Hi. I am using Manjaro with a KDE Plasma desktop. This is a recent installation, as in this weekend. (Mar. 2-3()
My go-to editors are Gvim in graphical, and vi in the console. No problems for the first little while, but now the ESC key does not take me out of Insert mode.
I just used the menu editor to check keyboard shortcuts for all my applications, not noticing anything untoward. I am a big fan of keyboard shortcuts, and they are one thing I do early after an install.
One thing I did was install neovim and neovimqt with the Add / Remove Software app, but removed them right away with pamac.
I installed vim and Gvim with pamac on the console.
I tried removing Gvim and vim from the console, but after removing Gvim, vim was also gone. ??
I was using the onboard keyboard of my Lenovo ideapad 300 when the problem occurred. I switched to a wireless device and the problem persisted. I booted into Fedora and both keyboards worked fine, with Gvim and vi. I also booted into Mint and again no problems.
My home folder does not have a .vimrc file, and the /etc/vimrc did not shout error to me.
The key combos you suggested will have to stand in for the nonce, thank you kindly for the pointer.
Since both keyboards work as expected when I run other distros, I have to think it is a configuration issue.
I have been using Plasma for quite a while, since Debian Stretch, so I hope I know how to create shortcuts for my apps. Can’t see me doing something odd in that area.
Don’t have a ~/.vimrc,
/etcdefault/keyboard looks normal,
and the /etc/vimrc only has one line in it. => runtime! archlinux.vim
The copy of Manjaro on this computer, a MS Surface Pro 3 runs gvim and vi in a normal manner. Go figure.
