Ethernet cap at 100 mbit/s
Hey,
3 months ago my isp upgraded my internet from 100 mbit to 300 mbit.
Everything was working fine until it got capped out of nowhere to 100 mbit since 2 months. My Router says 337 mbit are available from my isp and also my WLAN connected smartphone has über 170 mbit/s.
Linux says it’s max. 100 mbit?
Can someone help me with this out? :slight_smile:
What does it say - and where does it say it?
How did you acquire that information?
All of my download rate and speed tests are limited to 100 mbit/s
Also this screenshot:
“Network”
“Wired connection”
You are using a wired connection.
It appears that either your routers network adapter or the one in your machine (or both) are only rated at 100 mbit//s
It may also be a bad quality cable, preventing the two partners to negotiate a higher speed.
It is very likely simply a hardware limitation on one of the devices.
For instance:
I know that my Laptop’s ethernet adapter can only do 100 Mbit/s max. (it’s not the newest with being more than 10 years old …)
My router can do much more (1 Gbit/s I think) - but I simply can’t make use of that with this laptop’s built in ethernet adapter.
What happens when you click on the “Configure” icon (highlighted in red below)?
Screenshot_20241014_204948
But the weird thing is, it was working 2 months before :open_mouth:
Here is my terminal output:
vendor: ASRock driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac:
IF-ID-1: nm-bridge state: up speed: 100 Mbps duplex: unknown mac:
IF-ID-2: virbr0 state: down mac:
Only details but nothing to configure accroding to network speed.
Please provide the full output of:
inxi --admin --verbosity=8 --filter --no-host --width
This will help to understand your hardware capabilities.
It may be that updating you BIOS may improve things; see the hardware manufacturer website for details.
Updating your kernel can potentially help; or, in this case, reverting to kernel 6.6 (LTS), 6.1 (LTS) or possibly even older, depending on the age of your machine.
We can only guess until you provide more information.
Cheers.
The only thing I can say is:
my router has got 4 ports (I believe) (Fritz!Box 6660)
only one of them is capable of delivering gigabit speeds - and/or it can be set via the configuration interface of the box which port is which …)
if it is the same for you - perhaps you used the wrong port?
… it’s all speculation
@soundofthunder asked for hardware info …
here is the full output
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=81ta10d6-a1a0-4126-9eaf-7c2e41a86ad9 rw amd_iommu=on iommu=pt
    quiet
    cryptdevice=UUID=116dc45b-3ae6-48ff-b479-01ac66ee253a:luks-116dc25b-3ae6-48ff-b479-01ac66ee253a
    root=/dev/mapper/luks-116dc25b-3ae6-48ff-b479-01ac66ee253a splash
  Desktop: GNOME v: 46.5 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 43.0 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: P2.40 date: 10/19/2022
  System RAM: total: 16 GiB available: 15.54 GiB used: 10.45 GiB (67.2%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMW16GX4M2C3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 1863 min/max: 2200/4208 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1863 2: 1863 3: 1863
    4: 1863 5: 1863 6: 1863 7: 1863 8: 1863 9: 1863 10: 1863 11: 1863 12: 1863
    bogomips: 86275
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GT218 [GeForce 210] vendor: Micro-Star MSI N210
    driver: nouveau v: kernel non-free: series: 340.xx
    status: legacy (EOL~2019-12-xx) last: release: 340.108 kernel: 5.4
    xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-2013 pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 link-max: lanes: 16 ports: active: none
    empty: DVI-I-1,HDMI-A-1,VGA-1 bus-ID: 03:00.0 chip-ID: 10de:0a65
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600
    OEM/5600 XT / 5700/5700 XT] vendor: XFX Pine driver: amdgpu v: kernel
    arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: DP-3,HDMI-A-2 bus-ID: 07:00.0 chip-ID: 1002:731f class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Idek Iiyama PL2530H serial: <filter> built: 2017
    res: 1920x1080 dpi: 90 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
    x: 0.325 y: 0.627 blue: x: 0.157 y: 0.075 white: x: 0.314 y: 0.329
    size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9
    modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1152x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
  Monitor-2: DP-2 model: Idek Iiyama PL2530H serial: <filter> built: 2017
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
    device: 0 egl: 1.4 drv: nouveau device: 1 drv: radeonsi device: 2 drv: swrast
    gbm: egl: 1.4 drv: nouveau surfaceless: egl: 1.4 drv: nouveau wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 3.3 vendor: amd mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 18.1.8 DRM 3.57 6.10.13-3-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 24.2.4-arch1.0.1
    device-ID: 1002:731f surfaces: xcb,xlib,wayland
  Device-1: NVIDIA High Definition Audio vendor: Micro-Star MSI N210 Geforce
    210 PCIe driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 4 link-max: lanes: 16 bus-ID: 03:00.1 chip-ID: 10de:0be3
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 07:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Kingston HyperX 7.1 Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0951:16a4 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: nm-bridge state: up speed: 100 Mbps duplex: unknown mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  Device-1: luks-116dc25b-3ae6-48ff-b479-01ac66ee253a maj-min: 254:0
    type: LUKS dm: dm-0 size: 465.46 GiB
  Components:
  p-1: sdd2 maj-min: 8:50 size: 465.46 GiB
  Local Storage: total: 3.18 TiB used: 950.6 GiB (29.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM014-1EJ164
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SM30 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 045
  ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT500MX500SSD4
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 370.98 GiB (81.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-116dc25b-3ae6-48ff-b479-01ac66ee253a label: N/A
    uuid: 810a10d6-a1a0-4126-9eaf-7b2e41a86ad9
    used: 472 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: N/A
    uuid: 8BCB-3F0D
  ID-3: /media/Backup raw-size: 474.64 GiB size: 466.12 GiB (98.21%)
    used: 171.99 GiB (36.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 8d6fe3d5-d01-4f71-b90d-98636455f85f
  ID-4: /mnt/0a57ec5f-db0a-45e4-91ed-9617990ccd7a raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 407.63 GiB (44.5%) fs: ext4 dev: /dev/sdc
    maj-min: 8:32 label: Games uuid: 0a57ec5f-db0a-45e4-91ed-9617990ccd7a
  ID-1: /dev/sda1 maj-min: 8:1 size: 456.88 GiB fs: ext4 label: N/A
    uuid: b3ce8a5f-06f1-4829-94be-fb8dede53e76
  ID-2: /dev/sdb1 maj-min: 8:17 size: 814.8 GiB fs: ntfs label: Volume
    uuid: B0388FFB388FBF3A
  ID-3: /dev/sdb2 maj-min: 8:18 size: 116.71 GiB fs: ext4 label: N/A
    uuid: 4f4a3de5-f0c6-49d7-af54-482a3503bd9a
  Device-1: 1-1:2 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
  Device-2: 1-10:3 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Device-1: 3-3:2 info: Logitech G910 Orion Spectrum Mechanical Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c335 class-ID: 0300 serial: <filter>
  Device-2: 3-4:3 info: Kingston HyperX 7.1 Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    chip-ID: 0951:16a4 class-ID: 0300 serial: <filter>
  System Temperatures: cpu: 36.5 C mobo: 32.0 C
  Fan Speeds (rpm): fan-1: 976 fan-2: 1636 fan-3: 0 fan-4: 962 fan-5: 928
    fan-6: 0 fan-7: 931
  GPU: device: nouveau temp: 40.0 C mV: 900.00 device: amdgpu temp: 52.0 C
    mem: 58.0 C fan: 0 watts: 24.00
  Packages: 1761 pm: dpkg pkgs: 0 pm: pacman pkgs: 1715 libs: 388
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 46
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    5: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 418
  1: cpu: 68.1% command: pamac-manager pid: 34409 mem: 877.4 MiB (5.5%)
  2: cpu: 22.3% command: rider pid: 31296 mem: 2413.0 MiB (15.1%)
  3: cpu: 11.6% command: gnome-characters started-by: gjs-console pid: 34403
    mem: 220.1 MiB (1.3%)
  4: cpu: 10.3% command: gnome-clocks pid: 34407 mem: 48.6 MiB (0.3%)
  5: cpu: 9.9% command: nautilus pid: 34405 mem: 73.3 MiB (0.4%)
  Memory top: 5 of 418
  1: mem: 2413.0 MiB (15.1%) command: rider pid: 31296 cpu: 22.3%
  2: mem: 2299.5 MiB (14.4%) command: Rider.Backend pid: 31369 cpu: 6.6%
  3: mem: 877.4 MiB (5.5%) command: pamac-manager pid: 34409 cpu: 68.1%
  4: mem: 598.8 MiB (3.7%) command: ./jetbrains-toolbox pid: 2332 cpu: 2.5%
  5: mem: 499.1 MiB (3.1%) command: brave pid: 4230 cpu: 4.4%
  Processes: 418 Power: uptime: 2h 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.36
    ~/.config/JetBrains/Rider2024.2 
This can be the reason maybe, yes
Please use the </> button when pasting command output to avoid great walls of text like the one you just posted. Thanks.
To fix that post, please edit it and place three (3) backtick characters both before and after the text:
[Assume this is your great wall of text]
This will achieve the same result; and those trying to help won’t have to scroll to Antarctica and back to find anything useful.
Cheers.
I assume you are running Gnome, as I had a look at one of your previous topics. This means you should have nm-connection-editor installed.
Open nm-connection-editor from a terminal. You should then see a GUI listing your network connections. Double-click on the connection in the “Ethernet” section. The default name will be something like enp1s0 (edit: enp4s0 according to your inxi output) - something that starts with an “e” (for ethernet). You should then see the settings for that connection - this is what mine looks like (I am running nm-connection-editor in Plasma):
You probably have the link negotiation set to “Ignore”, which is the default setting.
Ignoring link negotiation
In this case, NetworkManager ignores link configuration for an ethernet connection, keeping the already configuration on the device.
Try changing that to “Automatic”. If those options are not available to you as a normal user, then you may have to open nm-connection-editor using sudo to access the settings. Automatic negotiation should (hopefully) pick up the higher speed you now have. You might need to reboot, or at least disconnect & reconnect the ethernet connection for it renegotiate.
If worst comes to worst, there is also the option to manually set the speed. That should probably be a last resort, as it is easy to mess up the settings. You might want to have a read of this before making any changes:
Done :slight_smile:
All of my LAN-Ports can provide 1 gbit/s
OMFG, the reason was the cable from the router to the pc --__–
… and I was just about to mention this as the possible cause once again … :ok_hand:
Ohh haha, now the question is, which person did change the cable :open_mouth:
… if dogs can eat the homework, perhaps they can change cables, too? :upside_down_face:
Hahaha, maybe :open_mouth:
