Hi ! My Ethernet connetion has been lost for a few days now. I don’t know what’s causing it. Here’s my inxi output :
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1885e413-ae00-430d-9e25-bd5a2ec37ef5 rw quiet splash apparmor=1
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: SAMSUNG product: 530U3C/530U4C/532U3C v: 0.1
serial: <filter> Chassis: type: 9 v: 0.1 serial: <filter>
Mobo: SAMSUNG model: NP532U3C-A01FR v: FAB1 serial: <filter> UEFI: Phoenix
v: P04ABH date: 11/03/2012
ID-1: BAT1 charge: 18.2 Wh (84.7%) condition: 21.5/45.1 Wh (47.5%)
volts: 8.2 min: 7.4 model: SAMSUNG Electronics type: Li-ion serial: N/A
status: Charging cycles: 272
RAM: total: 3.54 GiB used: 1.75 GiB (49.4%)
Info: Dual Core model: Intel Core i3-2365M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 3 MiB bogomips: 11179
Speed: 1029 MHz min/max: 800/1400 MHz Core speeds (MHz): 1: 1029 2: 937
3: 976 4: 931
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Samsung Co driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Silicon Motion WebCam SC-13HDL12131N type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 2232:1035 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.2.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel
port: efa0 bus-ID: 01:00.0 chip-ID: 8086:088e class-ID: 0280
vendor: Samsung Co driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 2-1.5:3 chip-ID: 8087:07da class-ID: e001
Local Storage: total: 223.57 GiB used: 11.79 GiB (5.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0P13 scheme: GPT
ID-1: / raw-size: 136.72 GiB size: 133.51 GiB (97.66%)
used: 11.77 GiB (8.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 1885e413-ae00-430d-9e25-bd5a2ec37ef5
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 5673-6400
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Silicon Motion WebCam SC-13HDL12131N type: Video
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.5:3 info: Intel Centrino Bluetooth Wireless Transceiver
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: 29.8 C
Processes: 208 Uptime: 32m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1145 lib: 324 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Can you help me solve this ? By the way, I’m new at linux.
5.13 Kernel is EOL. Can you try with one of the LTS Kernels, 5.4 or 5.10? I know it is improbable, but can you swap Ethernet cable (rule out bad cable) and/or plug directly into the modem to rule out router configuration?
Hi ! I’ve tried two ethernet cables, and the modem of where I live is reliable : same installation for my neighbours who have no problem. I think it comes from my system. How to update my LTS Kernel to 5.4 or 5.10 ?
Hi ! I have intalled and run 5.10 Kernel. Besides, what does EOL mean for 5.13 Kernel ? Ethernet still doesn’t work. Here is my new inxi output :
Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
ID-1: BAT1 charge: 8.6 Wh (40.0%) condition: 21.5/45.1 Wh (47.5%) volts: 7.9
RAM: total: 3.54 GiB used: 1.57 GiB (44.4%)
Speed: 798 MHz min/max: 800/1400 MHz Core speeds (MHz): 1: 798 2: 868 3: 871
4: 874
Type: l1tf
class-ID: 0300
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Local Storage: total: 223.57 GiB used: 12.06 GiB (5.4%)
used: 12.04 GiB (9.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 5673-6400
System Temperatures: cpu: 52.0 C mobo: 29.8 C
Processes: 219 Uptime: 4m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1146 lib: 324 flatpak: 0 Shell: Zsh
What could I do now ? On my side, I will buy a new cable and verify on another computer if ethernet works. What about having another distro next to Manjaro in case of problem ? I don’t want to reinstall windows…
Maybe, try to install the R8168 driver ( r8168-dkms 8.049.02-1) and blacklist the R8169 driver. Make sure that you have the appropriate kernel headers installed.
EOL = End of Life
You can see the lifespans of kernels on kernel.org .
You can also try the newest kernel we have to see if it has drivers built in that fixes the issue.
Also maybe something here can help:
Hello. It appears it comes from the router of my accomadation provider (not much details). Thank you anyway, I have learned a bit.
system
Closed
12 October 2021 21:56
9
