After a reboot yesterday, my internet stopped working. I have tried a lot of solutions online, but after the whole day, it is still not working. I have tried switching users, but it does not work for both users. Additionally, network runs well on my boot USB, so it shouldn’t be a problem with my net card.
nmcli connection show
NAME UUID TYPE DEVICE
br-4bc4667df2e7 [a bit long to type] bridge *same as NAME*
br-4daaa69d574d bridge *same as NAME*
docker0 bridge *same as NAME*
enp2s0 ethernet *same as NAME*
Wired connection 1 ethernet --
journalctl -fu systemd-resolved.service
[the time] [hostname] systemd-resolved[10287]: Using degraded feature set UDP instead of UPD+EDNS0 for DNS server 208.67.222.222
... Some more similar messages
[the time] [hostname] systemd-resolved[10287]: Failed to send hostname reply: Transport endpoint is not connected
... repeats
/etc/NetworkManager/NetworkManager.conf
[main]
plugins=keyfile
[device]
wifi.scan-rand-mac-address=no
/etc/NetworkManager/conf.d/20-rc-manager.conf
[main]
rc-manager=resolvconf
/etc/NetworkManager/conf.d/99-dont-touch-my-dns.conf
[main]
dns=none
System info:
- Realtek RTL8125 2.5GbE
- Driver: “r8169”
- Driver Modules: “r8169”
Sorry if I gave too little input, since I cannot connect to the internet, I have to type the output from my laptop. Feel free to ask for other output, I will be willing to type them if they could be helpful to solve my problem!
Thanks in advance.
Edit 1:
I have found that there should be network, but it is like less than 1KB/s, so it barely works. When I try pamac install linux515-headers
, it outputs Temporary failure in name resolution
of all of my mirrors. I then try sudo pacman-mirrors --fasttrack
, then the output is WARNING https://repo.manjaro.org/ 'Connection: HTTPSConnectionPool(host='repo.manjaro.org, port=443): Max entries exceeded with url: / (Caused by NewConnectionError('urllib3.connection.HTTPSConnection object at <0x7f0dd0d15e70>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
Is this a problem with DNS Configuration? If so, how do I fix it?
