Etherape issue with shared library
Hello everyone,
Brief intro on my behalf,
Been using Manjaro for 2 years now & loving it, but, still not that comfortable with Linux … Always solved any issue i had by looking in forums .
This issue i couldnt find a thing, so made an account … wasn´t sure in what section to make it, so i droped it here…
Got an issue with etherape after this last update.
kernel is 4.19
etherape: error while loading shared libraries: libgoocanvas-2.0.so.9: cannot open shared object file: No such file or directory
Thought i could solve it by reinstalling it …
sudo pacman -R etherape
sudo pacman -Syu && sudo pacman -S etherape
sudo etherape
epic fail :upside_down_face:, got same msg …
Any ideas ?
@nightmare-2021 eitherape needs a rebuild against goocanvas 3.0.0.
Rebuild is done
thx for replying.
And on my end ? im a bit unexperienced, especially withthese kind of things.
What am i supposed to do ?
Some help ? pls :slightly_smiling_face:
I feel this is so so so above my paygrade …nevertheless, my 2 …bits…
they updated libgoocanvas, and now etherape needs it to run… thats clear, its a shared library and now i need to compile etherape again ?
$ whereis etherape
$ ldd -v /usr/bin/etherape
i get a huuge output & dont see any libgoocanvas 3.0.0-1 …
& now i do what ?
etherape 0.9.19-2 is now available in all branches so you’ll see the update when your mirror has it.
Thx for your reply
This morning, when i saw both your replies, i did a sudo pacman -Syu & got nothing… did another after i saw your reply and just got an kiconthemes update …
But now i know its just a question of waiting …
Thx again :slightly_smiling_face:
P.S. i stopped at ldd -r /usr/bin/etherape
