I am currently using my personal Lenovo laptop with the KDE Plasma DE. Everything is great except that everytime I restart my computer the ‘Esc’ key gets set as the shortcut for the audio volume control widget in my system tray. No matter how many times I go into the shortcut settings and delete this shortcut, or set it to something else, when I restart the ‘Esc’ key is back at it with these shenanigans.
Thanks for the reply. It is indeed the keyboard shortcut you indicated. My Desktop session settings are currently set to ‘Start with an empty session’. I don’t think I ever set the shortcut to be ‘Esc’ but may have accidentally done it at some point.
Thank you so much! This did the trick. Previously, I tried to tinker with ~/.config/kglobalshortcutsrc and set activate widget 9=none,none,Activate Audio Volume Widget but this didn’t really work. After making your suggested edits and restarting, things seem to be back to normal. Thanks again!
