Seems to be related to a 3G/4G/GSM modem either your laptop has, or is connected via USB. Probably you need to install modem-manager-gui from community repository.
Most likely the gkr-pam runs before the system initializes the rest of the session, so the gnome-keyring daemon that has to be unlocked does not yet run when first check happens, but if you have no issues logging in your desktop, then is just a log entry that you can ignore.
