Hi all
I have a (pretty) recent install of Manjaro with i3wm. Today I tried to connect via cable because the wifi signal in my room is not so great, but to my dissapointment, I could not connect to the internet. This might be the first time I try to connect via ethernet so it might have never worked in the first place.
Some things I have ruled out:
- It is not a router problem, connecting another (windows that is) pc to the port works fine
- It is most probably a physical problem in my laptops ethernet port, since this did work on previous OS’es
- My wifi does work and can connect to the internet normally
I will give some info commands, keep in mind I’m switching from wifi to ethernet and back to do these commands and write here. To clarify, pinging to 8.8.8.8 does not work.
inxi -v7azy
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c62eec07-b7d4-4b9d-9bef-d0ab1e8a9a0b rw quiet apparmor=1
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 82K1 v: IdeaPad Gaming 3 15IHU6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IHU6
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: H4CN23WW(V1.08) date: 02/11/2022
ID-1: BAT1 charge: 40.1 Wh (97.8%) condition: 41.0/45.0 Wh (91.2%)
volts: 12.9 min: 11.5 model: SMP L20M3PC2 type: Li-ion serial: <filter>
status: not charging cycles: 217
System RAM: available: 15.41 GiB used: 3.25 GiB (21.1%)
Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x2A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2827 high: 3313 min/max: 400/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 3200 2: 1623 3: 3214
4: 3232 5: 3215 6: 2252 7: 2571 8: 3313 bogomips: 51008
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 174f:244c
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a driver:
X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: MSI MP241
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x09d2 built: 2020
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off with: a2jmidid status: off
tools: qjackctl
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues?
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:8 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 286.95 GiB (60.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
lanes: 4 tech: SSD serial: <filter> fw-rev: C01C temp: 32.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 286.94 GiB (61.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c62eec07-b7d4-4b9d-9bef-d0ab1e8a9a0b
used: 14.3 MiB (4.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BEE2-6799
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-1:12 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Device-1: 1-1.1:13 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
Device-2: 1-1.4:14 info: Apple Aluminium Keyboard (ANSI) type: keyboard,HID
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 05ac:024f class-ID: 0300
Device-3: 1-2:3 info: Yubicom Yubikey 4/5 OTP+U2F type: keyboard,HID
lanes: 1 mode: 1.1 power: 30mA chip-ID: 1050:0403 class-ID: 0300
Device-4: 1-6:5 info: Syntek Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
Device-5: 1-8:7 info: Integrated Express ITE Device(8176) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c966 class-ID: 0301
Device-6: 1-10:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 253 Uptime: 25m wakeups: 1 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1548 libs: 400 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: termite inxi: 3.3.27
next I ran when switching from wifi to ethernet:
journalctl -fu NetworkManager.service
Jun 17 21:30:09 wout-pc6 NetworkManager[713]: <info> [1687030209.7994] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Jun 17 21:30:09 wout-pc6 NetworkManager[713]: <info> [1687030209.9527] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.1.36
Jun 17 21:30:09 wout-pc6 NetworkManager[713]: <info> [1687030209.9575] device (wlp0s20f3): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jun 17 21:30:09 wout-pc6 NetworkManager[713]: <info> [1687030209.9580] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jun 17 21:30:09 wout-pc6 NetworkManager[713]: <info> [1687030209.9582] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jun 17 21:30:09 wout-pc6 NetworkManager[713]: <info> [1687030209.9643] device (wlp0s20f3): Activation: successful, device activated.
Jun 17 21:30:58 wout-pc6 NetworkManager[713]: <info> [1687030258.1675] device (enp2s0): state change: activated -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
Jun 17 21:30:58 wout-pc6 NetworkManager[713]: <info> [1687030258.1687] audit: op="device-disconnect" interface="enp2s0" ifindex=2 pid=1223 uid=1000 result="success"
Jun 17 21:30:58 wout-pc6 NetworkManager[713]: <info> [1687030258.2077] device (enp2s0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
Jun 17 21:30:58 wout-pc6 NetworkManager[713]: <info> [1687030258.2340] policy: set 'WiFi-2.4-0498' (wlp0s20f3) as default for IPv4 routing and DNS
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3112] device (enp2s0): Activation: starting connection 'enp2s0' (0e493875-7a52-45cd-b484-240d44bdccda)
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3113] audit: op="connection-activate" uuid="0e493875-7a52-45cd-b484-240d44bdccda" name="enp2s0" pid=1223 uid=1000 result="success"
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3113] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3115] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3118] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3120] manager: NetworkManager state is now CONNECTING
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3121] policy: set 'enp2s0' (enp2s0) as default for IPv4 routing and DNS
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3126] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3441] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3442] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3443] manager: NetworkManager state is now CONNECTED_GLOBAL
Jun 17 21:31:11 wout-pc6 NetworkManager[713]: <info> [1687030271.3444] device (enp2s0): Activation: successful, device activated.
And lastly the output of:
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether e4:a8:df:c5:d6:b3 brd ff:ff:ff:ff:ff:ff
inet 192.168.3.3/24 brd 192.168.3.255 scope global noprefixroute enp2s0
3: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether c4:75:ab:3c:52:e9 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.36/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp0s20f3
valid_lft 3486sec preferred_lft 3486sec
inet6 fe80::1db1:e68b:aa63:b8c9/64 scope link noprefixroute
I hope this is enough information (for now) and I thank you in advance for your help!
Greetings
