Greetings.
I’ve never had a problem with Manjaro for almost two years, but ethernet. This ethernet issue would appear once in a while and I have no idea what it wants. Don’t know for sure why it showed up this time(I guess after system update) and why it disappeared in the past.
I prefer to use wired ethernet connection on my laptop Hp probook 430 g5. No issues with wi-fi though.
Some outputs of commands from wiki.
lspci (ethernet part):
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Hewlett-Packard Company Device 8377
Flags: bus master, fast devsel, latency 0, IRQ 140
I/O ports at 3000 [size=256]
Memory at f0304000 (64-bit, non-prefetchable) [size=4K]
Memory at f0300000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: r8168
dmesg | grep r8168:
[ 13.864746] r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
[ 13.879391] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 13.881401] r8168 Copyright © 2020 Realtek NIC software team nicfae@realtek.com
[ 14.889409] r8168 0000:01:00.0 enp1s0: renamed from eth0
[15070.183385] r8168: enp1s0: link up
[15071.207123] r8168: enp1s0: link down
[15079.543133] r8168: enp1s0: link up
[15080.566820] r8168: enp1s0: link down
[15088.912902] r8168: enp1s0: link up
[15089.926589] r8168: enp1s0: link down
[15099.312669] r8168: enp1s0: link up
[15100.336324] r8168: enp1s0: link down
[15108.662362] r8168: enp1s0: link up
[15109.686084] r8168: enp1s0: link down
modinfo r8168:
filename: /lib/modules/4.19.138-1-MANJARO/extramodules/r8168.ko.gz
version: 8.048.03-NAPI
license: GPL
description: RealTek RTL-8168 Gigabit Ethernet driver
author: Realtek and the Linux r8168 crew netdev@vger.kernel.org
srcversion: 3D290B8867C584C2920F0E4
alias: pci:v00001186d00004300sv00001186sd00004B10bcsci*
alias: pci:v000010ECd00002600svsdbcsci*
alias: pci:v000010ECd00002502svsdbcsci*
alias: pci:v000010ECd00008161svsdbcsci*
alias: pci:v000010ECd00008168svsdbcsci*
depends:
retpoline: Y
vermagic: 4.19.138-1-MANJARO SMP mod_unload
parm: speed_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: duplex_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: autoneg_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: advertising_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: aspm:Enable ASPM. (int)
parm: s5wol:Enable Shutdown Wake On Lan. (int)
parm: s5_keep_curr_mac:Enable Shutdown Keep Current MAC Address. (int)
parm: rx_copybreak:Copy breakpoint for copy-only-tiny-frames (int)
parm: use_dac:Enable PCI DAC. Unsafe on 32 bit PCI slot. (int)
parm: timer_count:Timer Interrupt Interval. (int)
parm: eee_enable:Enable Energy Efficient Ethernet. (int)
parm: hwoptimize:Enable HW optimization function. (ulong)
parm: s0_magic_packet:Enable S0 Magic Packet. (int)
parm: debug:Debug verbosity level (0=none, …, 16=all) (int)
