Errors logged during the boot process
I am using the latest stable update(2021-11-19) with Gnome41.1 everything works fine, but I see these errors logged while booting. Any suggestions on fixing below errors would be much appreciated!
Hardware:-
Name		: Mi NoteBook Ultra
Vendor		: TIMI
-BIOS-
Date		: 07/14/2021
Vendor		: TIMI
Version		: RMATG5B0P0D0D
-Board-
Vendor		: TIMI
Version		: V1.0
-- Boot a699c8c8c910442986683604f268a378 --
Nov 22 15:06:21 mnu-2021 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.RP09._S0W], AE_ALREADY_EXISTS (20210331/dswload2-326)
Nov 22 15:06:21 mnu-2021 kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210331/psobject-220)
Nov 22 15:06:21 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPD0], AE_NOT_FOUND (20210331/dswload2-162)
Nov 22 15:06:21 mnu-2021 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210331/psobject-220)
Nov 22 15:06:21 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPL1], AE_NOT_FOUND (20210331/dswload2-162)
Nov 22 15:06:21 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C1.TPL1], AE_NOT_FOUND (20210331/dswload2-162)
Nov 22 15:06:21 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C2.TPL1], AE_NOT_FOUND (20210331/dswload2-162)
Nov 22 15:06:21 mnu-2021 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.DGPV], AE_NOT_FOUND (20210331/psargs-330)
Nov 22 15:06:21 mnu-2021 kernel: ACPI Error: Aborting method \_SB.PC00.RP05.PCRP._ON due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
Nov 22 15:06:21 mnu-2021 kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Nov 22 15:06:22 mnu-2021 kernel: intel-spi 0000:00:1f.5: unrecognized JEDEC id bytes: c2 75 18 c2 75 18
Nov 22 15:06:23 mnu-2021 wpa_supplicant[871]: nl80211: kernel reports: Attribute failed policy validation
Nov 22 15:06:23 mnu-2021 wpa_supplicant[871]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Nov 22 15:06:23 mnu-2021 wpa_supplicant[871]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Nov 22 15:06:25 mnu-2021 bluetoothd[875]: Failed to set mode: Blocked through rfkill (0x12)
Nov 22 15:06:32 mnu-2021 gdm-password][1433]: gkr-pam: unable to locate daemon control file
Nov 22 15:06:35 mnu-2021 gdm-launch-environment][990]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Nov 22 15:07:23 mnu-2021 kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Moderator note:
Please format output using the </> button in the comment toolbar
Thanks. Will do next.
At least the ACPI errors can be ignored. I doubt there is any system running without some ACPI error messages. :laughing:
If your system is working fine, I would also ignore the other error messages.
@Wollie :sunglasses: Thank you for confirming. Everything is working swift & buttery-smooth. Absolute delight to use it.
