Hola, me gustaría sabe que tengo que hacer para reparar estos errores.
dic 24 16:51:21 sergio-tobefilledbyoem kernel: ata3: softreset failed (1st FIS failed)
dic 24 16:51:21 sergio-tobefilledbyoem kernel: sd 9:0:0:0: [sdi] No Caching mode page found
dic 24 16:51:21 sergio-tobefilledbyoem kernel: sd 9:0:0:0: [sdi] Assuming drive cache: write through
dic 24 16:51:33 sergio-tobefilledbyoem kernel:
dic 24 16:51:33 sergio-tobefilledbyoem kernel: scsi 9:0:0:1: Wrong diagnostic page; asked for 1 got 8
dic 24 16:51:33 sergio-tobefilledbyoem kernel: scsi 9:0:0:1: Failed to get diagnostic page 0x1
dic 24 16:51:33 sergio-tobefilledbyoem kernel: scsi 9:0:0:1: Failed to bind enclosure -19
dic 24 16:51:33 sergio-tobefilledbyoem kernel: usb 10-2: dvb_usb_v2: Did not find the firmware file 'dvb-usb-af9015.fw' (status -2). You can use <kernel_dir>/scripts/get_dvb_firmware to get the firmware
dic 24 16:51:36 sergio-tobefilledbyoem bluetoothd[1345]: src/plugin.c:plugin_init() Failed to init vcp plugin
dic 24 16:51:36 sergio-tobefilledbyoem bluetoothd[1345]: src/plugin.c:plugin_init() Failed to init mcp plugin
dic 24 16:51:36 sergio-tobefilledbyoem bluetoothd[1345]: src/plugin.c:plugin_init() Failed to init bap plugin
dic 24 16:52:03 sergio-tobefilledbyoem systemd[1664]: Failed to start Update XDG user dir configuration.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 26 and the job result is failed.
dic 24 16:52:57 sergio-tobefilledbyoem systemd[1746]: Failed to start Powerdevil.
░░ The job identifier is 74 and the job result is failed.
dic 24 16:52:58 sergio-tobefilledbyoem pipewire[1937]: spa.v4l2: '/dev/video0' VIDIOC_ENUM_FRAMESIZES: Función ioctl no apropiada para el dispositivo
dic 24 16:53:58 sergio-tobefilledbyoem konsole[2193]: kf.xmlgui: Shortcut for action "" "Mostrar el gestor de SSH" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
dic 24 16:53:58 sergio-tobefilledbyoem konsole[2193]: kf.xmlgui: Shortcut for action "" "Mostrar las órdenes rápidas" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
dic 24 16:57:39 sergio-tobefilledbyoem konsole[2730]: kf.xmlgui: Shortcut for action "" "Mostrar el gestor de SSH" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
dic 24 16:57:39 sergio-tobefilledbyoem konsole[2730]: kf.xmlgui: Shortcut for action "" "Mostrar las órdenes rápidas" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
dic 24 16:59:10 sergio-tobefilledbyoem konsole[2797]: kf.xmlgui: Shortcut for action "" "Mostrar el gestor de SSH" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
dic 24 16:59:10 sergio-tobefilledbyoem konsole[2797]: kf.xmlgui: Shortcut for action "" "Mostrar las órdenes rápidas" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
