: 0.7%
  3: mem: 397.1 MiB (1.2%) command: brave pid: 5826 cpu: 2.8%
  4: mem: 373.3 MiB (1.1%) command: steam pid: 7369 cpu: 21.1%
  5: mem: 347.3 MiB (1.1%) command: brave pid: 7184 cpu: 0.7%
  Processes: 414 Power: uptime: 53m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.16 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: xfce4-terminal
    inxi: 3.3.38
Your problem is here : driver: N/A`
Solutions seem to exist in this forum, search for Realtek RTL8125
https://forum.manjaro.org/search?q=Realtek%20RTL8125%20%23support%3Anetwork%20order%3Alatest
3d or 4th post seems interesting
