hey guys
- I use thunar as a file manager
- I want to use “custom actions” on certain files (Thunar → Edit → Configure Custom Actions…)
- the command I use is:
xfce4-terminal -e "md5sum '%F'" --hold
This works fine, except when the file path or file name contains a space. It just won’t work as intended because the file can then not be found.
I think this is because the spaces in the file path are not automatically escaped
How do I solve this problem?
Thank you in advance
