Establishing connection to PulseAudio. Please wait
I installed Manjaro XFCE 22.1.0 in my Desktop PC, but audio does not work in my PC. Please help me to find out solution to it.
When I open volume control, it blinks so fast that I cannot have access to any tab such as configuration, playback, etc. I just see “Establishing connection to PulseAudio. Please wait.”
I ran many commands, but none of them worked.
Sound works fine in Windows 10.
Can you post the output of inxi -A
In addition to the above (inxi -A).:
  1. check the journalctl -b and ~/.xsession-errors
  2. execute pavucontrol from a shell. I’m assuming it will fail but there will be error messages written to your terminal. These would also be in one of the sources in #1.
The output of inxi -A is as follows :-
Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
better is inxi -Aa
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:27d8 class-ID: 0403
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
Is it possible to turn off PulseAudio and turn on PipeWire so that problem may be resolved?
Message “Establishing connection to PulseAudio. Please wait.” in PulseAudio Volume control shows the mixer GUI is unable to contact PulseAudio
Please post more information about PulseAudio
systemctl --user -l --no-pager status pulseaudio.{socket,service}
and this to show if audio devices are detected in ALSA correctly
sudo alsa-info.sh --with-dmesg --with-aplay --with-amixer | curl -F 'clbin=<-' https://clbin.com
(New users are not permitted to post active links, but an inactive link to uploaded data can be created using Preformatted text </> button, to avoid forum spam filter)
Replacing PulseAudio with PipeWire might resolve audio issue if it is within PulseAudio, but PipeWire cannot resolve any issue with ALSA audio devices or audio GUI controls
IMO opinion it would be better to turn off PulseAudio (assuming it is shown as active from previous data):
systemctl --user stop pulseaudio.{socket,service}
and determine if audio playback direct to ALSA is working.
I suggest using Audacious with audio settings configured to use ALSA plugin playing direct to card 0
● pulseaudio.socket - Sound System
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; preset: enabled)
     Active: active (running) since Fri 2023-04-21 09:17:54 IST; 9min ago
   Triggers: ● pulseaudio.service
     Listen: /run/user/1000/pulse/native (Stream)
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.socket
Apr 21 09:17:54 vishnuji systemd[854]: Listening on Sound System.
● pulseaudio.service - Sound Service
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
     Active: active (running) since Fri 2023-04-21 09:18:00 IST; 9min ago
TriggeredBy: ● pulseaudio.socket
   Main PID: 1042 (pulseaudio)
      Tasks: 9 (limit: 2320)
     Memory: 8.9M
        CPU: 34.096s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
             ├─1042 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─1144 /usr/lib/pulse/gsettings-helper
Apr 21 09:17:58 vishnuji systemd[854]: Starting Sound Service...
Apr 21 09:18:00 vishnuji pulseaudio[1042]: stat('/etc/pulse/default.pa.d'): No such file or directory
Apr 21 09:18:00 vishnuji systemd[854]: Started Sound Service.
Apr 21 09:18:25 vishnuji pulseaudio[1042]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
When I executed sudo alsa-info.sh --with-dmesg --with-aplay --with-amixer | curl -F ‘clbin=<-’ https://clbin.com, I received the following message :-
/usr/bin/alsa-info.sh: line 661: tree: command not found
Please help me to find out problem. I suspect there is an issue due to audio driver,
No evidence so far to support this suspicion
Please post more information about audio drivers and hardware
sudo alsa-info.sh --upload
Warning message about tree command is not unusual on Manjaro and should not prevent alsa-info script from gathering and uploading diagnostic data
forum.manjaro.org/search — line 661: tree: command not found
Uploading information to www.alsa-project.org ... Done!
Your ALSA information is located at http://alsa-project.org/db/?f=2b71b7b7be6b8bceb00e6b1198256e3b477d9992
Please inform the person helping you.
Apr 21 21:41:15 vishnuji systemd[852]: Failed to start Sound Service.
Apr 21 21:41:15 vishnuji systemd[852]: pulseaudio.service: Scheduled restart jo>
Apr 21 21:41:15 vishnuji systemd[852]: Stopped Sound Service.
Apr 21 21:41:15 vishnuji systemd[852]: pulseaudio.service: Start request repeat>
Apr 21 21:41:15 vishnuji systemd[852]: pulseaudio.service: Failed with result '>
[vishnuji@vishnuji ~]$ pulseaudio --check
[vishnuji@vishnuji ~]$ pulseaudio --start
[vishnuji@vishnuji ~]$ sudo systemctl restart sound.service
Failed to restart sound.service: Unit sound.service not found.
ALSA data shows onboard audio device Realtek ALC887-VD detected correctly
But ALSA mixer data shows analog outputs for Headphone and Front speaker are muted
and Auto-Mute Mode is enabled to mute speaker output when headphones are plugged in
!!-------Mixer controls for card Intel
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Limits: Playback 0 - 64
  Mono:
  Front Left: Playback 0 [0%] [-64.00dB] [off]
  Front Right: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'Front',0
  Mono:
  Front Left: Playback 64 [100%] [0.00dB] [off]
  Front Right: Playback 64 [100%] [0.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
I suggest disable Auto-Mute and unmute both Front speaker and Headphone outputs
amixer --card=0 sset 'Auto-Mute Mode' Disabled
amixer --card=0 sset 'Headphone' 64 unmute
amixer --card=0 sset 'Front' 64 unmute
That should at least get audio working in ALSA
If PulseAudio is still not working as expected, I suggest delete user configuration:
rm ~/.config/pulse/*
reboot system
and check status of pulseaudio.socket and pulseaudio.service again
  Capabilities: enum
  Item0: 'Disabled'
  Mono:
  Front Left: Playback 64 [100%] [0.00dB] [on]
  Front Right: Playback 64 [100%] [0.00dB] [on]
  Mono:
I also deleted the file by executing the command rm ~/.config/pulse/*, but problem still persists.
No. My problem is not resolved.
!!ALSA Information Script v 0.5.1
!!Script ran on: Wed Apr 26 14:58:53 UTC 2023
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      OEM
Product Name:      OEM
Product Version:   OEM
Firmware Version:  6.00 PG
System SKU:
Board Vendor:
Board Name:
!!ACPI Device Status Information
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0A08:00/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/device:02/status 	 15
/sys/bus/acpi/devices/device:03/status 	 15
/sys/bus/acpi/devices/device:04/status 	 15
/sys/bus/acpi/devices/device:05/status 	 15
/sys/bus/acpi/devices/device:06/status 	 15
/sys/bus/acpi/devices/device:07/status 	 15
/sys/bus/acpi/devices/device:08/status 	 15
!!Kernel Information
Kernel release:    6.1.25-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k6.1.25-1-MANJARO
Library version:    1.2.8
Utilities version:  1.2.8
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [Intel          ]: HDA-Intel - HDA Intel
                      HDA Intel at 0xfdff8000 irq 25
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation NM10/ICH7 Family High Definition Audio Controller [8086:27d8] (rev 01)
	Subsystem: Intel Corporation DeskTop Board D945GTP [8086:27d8]
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	ctl_dev_id : N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 1
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC887-VD
Address: 2
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0887
Subsystem Id: 0x10ec0887
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC887-VD Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
  Amp-Out vals:  [0x00 0x00]
  Converter: stream=5, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  Converter: stream=5, channel=4
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Converter: stream=5, channel=2
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Side Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
  Device: name="ALC887-VD Digital", type="SPDIF", device=1
  Digital: Non-Copyright
  Digital category: 0x12
  IEC Coding Type: 0x0
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
  Amp-In vals:  [0x80 0x80]
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=1, device=0
  Control: name="Capture Switch", index=1, device=0
  Device: name="ALC887-VD Alt Analog", type="Audio", device=2
  Converter: stream=0, channel=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  Digital category: 0x0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Rear Mic Playback Volume", index=0, device=0
  Control: name="Rear Mic Playback Switch", index=0, device=0
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Control: name="CD Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=4, ofs=0
  Control: name="CD Playback Switch", index=0, device=0
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=5, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000010: OUT
  Pin Default 0x40338000: [N/A] CD at Ext N/A
    Conn = ATAPI, Color = Purple
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x01014030: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=06, enabled=1
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Switch", index=0, device=0
  Pincap 0x00000036: IN OUT Detect Trigger
  Pin Default 0x01011031: [Jack] Line Out at Ext Rear
    DefAssociation = 0x3, Sequence = 0x1
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=08, enabled=1
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Pin Default 0x01016032: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Orange
    DefAssociation = 0x3, Sequence = 0x2
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=07, enabled=1
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Side Playback Switch", index=0, device=0
  Pin Default 0x01012033: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Grey
    DefAssociation = 0x3, Sequence = 0x3
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=09, enabled=1
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Rear Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00003736: IN OUT Detect Trigger
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19050: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x5, Sequence = 0x0
  Pin-ctls: 0x21: IN VREF_50
  Unsolicited: tag=02, enabled=1
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Pincap 0x0000373e: IN OUT HP Detect Trigger
  Pin Default 0x02a19080: [Jack] Mic at Ext Front
    DefAssociation = 0x8, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=03, enabled=1
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Line Boost Volume", index=0, device=0
  Pin Default 0x01813051: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x5, Sequence = 0x1
  Pin-ctls: 0x20: IN VREF_HIZ
  Unsolicited: tag=04, enabled=1
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
  EAPD 0x2: EAPD
  Pin Default 0x02214040: [Jack] HP Out at Ext Front
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Unsolicited: tag=01, enabled=1
  Connection: 5
     0x0c 0x0d 0x0e 0x0f 0x26*
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
  Pincap 0x00000024: IN Detect
  Pin Default 0x9933105f: [Fixed] CD at Int ATAPI
    Conn = ATAPI, Color = Black
    DefAssociation = 0x5, Sequence = 0xf
  Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x40240887: [N/A] HP Out at Ext N/A
    Conn = RCA, Color = Unknown
    DefAssociation = 0x8, Sequence = 0x7
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pin Default 0x01441070: [Jack] SPDIF Out at Ext Rear
    Conn = RCA, Color = Black
    DefAssociation = 0x7, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
  Pin Default 0x41c46060: [N/A] SPDIF In at Ext Rear
    Conn = RCA, Color = Orange
    DefAssociation = 0x6, Sequence = 0x0
  Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 12
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116,  7 Apr 26 20:04 /dev/snd/controlC0
crw-rw----  1 root audio 116,  6 Apr 26 20:04 /dev/snd/hwC0D2
crw-rw----  1 root audio 116,  3 Apr 26 20:19 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116,  2 Apr 26 20:28 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116,  4 Apr 26 20:04 /dev/snd/pcmC0D1p
crw-rw----  1 root audio 116,  5 Apr 26 20:04 /dev/snd/pcmC0D2c
crw-rw----  1 root audio 116,  1 Apr 26 20:04 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Apr 26 20:04 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Apr 26 20:04 .
drwxr-xr-x 3 root root 220 Apr 26 20:04 ..
lrwxrwxrwx 1 root root  12 Apr 26 20:04 pci-0000:00:1b.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC887-VD Analog [ALC887-VD Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC887-VD Digital [ALC887-VD Digital]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 0: Intel [HDA Intel], device 2: ALC887-VD Alt Analog [ALC887-VD Alt Analog]
  Subdevices: 1/1
!!Amixer output
Card sysdefault:0 'Intel'/'HDA Intel at 0xfdff8000 irq 25'
  Mixer name	: 'Realtek ALC887-VD'
  Components	: 'HDA:10ec0887,10ec0887,00100302'
  Controls      : 55
  Simple ctrls  : 24
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback 0 [0%] [-64.00dB] [off]
  Mono:
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
  Mono:
Simple mixer control 'Front Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Center',0
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
  Mono:
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
Simple mixer control 'CD',0
  Mono:
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Mono:
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 46
  Front Left: Capture 28 [61%] [12.00dB] [on]
  Front Right: Capture 28 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-16.00dB] [off]
  Front Right: Capture 0 [0%] [-16.00dB] [off]
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Rear Mic' 'Front Mic' 'Line' 'CD'
  Item0: 'Front Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Rear Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
!!Alsactl output
--startcollapse--
state.Intel {
	control.1 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
			dbvalue.1 -6400
	control.4 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Center Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
	control.6 {
		iface MIXER
		name 'LFE Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
	control.7 {
		iface MIXER
		name 'Center Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		name 'LFE Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'Side Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.10 {
		iface MIXER
		name 'Side Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
			dbvalue.1 -6400
	control.12 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.13 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.14 {
		iface MIXER
		name 'Rear Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.15 {
		iface MIXER
		name 'Rear Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.16 {
		iface MIXER
		name 'Front Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.17 {
		iface MIXER
		name 'Front Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.18 {
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.19 {
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.20 {
		iface MIXER
		name 'CD Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.21 {
		iface MIXER
		name 'CD Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.22 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.23 {
		iface MIXER
		name 'Input Source'
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Rear Mic'
			item.1 'Front Mic'
			item.2 Line
			item.3 CD
	control.24 {
		iface MIXER
		name 'Input Source'
		index 1
		value 'Rear Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Rear Mic'
			item.1 'Front Mic'
			item.2 Line
			item.3 CD
	control.25 {
		iface MIXER
		name 'Capture Volume'
		value.0 28
		value.1 28
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 46'
			dbmin -1600
			dbmax 3000
			dbvalue.0 1200
			dbvalue.1 1200
	control.26 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.27 {
		iface MIXER
		index 1
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 46'
			dbmin -1600
			dbmax 3000
			dbvalue.0 -1600
			dbvalue.1 -1600
	control.28 {
		iface MIXER
		index 1
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.29 {
		iface MIXER
		name 'Rear Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.30 {
		iface MIXER
		name 'Front Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.31 {
		iface MIXER
		name 'Line Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.32 {
		iface MIXER
		name 'Beep Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.33 {
		iface MIXER
		name 'Beep Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.34 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.35 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.36 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0012000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.37 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.38 {
		iface MIXER
		name 'IEC958 Default PCM Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.39 {
		iface MIXER
		name 'Master Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -6400
			dbmax 0
			dbvalue.0 -6400
	control.40 {
		iface MIXER
		name 'Master Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.41 {
		iface CARD
		name 'Rear Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.42 {
		iface CARD
		name 'Front Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.43 {
		iface CARD
		name 'Line Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.44 {
		iface CARD
		name 'CD Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.45 {
		iface CARD
		name 'Line Out Front Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.46 {
		iface CARD
		name 'Line Out Surround Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.47 {
		iface CARD
		name 'Line Out CLFE Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.48 {
		iface CARD
		name 'Line Out Side Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.49 {
		iface CARD
		name 'Front Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.50 {
		iface CARD
		name 'SPDIF Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.51 {
		iface PCM
		name 'Playback Channel Map'
		value.0 3
		value.1 4
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access read
			type INTEGER
			count 8
			range '0 - 36'
	control.52 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.53 {
		iface PCM
		device 1
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.54 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.55 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
acpi_cpufreq
ata_generic
ata_piix
bpf_preload
ccm
cec
cfg80211
coretemp
crc16
crc32c_generic
crypto_user
dm_mod
drm_buddy
drm_display_helper
ext4
fuse
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
intel_agp
intel_gtt
intel_pmc_bxt
ip_tables
jbd2
joydev
ledtrig_audio
libarc4
libphy
loop
lpc_ich
mac80211
mac_hid
mbcache
mdio_devres
mousedev
mt7601u
ntfs3
pata_acpi
pcspkr
qrtr
r8169
realtek
rfkill
sha512_ssse3
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_timer
soundcore
squashfs
ttm
usbhid
video
wmi
x_tables
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x11 0x40338000
0x12 0x411111f0
0x14 0x01014030
0x15 0x01011031
0x16 0x01016032
0x17 0x01012033
0x18 0x01a19050
0x19 0x02a19080
0x1a 0x01813051
0x1b 0x02214040
0x1c 0x9933105f
0x1d 0x40240887
0x1e 0x01441070
0x1f 0x41c46060
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[    8.288854] intel_powerclamp: No package C-state available
[    8.576191] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC887-VD: line_outs=4 (0x14/0x16/0x15/0x17/0x0) type:line
[    8.576202] snd_hda_codec_realtek hdaudioC0D2:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    8.576206] snd_hda_codec_realtek hdaudioC0D2:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    8.576210] snd_hda_codec_realtek hdaudioC0D2:    mono: mono_out=0x0
[    8.576212] snd_hda_codec_realtek hdaudioC0D2:    dig-out=0x1e/0x0
[    8.576215] snd_hda_codec_realtek hdaudioC0D2:    inputs:
[    8.576218] snd_hda_codec_realtek hdaudioC0D2:      Rear Mic=0x18
[    8.576221] snd_hda_codec_realtek hdaudioC0D2:      Front Mic=0x19
[    8.576223] snd_hda_codec_realtek hdaudioC0D2:      Line=0x1a
[    8.576226] snd_hda_codec_realtek hdaudioC0D2:      CD=0x1c
[    8.596416] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    8.596521] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    8.596612] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    8.596718] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    8.597007] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    8.597117] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    8.597208] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    8.597297] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    8.603987] iTCO_vendor_support: vendor-support=0
http://alsa-project.org/db/?f=7a2a390d5d84d8e77a2023c5467316b6b43d538c
ALSA mixer data shows controls for Master Headphone and Front speaker are muted
and IEC958 Default PCM is enabled to use digital output as default
Simple mixer control ‘IEC958 Default PCM’,0
  Mono: Playback [on]
I suggest
  • Open ALSA controls in alsamixer
    sudo alsamixer -c Intel -V playback
  • Use M to unmute Master, Headphone and Front outputs
    to increase audio levels reset to 0%
    and turn off IEC958 Default PCM
  • Open another terrminal and save ALSA settings
    sudo alsactl store
  • check if audio playback is working via PulseAudio or direct to ALSA outputs
  • reboot system and check if ALSA audio settings are still correct
    amixer -c Intel
  • If audio settings are not as expected use this command to restore them
    sudo alsactl restore
[quote="nikgnomic, post:18, topic:138951"]
turn off **IEC958 Default PCM**
[/quote]
How to turn off IEC958 Default PCM at the terminal?
