Error , you need to load kernel first
I was installing some updats and the computer went to a blank screen with jusr a curser is the top left but it wouldnt type . after a whike i had to hold powet button to turn it off and now at rhe grub menu i get " you must load kernal first " it wont boot into linux .
Can this be saved ?
Yes.
Boot using the USB you installed the system with - or any other - and chroot (manjaro-chroot) and then finish the update.
Thank you , i folowed the info . now i get welcone to grub for a second then it goes straight to memory testing …
i ran update grub and this is the output i got
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sdc1.  Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
[manja
mkinitcpio -P && update-grub
after chroot manjaro -a ?
You did not run the unfinished update again.
You are still missing a kernel entirely.
If the update does not pull one in - which would surprise me - install one explicitly:
mhwd-kernel -li
to list what is available
mhwd-kernel -i
to install one of them
but first run the update:
pacman -Syu
yes - all of this afterwards - from within chroot
i followed the post above and this is the final output
 there is nothing to do
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
done
exit
 --> umount: [/mnt]
you definitely did not:
At the start of the update, the kernel and initrd is removed.
When the update does not finish, you end up with no kernel and therefore can’t boot,
because the new kernel is only installed at the very end of the update.
The output will look similar to this at the end of the update:
update-grub
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
/usr/bin/grub-probe: warning: unknown device type vda.
Note the mention of:
Found linux image:
and
Found initrd image:
the one posted by megavolt
ok
can we back up, i just ran update pacman its running now
showes one version of manjaro installed .
seems grub is missing and needs to be reinstalled
show us what you see when you run
update-grub
see the last line on my previous post - it expands on click
it should look like this
whatever makes you think that - it’s probably unneccessary but you can do that if you want
[manjaro manjaro]# update-grub
/usr/bin/grub-probe: error: failed to get canonical path of `overlay'.
That is only the last line.
Don’t be stingy with information. :sunglasses:
… you where in chroot when you ran the command?
I suspect you where not.
Everything you do needs to be from within chroot.
i was not , thought i was .
[manjaro /]# update-grub
done
There is still no sign of any installed kernel / initrd.
[manjaro /]# mhwd-kernel -li
Currently running: 6.6.25-1-MANJARO (linux66)
   * linux515
install it again - the result of
update-grub
does not show any kernel - just the memtest
