I was updating the system after long time no use
Using “-Syyu”
Internet disconnected and update stopped.
Re connected and pacman says 10 updates available.
The mouse was lagging so i restarted the system.
Grub shows but
‘/boot/vmlinuz-4.19-x86_64’ not found
How do i fix this?
Tired to edit the “4.19” to “5.7”
But didn’t work.
A good practice to start doing is to use Timeshift and create a restore point before doing updates or any major change to your system. Then you can restore back to that point if needed.
If you already have one usb ready - simply use that one. Else always use the latest official iso.
I don’t think so, 4.19 is an LTS kernel and available and perfectly viable choice of kernel. It would not have been removed automatically.
I suspect you had too long an update pause for your system and therefor some pacman hooks weren’t in place when the 4.19 kernel got updated (which would have copied the kernel to /boot).
nope. I didn’t.
I downloaded from the official site and didn’t think there is anything i should worry about. Just like every other time i downloaded manjaro.
