So, I am planing mine on my desktop PC with dedicated PRO graphics card (meaning one for daily usage and one for mining, both cards from AMD-preventing major driver issues).
I am planing using this graphics card:
AMD Radeon PRO WX 3200 4GB from HP
Now my question is:
How to configure the system and software to prevent mix ups and breakdowns?
I was playing around and got my laptop to “dig” for Etherium using Ethminer GitHub - ethereum-mining/ethminer: Ethereum miner with OpenCL, CUDA and stratum support it is available in AUR repository.
HOWEVER, you will need a GPU with higher VRAM than 4GB to get it to work… found that out the hard way.
How to connect to pool and miner can be found out here ethminer/POOL_EXAMPLES_ETH.md at master · ethereum-mining/ethminer · GitHub
I have no idea how to configure the system and software to prevent mix-ups and breakdowns, but being on rolling-distro might not be the smartest idea if you want to dig coin.
Alternatively you can mine bitcoin using Nicehash by using Nuxhash GitHub - YoRyan/nuxhash: A NiceHash cryptocurrency mining client for Linux. (basically copy/paste sudo pip command). It is painfully slow, but for some reason I can haz Bitcoin using this on my GTX 1050 mobile (which is absurd and not beneficial).
Thank you
Another question:
Compatibility with Go Ethereum and Etherwall?
These are questions that should be asked crypto forums I believe.
