Newbie who is unfamiliar with a lot of terminology here. I installed the linux65 kernel and restarted, and my internet completely stopped working. I connect an ethernet cable to a wifi extender. I tried downgrading to different kernels but it was still not working.
ip link isn’t showing anything.
journalctl -u NetworkManager.service
gave me this:
Oct 14 21:51:28 reissecomputer systemd[1]: Starting Network Manager...
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.6756] NetworkManager (version 1.38.4-1) is starting... (for the first time)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.6761] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Oct 14 21:51:28 reissecomputer systemd[1]: Started Network Manager.
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.6780] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.6846] manager[0x563dc5176020]: monitoring kernel firmware directory '/lib/firmware'.
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7305] hostname: hostname: using hostnamed
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7305] hostname: static hostname changed from (none) to "reissecomputer"
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7308] dns-mgr[0x563dc5153270]: init: dns=default,systemd-resolved rc-manager=symlink
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7380] manager[0x563dc5176020]: rfkill: Wi-Fi hardware radio set enabled
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7380] manager[0x563dc5176020]: rfkill: WWAN hardware radio set enabled
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7539] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.38.4-1/libnm-device-plugin-team.so)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7565] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.38.4-1/libnm-device-plugin-wifi.so)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7586] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.38.4-1/libnm-device-plugin-adsl.so)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7616] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.38.4-1/libnm-device-plugin-wwan.so)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7627] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.38.4-1/libnm-device-plugin-ovs.so)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7660] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.38.4-1/libnm-device-plugin-bluetooth.so)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7664] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7665] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7666] manager: Networking is enabled by state file
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7680] settings: Loaded settings plugin: keyfile (internal)
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <warn> [1665798688.7702] keyfile: load: "/etc/NetworkManager/system-connections/Auto Ethernet.nmconnection": failed to load connection: invalid connection: connection.type: property is missing
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7711] dhcp-init: Using DHCP client 'internal'
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7711] device (lo): carrier: link connected
Oct 14 21:51:28 reissecomputer NetworkManager[1169]: <info> [1665798688.7713] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
I’m not sure what that warn thing means but it was in yellow so it must be important.
