I recently bought an Asus Tuf A15 with a Ryzen 5800h and an RTX3060
The issue I’m facing is that after boot, neither wired nor wireless network works. Strangely enough Wired starts working if I plug in the power instead of running on Battery, even if I unplug the power afterwards. Wireless however never works. However… I distinctly remember Wireless also worked in the past for some reason. The Laptop is very new and I have done more or less nothing other than installing manjaro and updating everything.
Note that I am dual booting with Windows
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e703a267-cd8b-4025-a1d4-b7842531b706 rw quiet apparmor=1
security=apparmor resume=UUID=9a50511d-8ac8-46a7-bc8b-4983efc1b16a
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_FA506QM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: FA506QM.307 date: 06/02/2021
ID-1: BAT1 charge: 88.5 Wh (95.0%) condition: 93.2/90.2 Wh (103.2%)
volts: 17.2 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: Unknown
RAM: total: 30.77 GiB used: 1.47 GiB (4.8%)
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L2: 4 MiB bogomips: 102254
Speed: 1197 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz):
1: 1197 2: 1216 3: 1196 4: 1198 5: 1197 6: 1197 7: 1198 8: 1196 9: 1197
10: 1197 11: 1197 12: 1197 13: 1197 14: 1197 15: 1197 16: 1197
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: N/A alternate: nouveau bus-ID: 01:00.0 chip-ID: 10de:2520
class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 322e:202c class-ID: 0e02
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.8-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK vendor: AzureWave driver: N/A modules: mt7921e port: e000
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 942.7 GiB used: 9.48 GiB (1.0%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 211070WD temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 442.72 GiB size: 434.7 GiB (98.19%) used: 9.48 GiB (2.2%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:8 label: N/A
uuid: e703a267-cd8b-4025-a1d4-b7842531b706
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
label: NO_LABEL uuid: FC25-30F0
ID-1: swap-1 type: partition size: 33.92 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p3 maj-min: 259:9 label: N/A
uuid: 9a50511d-8ac8-46a7-bc8b-4983efc1b16a
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: B03A-CFA6
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 244.45 GiB fs: ntfs label: N/A
uuid: A418449318446680
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 508 MiB fs: ntfs label: N/A
uuid: C62E32F52E32DE5D
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 220.7 GiB fs: ntfs
label: New Volume uuid: BE58EF3458EEEA5B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-4:2 info: Sonix USB2.0 HD UVC WebCam type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: IMC Networks Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 60.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): cpu: 2300
Processes: 307 Uptime: 20m wakeups: 520 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1192 lib: 327 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.06
Any ideas why ethernet needs power to turn on and wifi doesn’t work?
