Hello
I get this errors on journal upon boot.
Anything I should worry about?
[jesuslinux@A9410 ~]$ journalctl -p 3 -xb
fev 14 20:31:14 A9410 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem>
fev 14 20:31:14 A9410 kernel: tpm_crb MSFT0101:00: can't request region for resource [mem 0xddc20000-0xddc20fff]
fev 14 20:31:14 A9410 kernel: kfd kfd: amdgpu: STONEY not supported in kfd
fev 14 20:31:16 A9410 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
fev 14 20:31:17 A9410 kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 0
fev 14 20:31:18 A9410 bluetoothd[440]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
fev 14 20:31:18 A9410 bluetoothd[440]: Failed to clear UUIDs: Failed (0x03)
fev 14 20:31:18 A9410 bluetoothd[440]: Failed to add UUID: Failed (0x03)
fev 14 20:31:18 A9410 bluetoothd[440]: Failed to set mode: Failed (0x03)
fev 14 20:31:22 A9410 wpa_supplicant[537]: bgscan simple: Failed to enable signal strength monitoring
fev 14 20:31:39 A9410 lightdm[648]: gkr-pam: unable to locate daemon control file
fev 14 20:31:41 A9410 bluetoothd[440]: Failed to add UUID: Failed (0x03)
fev 14 20:31:46 A9410 bluetoothd[440]: Failed to add UUID: Failed (0x03)
...skipping...
lines 1-27/27 (END)
System info:
[jesuslinux@A9410 ~]$ inxi -zav7
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b9c1fd33-2f73-4159-9a12-ed4859c31e0f rw quiet splash apparmor=1
security=apparmor resume=UUID=4a33bf11-5d98-47c4-96d8-a5f475484937
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: HP product: HP Pavilion Notebook v: N/A
Mobo: HP model: 81FB v: 80.21 serial: <superuser required>
part-nu: X0K19EA#AB9 uuid: <superuser required> UEFI: American Megatrends
v: F.32 date: 04/26/2019
ID-1: BAT0 charge: 26.4 Wh (100.0%) condition: 26.4/26.4 Wh (100.0%)
volts: 8.5 min: 7.7 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full cycles: 237
System RAM: total: 8 GiB available: 7.22 GiB used: 2.37 GiB (32.9%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: Bottom-Slot 1 (left) type: DDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: spec: 2133 MT/s actual: 1866 MT/s volts:
curr: 2 min: 2 max: 2 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471A5143EB0-CPB serial: <filter>
Device-2: Bottom-Slot 2 (right) type: DDR4 detail: synchronous unbuffered
Info: model: AMD A9-9410 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1397 min/max: 1400/2900 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
bogomips: 11582
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload
vgif vmcb_clean vme vmmcall wdt xop xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Sunplus Innovation HP Wide Vision HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:4
chip-ID: 1bcf:2c87 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm4 v: 4.18.0
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0
note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c6 built: 2013 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon R5 Graphics (radeonsi stoney LLVM
16.0.6 DRM 3.54 6.6.10-1-MANJARO) device-ID: 1002:98e4 memory: 500 MiB
unified: no
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:5 chip-ID: 0bda:b008
Local Storage: total: 238.47 GiB used: 153.24 GiB (64.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC600256G
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH61
dev-links: cdrom
ID-1: / raw-size: 99.5 GiB size: 97.38 GiB (97.87%) used: 70.86 GiB (72.8%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: b9c1fd33-2f73-4159-9a12-ed4859c31e0f
ID-2: /boot/efi raw-size: 512.6 MiB size: 511.6 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: B86F-09A6
ID-3: /mnt/AED21046D2101565 raw-size: 129.87 GiB
size: 129.87 GiB (100.00%) used: 82.38 GiB (63.4%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: AED21046D2101565
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 4a33bf11-5d98-47c4-96d8-a5f475484937
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: A20F-4ADA
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 500 MiB fs: ntfs label: N/A
uuid: 101203091202F38E
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.1:3 info: MOSART Semi. 2.4G Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3938:1031 class-ID: 0301
Device-2: 1-1.3:4 info: Sunplus Innovation HP Wide Vision HD type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:2c87 class-ID: 0e02
Device-3: 1-1.4:5 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 61.2 C mobo: N/A gpu: amdgpu temp: 61.0 C
Fan Speeds (rpm): N/A
Processes: 190 Power: uptime: 23m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 2.87 GiB
daemons: xfce4-power-manager,upowerd Init: systemd v: 255
Packages: 1210 pm: pacman pkgs: 1203 libs: 359 tools: pamac pm: flatpak
pkgs: 7 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.32
